Question about Braun Syncro 7526 Electric Shaver
The On & Off Switch does not work!!!! - Braun Syncro 7526 Electric Shaver
Pry out the blue button. In the oval hole where the button was you will see a thin metallic part (semi-circular shapes on each side); pull it out through the hole and the switch will be functional.
Posted on Aug 12, 2008
  • BeerBellyJoe Aug 05, 2011
    This is listed as the "best solution"...
    it's actually the ONLY solution!
    Now I know what to ask for this Christmas but at least I'll be able to shave until then.
I have a 2004 kia how do i know if the ignition switch is bad or going bad
Have it tested
If your working on a vehicle problem, you need a reason
to go & test the ignition switch
That reason comes from looking at & studying wiring diagrams
for a system problem & seeing the relationship or cause & effect,
that part has to your problem,basically lack of voltage not going
somewhere & controlled by the ignition switch
Testing can be done at a distance from the switch, depending on what info your gathering off the diagrams & confirming what works
& what doesn't
Jul 16, 2014 | Cars & Trucks
Scion xa driverside door switch wont unlock 2006
That's in all prob the switch itself. If you can, open the switch panel & test if you have power & ground w/ a test lt as U move the switch back & forth, if OK, U need a switch. if no power or a bad ground-electrical short. sounds like a switch or the connection. Good luck Frank M (if elec short & U cant handle it, take it in.
Mar 15, 2013 | 2006 Scion xA
Battery disconnect switch not turning on & off properly
i am a tech at a ford dealership. it sounds like you have a short some wheres around your steering column that maybe what we call "backfeeding" to other systems. the area where the tilt is on the steering column is a good place to check. also remote starters can cause alot of havoc on a vehicle.
Oct 21, 2012 | Cars & Trucks
I have a 2009 dodge avenger that the front passenger window goes down but it doesnt go back up. I checked power at the motor & had power going both up & down. I thought it was the motor but I...
It may be a bad Power Window Switch, if the Power Window Motor goes up and down when you ran power leads to it but doesn't work with the switch, than the switch is bad. Replace the power window switch and it should work fine.
May 04, 2011 | Dodge Avenger Cars & Trucks
2003 Explorer XLT. Driver's door lock switch does not lock, only unlocks all doors. The key fob switch works on all doors. Broken switch?
May be switch but could also be bound up linkage &/or door lock actuator. Pull interior door panel & lube up all rods, linkage & actuator with a good penetrating oil. Then watch linkage & actuator as you lock & unlock door.
Apr 04, 2011 | 2003 Ford Explorer
I have a 1996 Jeep Cherokee and the heater vents dont work.I have tried to find a picture of the fuse panel i can read but i cant..When you swith it to vents it only comes out of the defrost.Where can i...
Hope this helps:
Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206): 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
Row 1: 1-6 (left to right) Row 2: 7-12 Row 3: 13-18 Row 4: 19-22
1996 Jeep Grand Cherokee Fuse Panel (Passenger Side kick panel) Reply
CAVITY FUSE DESCRIPTION 1 -10 amp (RED) Radio 2 -15 amp (Lt Blue) Cigarette Lighter 3 -10 amp (RED) Rear Washer Switch, Body Controller 4 -10 amp (RED) Airbag 5 -10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II 6 -15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror 7 -20 amp (Yellow) Body Amp, Cluster, Body Controller 8 -20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow 9 -15 amp (Lt Blue) Brake Switch 10- 10 amp (RED) Rear Window Defroster 11 -10 amp (RED) ABS Module 12 -10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor 13 -15 amp (Lt Blue) Hazard Switch, Turn Signal Switch 14 -15 amp (Lt Blue) Spare 15 -15 amp (Lt Blue) Spare 16 -10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror 17 -15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller 18 -20 amp (Yellow) Spare 19 -15 amp (Lt Blue) Passing Light 20 -15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center 21 -15 amp (Lt Blue) Power Outlet 22 -10 amp (Blue) Airbag Module -------------------------------------------------------------------------------------
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehiclesairconman.jpg
Dec 16, 2010 | 1996 Jeep Grand Cherokee
Brake lights not working even though the brake peddle is pushed down The switch still goes in and out. Fuse box has some fuses missing. The fuse box does not have a desription on every plug of what it is...
Here are the numbers on your fuseblock and fuses coresponding to the number that is on your fuse block.
1-20 amp (yellow)
Hazard flasher
2-10 amp (red)
back up lights, A/C clutch cycling Switch
3-30 amp (green)
Power windows
4-30 amp (yellow)
A/C or heater blower motor
5-20 amp (yellow)
Panel Lights, Side marker lights, Park, Taillights, Clock & radio display Intensity, License & panel lights.
#6-10 amp (red)
Stoplight, buzzers, Anti-lock brake module
#7-15 amp (lt. Blue)
Tachometer, horn & Relay
#8-8 amp (yellow)
Power Door locks
#9-10 amp (red)
#10-10 amp (red)
Rear Wheel Anti-lock module, Turn Signals
#11-20 amp (Yellow)
Windshield wiper & washers
#12-15 amp ( LT. Blue)
Cigarette Lighter
#13-5 amp (tan)
Speed Control, warning buzzers, gauges, indicator lights
#14-5 amp (tan)
Time/delay relay & under-hood light, dome light, power mirrors, readio & clock Memory, Interior lights, reading lights
Not used
#16-4 amp (pink)
Radio Lights & overdrive switch light 1989-91, Cluster lights, Cigarette Lighter light & as tray light, Cluster lights, A/C & heater controls.
Hazard Flasher warning
#19-Circuit breaker
Turn signal Flasher
Aug 04, 2009 | 1991 Dodge Dakota
Distortion stopped working
Hi there. Check the foot switch. Plugged in all the way? Still not working? Use an ohm meter to check the foot switch. (unplug from amp and check for continuity across the plug. click switch on and off.) If alway open (no continuity) bad switch.
May 26, 2009 | Music
Guitar amp channel switch repair
Replace the switch. You gave no make/model number for your amp but if it has a jack for foot pedal operation of clean/dist function then try that. (on most amps) it will switch in spite of a bad front panel switch.
Dec 21, 2008 | Music
Crown D-150 Amp
Sounds like something was spilled into the amp and it got into the controls, switch and switch knob. As for the knob, lean the amp forward about 45 degrees and dribble hot water into the space behind the knob slowly. Try to keep the water from going inside the amp. Eventually, the knob should come off with some pulling & twisting. Once you get it off, replace both pots and the switch. If water gets into the amp just dry it up with paper towels, etc. and let it continue to dry while getting the new parts. HTH, Emory
Sep 27, 2007 | Audio Players & Recorders
Braun Syncro 7526 Electric Shaver Logo
98 people viewed this question
Top Braun Health & Beauty Experts
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
