Question about Dremel Garden
Took apart dremel 200 to clean the dust from inside, put it back together and now the switch to turn on wont work but if I push on the blue plastic screw thing( one on both sides, copper spring underneath it) itturns on. wSomething isnt right or not touching up properly, but what?
    Problem Solver:
  • 8 Answers
The spring with the thingy underneath, looks to be a brush commutator. Part that crosses the points for power to jump circuits.
Posted on Dec 09, 2012
  • Colby Butler
    Colby Butler Dec 09, 2012
    Armature winding, sorry. Couldn't remember the word for it at the time.
  • 12 Answers
SOURCE: i need help putting the metal spring back in. i
Hey if you look at poulan starter rope there is a solution posted for how to re-wrap the spring. ( it's actually pretty quick and easy to do ).
Posted on Jul 06, 2009
  • 86 Answers
SOURCE: oiler not working, need diagram to fix
HI. IF YOU GOT YOUR SAW NEW THERE SHOULD OF BEEN A DIGRAIM SHOWING YOU HOW IT WORKS. THATS THE BEST YOU WILL GET UNLESS YOU KNOW SOMEONE AT THE SAW SHOP BECAUSE THEY DON'T WANT YOU TO KNOW HOW TO TAKE THEM APART AND PUT THEM BACK TOGETHER. GOOD LUCK. JIMBO
Posted on Sep 14, 2009
dontbother10
  • 2220 Answers
SOURCE: Chain brake Assembly
A drawing of a Poulan Wildthing can be found here:
http://www.ordertree.com/modelinfo/PWE/2375-Gas-Saw-Type-1/75.2375-Gas-Saw-Type-1.1.59.1.html
Click "
View the illustrated parts list [Go]"
There are multiple drawings, this one may not be the correct one. The detail isn't very good but this is the best illustration for your saw. The "Handle, Chassis, and Bar Assembly" shows what is available. GL
Lou
Posted on Sep 21, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a poulan Pro 295 Chainsaw, I took apart the carb.
It appears to be an isolator or buffer #34, but I do not think it would have anything to do with not starting.
Posted on Nov 12, 2009
dontbother10
  • 2220 Answers
SOURCE: can't get chain to tighten
Hello Ted:
This is a very good OM for a Remington. Look at figure 8 on page 8. The adjustment block MUST engage one of the holes in the bar, Then do 1 through 5 as illustrated and you cannot go wrong.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/113005-01D/113005-01D_OM.pdf
If the block is engaged, the bar nuts are finger tight , and the adjuster will not tighten the chain it must be stripped. If not stripped, follow this example.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If it still causing problems try a local saw shop where someone can see what the problem is. Ask them to demonstrate please.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 07, 2010
I took the filter out of my Windtnnel Pro Pet to clean it (not with water) I put it back in and now the vacuum wont turn on.
I'm going to guess that when you put it back together it didn't quite go back in correctly. There could be a switch that prevents it from turning on if the filter is not installed. Make sure that it is seated correctly. I hope thats all it is.
Dec 27, 2014 | Tti Hoover 4010100Y 3-Pack Type Y...
I took my kitchenAid stand mixer (md# KSM5PSAC) apart to replace the plastic gear inside of it. When I put it back together it would not start. I took it back apart took a good look at all the connections,...
You need to either re-time the speed control switch at the back or replace it. If it worked great before then it is just an adjustment to get it back to running correctly. YouTube viseo available for timing the switch
Aug 06, 2013 | KitchenAid K45SS Classic Stand Mixer
I took my desktop apart and put it back together and now it won turn on
Open it back up and check to make sure you didn't accidentally pull one of the cables out.
Jun 30, 2012 | Dell Computers & Internet
Will not turn on. Bushings are fine/replaced.
Problem is more than likely that the plastic brush holder got hot with continuous use and the brushes n longer slide smoothly in their housing. Sometimes they even twist a little. The only solution to this is to replace the brush holder-variable switch assembly.
DH
Dec 30, 2009 | Dremel Variable - Speed Multipro Rotary...
360 wont turn on
The disk tray button on the unit is probably being pushed in from the outer cover. When you took it apart and put it together you may have pinched the button in. Very carefully inspect the disk tray button area. The button needs its full range of motion. The faceplate is pushing the button in and that is why it works without it. Or the face plate is making the top cover to press in on the button. Go over the area and watch what the pieces are doing when you assemble the front in regards to the tray button. I had the same problem. Remember these pieces are plastic and after being run (heat) the plastic may want to warp a little since new.
Sep 27, 2008 | Microsoft Xbox 360 Console
How do I reassemble On/Off switch?
The actual switch will not fall apart. There is a black part that is integral with the switch itself. This is about 1/4" to 3/8" wide, and can only be seen from inside the unit. Then there is a plastic piece that is part of the top shell. The hole in the plastic piece has to fit over the black part of the switch, so when the plastic piece is moved, the switch on the inside of the unit will move with it. SO, center both parts, and put them together. If you actually took the switch itself apart, you would have needed a soldering iron, and there would be no purpose for doing this.
Apr 03, 2008 | Fellowes P700-2 Shredder
Clean button
My ionic pro did the same, the red light just wouldnt go out, so I looked down the plate opening, (with unit unplugged), and could see one of the wires was broken. (these are the ones you clean by pulling up that plastic tab). I am currently looking for replacement wires, will post my progress. GregV
Oct 10, 2007 | Ionic Pro 901P2RIP04 Air Purifier
Garden Logo
120 people viewed this question
Top Dremel Garden Experts
Dennis Key
Dennis Key
john h
Are you a Dremel Garden Expert? Answer questions, earn points and help others
