Question about Volvo 670 Tractor With Dry Van Trailer
I have a 18 speed auto shift on a freightliner and it is getting stuck in gear and some times it says gearbox erratic
  • 28 Answers
For an auto shift ck for the harness on right side below frame rail.wires somethines shaff.if this is all right ck for x y shifter.if code stuck in gear or unable to select rail.
Posted on Dec 15, 2011
  • 784 Answers
Check the gear selector cilinder- may be faulty. It works with air.
Give me more details how it is.
Posted on Mar 15, 2011
  • gmurphy33 May 08, 2011
    check the air system. it sounds like you are getting contaminates in the system which will cause this. also you didn't specify. is this an electronic box?
Failling to engage gears and it's giving code 58 in Eton fuller gearbox in freightliner smart shift
Best Manuals Visit the on-line store, known as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
I have attached the link
Dec 03, 2017 | Smart Cars & Trucks
1998 nissan altima with manual 5 speed transmission is stuck in 5th gear and will not come out. any ideas?
if cables are used to change gear to the gear box check those
shift stick bush worn ..remove center console
internal gearbox shift rods syncro / scroll pin broken
clutch system master or slave or pressure plate issue
Oct 08, 2016 | 1998 Nissan Altima
My scania is showing gearbox malfunction on dash.what could be the problem?
This message mean more things
You must explane what happened with you exactly,
What us the type of your gearbox, manual or Opticruise
What is the gears you can mount it,and more things
Nov 05, 2014 | Cars & Trucks
P0722 FAULT CODE
P0722: Transmission speed signal missing.
There is a turbine speed sensor that detects and reports the speed of the transmission shaft to the computer to help determine shift points. Sometimes this duty is shared by the VSS (vehicle speed sensor) but if your speedometer still works, then the VSS is good and you should replace the TSS (turbine speed sensor). I would guess you are either stuck in 1st gear all the time or your transmission shifts erratically.
Nov 19, 2011 | 1999 Volvo C70
Gear shift stuck i n park, what do i do?
Try releasing your parking brake and having someone push or rock your car. Sometimes the gearbox gets stuck in Park if the car moves after you put the car in Park and let the car roll a bit before applying the handbrake. It could also be a fault with the gearbox itself.
Its also possible that the locking tab mechanism (that gets relesed when you press the button on your auto gear shift) has jammed. If you can get it out of Park do not put the car back into Park ,but rather put it in Neutral after you have finished driving around etc and use the hand brake when parking. At least you wont be stuck in Park until you get it to the repair shop. Note that your car can roll in Neutral, especially if your parking brakes are worn, so take extra care when parking ie point your wheels toward the kerb when parking on any hills or slopes.
Any time your gearbox gets stuck its a fair bet that you need to get your gearbox inspected by an authorized repairer.
Good luck,
Steve (Melbourne, Australia)
May 14, 2010 | 2002 Acura 3.2TL
18 speed bike 6 gear shift works fine 3 gear
You have to look if when you act on the shifting level it get hard to move or it is free, if free, probably the cable is broken.
Also check if the cable is not too loose, try to follow the cable track and move the level and see if the cable move with that, in that way probably can find where the cable is stuck or broken/loose.
May 09, 2010 | Huffy Alpine 24 Youth All-Terrain Bicycle
Trans shifting prob n gas mileage
have the shift solenoid checked out
Auto Zone will perform a free scan of the computer to dee which one is at fault
Feb 28, 2010 | 1996 Ford F250 Crew Cab
I NEED instructions on operating a 8 speed freightliner
whenever you get to the highest gear it will go in low range flip to high range. i drove a truck once with 18 gears.
Mar 20, 2009 | Walthers Ho-athearn-5506-freightliner...
95 honda civic automatic will not shift into second
Hi there OK, I assume that the autobox is stuck in first and you have two possible problems. Firstly, the shift value in the shift value block is stuck thus continually selecting first gear, or the speed sensor within the auto box is seized. Both these problems is as a result of not having the gearbox oil changed as per the recommended service intervals. Firstly, identify the colour of oil on the auto tarns dip-stick - if it's black, you need to change the oil in the autobox. After you have done this, drive the car in first for a few miles to circulate the new oil and after the vehicle is at normal operating temperture, go as fast as you can in first gear. What this is doing is maximising the load on the speed sensor in the gearbox and by increasing the speed it might just unseaze and change into the other gears. The other thing to do is a stall test, but I suggest that you have a Honda Dealer do this. Best regards, Scottech
Jan 15, 2009 | 1995 Honda Civic
Volvo 670 Tractor With Dry Van Trailer Logo
407 people viewed this question
Top Volvo Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Volvo Toy Expert? Answer questions, earn points and help others
