Question about Vacuums
Please please help me! I recently bought an Empisal Celebrity 550 Sewing machine, I've used it maybe 4 times up to now. Yesterday I was sewing with it and everything was working perfectly, today, when I got home, I plugged in the sewing machine and started sewing, just to see that the bottom stitch is completely loose. It's making this loose loops instead of stitches? I didn't change a knob or anything from working with it yesterday to today, so I don't understand how it all of a sudden doesn't work? I've read some forums where people say it's the tension on the bobbin that causes that, but I haven't touched it. And if it is the bobbin, how do I adjust it? There is no knob or lever or anything for my bobbin, the only knobs / adjustments available is for stitch widths and different kind of stitches, there's no other knob left that could be for the bobbin. Please help me, I'm on a very tight deadline for a university project and I don't have a clue what to do?
  • Vacuums Master
  • 1,534 Answers
This is the forum for help with vacuum cleaners. Post in sewing machine forum for help.
Posted on Mar 11, 2017
Tally Girl
  • 1133 Answers
SOURCE: I bought a 2nd hand
I haven't been able to locate a manual for this machine at first look. The only Empisal manual I did find was called "Expandamatic" at this site http://sewingonline.co.uk/empisal.html there is an image of the model. Or you could try www.2instructions.com or www.manualfox.com and see if they have something available to buy.
However, http://sewing.about.com/od/sewingmachineindex/bb/sewingmachines.htm this website gives lots of general information on sewing machines, how to use, basic threading up in a general way and other tips and tricks.
In general terms most sewing machines will have the following controls:
stitch length selector/dial - to choose length of stitch, usually goes from zero to 4, normal straight stitch would be 2.5.
Stitch width selector - early models only did straight and zigzag, so by adjusting this knob you would set how wide the zig zag stitch is. If your machine does other stitch combinations, then you would use this to set the width for those too. Again, probably ranges from zero (straight stitch would be zero) up to 4.
A tension dial setting to adjust the tension on the top thread, usually set to 5, but would range from zero to 10.
If your machine does anything more than straight and zigzag, then it would have some other dial or stitch selector or even a cam that you insert to get these other stitches.
I hope this helps you get started with your machine.
Posted on Jul 07, 2011
e-Guru
  • 3917 Answers
SOURCE: while using the pin stitch
Please go through the link given bellow to have the resolution to your problem...
http://sewing.about.com/od/sewingmachineindex/a/mtroubleshot.htm
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Posted on Apr 27, 2010
  • 79 Answers
SOURCE: loose stitches tention loose long
Thread tension is more dependent on what you are sewing than machine model. Upper should almost always be tighter than lower, and the thread should pull up into the fabric being sewn.
Posted on Aug 19, 2011
SOURCE: I have an Empisal Q2719/9300
Hi All
I have gone and uploaded the Instruction user manual for the dress maker 270d Please use the link provided to download the Instruction Manual. Have Fun :)
https://rapidshare.com/files/2244612243/Empisal_Dress_Maker_270D_Instruction_Manual.pdf
Posted on Sep 12, 2011
SOURCE: Hi. I got a Kenmore
Hi Silvia,
I am having the same problem and am unable to find an answer. Please let me know if you've figured it out!
Kay
Posted on Oct 28, 2011
Empisal dress maker 270d
Sounds like your tension is vibrating off to a least tension position, When the machine does this again check your tension button. Hope this is the solution?
May 16, 2014 | Vacuums
My daughter removed the tension dial on her empisal em 250 sewing machine. I have tried to put it back correctly but the bottom thread is so loose every time i sew. i think i have not put it back...
Hi. Start by taking everything back off. There should be the knob, a spring, two matching discs and one disc that is smaller than the other two. The two matching discs should go on first and should mirror one another with the flaring edges both facing out from where the discs touch. Then goes the smaller disc, then the spring with the larger end on the discs. Screw on the knob with the numbers facing out, all the way down till it stops and that should be the maximum setting. Back it off all the way to where the tension is indicated as 3 for your starting point. By the way, do all of that with the foot lowered. Raising the foot should separate the tension discs, which makes it possible to pull your work piece out from under the sewing area without breaking the thread.
Sep 09, 2011 | Vacuums
I have an Empisal Q2719/9300 sewing machine and need a manual to work out the stitches and how they work
Hi All
Jul 06, 2011 | Vacuums
How to get Brother sewing machine apart to replace spool spindle.
To be honest the best thingon such instructions is the manual which is provided along with the machines,but many people don't have it , probably because they have lost the manual orthey have got the machine as a used one and forgot to take the manual alongwith it.
Please follow the belowinstructions :-
Close to the end of theHandwheel , there is usually a spindle, at the back of the machine.
This is where you need to restthe spool on and you would notice it sitting perfectly.
In case the length of the spindleis less , then pull it up gently with your fingers.
Also there are machines these dayswhich have easy to replace facilities , so the spindles just slide intothe machine for safety norms when you put the machine away.
Therefore , all you need to do it pullit up and it would be fine.
An example of a manual forbrother's sewing machine can be found in the below link which would give you anidea of how exactly it's done.
http://bit.ly/j2BdsP
Hope this helps ..:)
Jun 11, 2011 | Vacuums
My Kenmore sewing machine timing has gotten off. I am sewing a big upholstery project and it starting bunching thread from the bobbin. The thread is so heavy that I had to put some pressure just to get...
Hello
Disassemble your bobbin case which is realy quite easy, clean thoroughly with a brush and air, paying particular attention to any rust that may have formed, and any thread that may have weazeled it's way into small but very incremental areas of your case.
Make sure your needle is not in backwards.The rounded side should be on the outside
. If threading is correct and your tension is properly adjusted , then check the hook for scratches. If you have ever hit the hook with a needle, it will be scarred and will catch the thread every time the upper thread passes around the bobbin case. the hook is the sharp point on the shuttle that holds the bobbin case. If it is scratched, polish it smooth with VERY fine sand paper
Make sure that your thread arm that rises and falls, constantly having tension running through it and that it is in fact staying in place.
Alternate between the metal and plastic bobbins - sometimes the plastic bobbins tend to chip
Dec 04, 2010 | Kenmore Vacuums
While using the pin stitch , the machine has started skipping stitches, knocking loudly, the top thread is breaking, sometimes thread knots up on the underneath side. I have cleaned bobbin area, changed...
Apr 27, 2010 | Vacuums
There was no category for sewing machines....so I picked small appliance. When I depress the foot control E1 flashes on the LCD screen. I've followed the steps in the manual but it continues to flash...
As you have not provided the make and model no. of the machine it really tough to get the exact solution for you, however few tips for you via few links:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faqh/000000/000000/000057/faqh000057_000.html?reg=us&c=us&lang=en&prod=hf_cs6000btieus&Cat=56
http://www.ehow.com/how-does_4842399_troubleshooting-brother-sewing-machine.html
Please let me know if this helps, or provide details of the make and model no. of the machine.Would appreciate extra details if recently you have done something with the machine.
Mar 16, 2010 | Vacuums
Vacuums Logo
46 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
