Question about Sport & Outdoor - Others
Ski doo won't start after running fine. - Sport & Outdoor - Others
  • 4 more comments
  • drwood81 Mar 15, 2011
    Sorry, what was the word before 'plugs'?
    It's got spark and it's getting gas. My husband already tried the other things you suggested. He's wondering if it could be the head gasket?
    I'm not sure how to use this site, so I'm not sure if you received my response. My husband already tried your suggestions to no avail, so he's now wondering if it could be the head gasket?
    Our 2002 MXZ 500 ski doo won't start after running fine. It's not the choke or flooded plugs, since my husband's already ruled that out. He's wondering if it could be the head gasket?
    Will it just quit running completely if the head gasket goes? He can feel compression but he doesn't know if it's enough.
    Genius:
  • 1,126 Answers
Check and see if the choke is stuck, and might lubed, on the linkage to the choke, and the reason it will not start could also be foud plugs.
Posted on Mar 15, 2011
  • 10,865 Answers
Hello dr..... these jet skis need to be put on a battery charger every now and then to put them back in running order. Once you once again have a full charge, your Ski Doo will start right up. Joe
Thanks for choosing Fixya!
Posted on Mar 16, 2011
  • Sport & Outd... Master
  • 5,370 Answers
Yes it can be dirty carburetor or problem with air leaks. If the Ski Doo shuts off while riding, change the plugs and clean up the carburetor. If this does not work, it is time to change the kill switch.If the Ski Doo does not start after cleaning the carburetor and kill switch looks fine, then install new gaskets to take care of air leaks. ------- In some cases its problem with pilot jets.First clean the carb and jets then check.If still the problem,.check the kill switch.If its checked out ok then there is air leak causing the problem.The gasket need to be replaced. ----------- This should help.Thanks.Helpmech.
4 Suggested Answers
  • 65 Answers
SOURCE: 1982 kawasaki 550 stand up ski-doo,starving for fuel
fuel pump ? checked pop off presure in carbs?
Posted on May 07, 2009
  • 85 Answers
SOURCE: I have a Ski doo 583 RAVE motor theat backfires
It sounds like you have a reed problem they should be in a "cage" just behind the carbs on the cylinder and if they were missing a piece or if they were cracked it would cause the engine to backfire. If they are in good condition they should close against the cage and stop the back pressure coming through the carbs.
Posted on Jan 21, 2010
  • 677 Answers
SOURCE: Sea doo jet ski won't get full throttle. It idles
I am not sure of the model that you have,so its a bit hard to help.If you have a seadoo and you want great help,I would go to seadooforum.Its the best site with really good,and also total knowledge of all things Seadoo.I have one also.The help is unsurpassed.I have a seadoo also.Hope this helps you
Posted on Feb 03, 2010
07 Doo 500ss doesn't charge, already tried stator and regulator
What is the resistance on your stator leads, when running what is your output from the start (before the regulator) it will be ac volts there will be 3 leads.
Feb 14, 2018 | Ski-Doo 2007 GSX Sport 500 SS
Ski doo 583 starts and runs fine for 1-2 minutes then dies and won't restart fo 30-40 minutes.
failed electronic part in ignition or sensor
internal component overheating and breaking the circuit until it cools down
Nov 04, 2017 | Winter Sports
2009 SUMMIT SKI DOO WILL NOT START
Ski Doo's are known to have BAD KILL SWITCHES
DPM going bad
Dec 24, 2013 | Ski-Doo 2009 Summit Everest 146 800R Power...
2002 gti sea doo wont turn over on the first try
if you have one of the kill cords that is round and it snaps onto a round button that has a silver dot in the center that when the kill lanyard is snapped into place makes a connection to the silver part inside of the kill lanyard itself. most the time its because it is still verifying that it is the right key. they are programed to match you CDI box/ignition module of your ski. this prevents theft. if you clean both the key and the button the key connects to with some rubbing alcohol to insure a good clean connection will most likely solve the problem. when you put the key on the ski you should hear a beep then wait 5 to 10 seconds before hitting the start stop button . that gives the ski time to recognize the key is in fact the correct key to the ski.. hope this helps
Jul 25, 2012 | New Ray 112 Scale Bombardier Sea-Doo XP...
Ski doo x team racing problems please help me
Try running in compatibility mode. Rightclick the shortcut, select properties>compatibility>check the box that says: run in compatibility mode for: and select an OS.
If that doesnt help I'm afraid you gotta actually run windows 95, 98, me or 2k to get it to work.
I hope this helps,
Yannick
Feb 17, 2009 | Simon & Schuster Ski-Doo: X-Team Racing...
Sport & Outdoor - Others Logo
1,234 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
