Question about Maytag Refrigerators
Maytag Refrigerator model MZP2766GEW insulation around doors of side by side freezer and refrigerator hot when you touch.
    Scholar:
  • 191 Answers
  • Is the thermostat knob turned to the proper setting? If not, reset it.
  • Next, see if the compressor motor is running
    The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
    If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
    • The compressor
    • The Thermostat
    • The overload, relay, or capacitor
    • The defrost timer
    • The condenser fan motor
    Posted on Aug 01, 2008
    • Maytag Master
    • 19,396 Answers
    That may be normal , important is cooling inside. Check if the gasket is insulating
    • Ginko
      Ginko Aug 01, 2008
      If the gasket is just warm that is normal, if it is burning hot pull the unit away from the wall and remove the rear bottom cover to check if the condenser fan is running. If it's dirty there, unplug the
      unit and clean rear of the fridge.
    LG side by side Model LSC 26905
    Insulation does not melt - gaskets may be affected by hot temps.
    Your condenser coils may be located on sides of fridge. If so the unit will be warm to the touch on the outside.
    Jul 29, 2016 | LG LSC26905TT Side by Side Refrigerator
    Mzd2766geb maytag ref freezer door insulation frozen solid with ice
    Even if the unit if issue free, this older design is still suseptable to moisture intrusion behind the inner liner. If your ice is below or around where the fointain area is, than you may be leaking water from the fountain behind the outer door shell. Since your outer door and inner liner are no longer avail, the best suggestion is to turn the entire fridge off, and let everything completely dry before re assembly. Once insulation gets imbedded with moisture and freezes, the insulation factor diminishes. Although your outer door insulation should be the newer style semi solid foamed in style, so moisture intrusion will not be any deeper than an inch or so. If the fountain heater has failed around the dispenser, you attract moisture to that area too. Pleazer Appliance...
    Jan 06, 2015 | Maytag MZD2766GES Side by Side...
    Door hot
    Totally normal. The condenser sends hot gas through the frame to stop the freezer door freezing to the frame. Check to see if you have a fan behind the condenser grill and make sure its running and clean
    May 04, 2017 | Maytag MSD2756G Side by Side Refrigerator
    Exterior of refrigerator between freezer and refrigerator is hot to the touch
    It is normal unless there is a lot of dust below your refrigerator blocking airflow. What you feel is hot gas tubes behind the surface of the metal to help reduce moisture around the door frame and door seals that will get hotter should the fan and condenser below refrigerator have a blockage of dust blocking airflow, Sea Breeze.
    Jun 17, 2013 | KitchenAid Superba Architect KSCS25INSS...
    The doors are scorching hot to touch on my Maytag 2454. It's always been warm to touch, but all of a sudden it is too hot to even touch. It is in the center part of both doors, along the door seal area and...
    It's usually caused by the condenser fan which is underneath around back. If it's not running when the compressor runs it will cause the problem you describe. You will need to remove the cardboard backing on the back of the fridge to access the fan.
    Apr 22, 2010 | Maytag MSD2454G Side by Side Refrigerator
    Freezer malfunction
    Drain hole is clogged behind the panel that covers the coils. I found a peice of solder blocking mine. Water was freezing on the bottom of the freezer and leaking out to the floor.
    Aug 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
    Door frame is always hot on freexer side
    Is it hot all the way around, or just on the face of the divider between the freezer and fridge? If it's just the divider, then it's probably not a defrost problem. When that divider gets hot, it usually means there is inadequate air flow over the condenser coils outside the unit.
    When the compressor is running, check for air blowing under the unit. If no air is moving, then you probably have a failed condenser fan. If the fan is running, then use your vacuum cleaner to clean the coils, and make sure there is space behind the fridge for air to flow.
    Jul 21, 2009 | Maytag MSD2756G Side by Side Refrigerator
    Area around freezer door is very hot to the touch. ice maker works, but after awhile the ice will melt. freezer is freezing.
    HI, That area being hot is a sign the refigerator is not cooling properly. We need to pin point the cooling problem.
    First, are you noticing any frost build up inside the rear freezer panel?
    Are the fans and the compressor running?
    Please let me know so I can assist you through this.
    Vic
    May 27, 2009 | Refrigerators
    Outside freezer hot and seals
    Fridge has either mullion heaters around door or most likely steel pipes just inside the skin of the perimeter of the door, this is to stop ice or condensation forming around the door seals, mainly the freezer, they are part of the condenser circuit ( hot part of the refrigeration system).
    It is normal for these to get hot, but in your case may be hotter than usual because of the constant running, the running may be caused by hot ambient temperatures, system being slightly short of refrigerant, faulty thermostat or in-efficient compressor.
    I suggest if temp is ok inside fridge dont worry too much, if you notice fridge starts loosing its capacity to refrigerate, have a refrigeration tech look at it.
    Nov 13, 2008 | Maytag MSD2756G Side by Side Refrigerator
    Refrigerators Logo
    63 people viewed this question
    Top Maytag Refrigerators Experts
    Bailey's...
    Bailey's...
    John Tripp
    John Tripp
    Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
