Question about Asko W6761 Front Load Washer
Hi I have an ASKO 20004 WM200, washing machine, that not pump out the water. It looks like the pump just goes back and forth without it rotates to clear up. What could be wrong
    Brigadier General:
  • 6,277 Answers
It's not the drum rotating which pumps out the water but a separate drain pump motor.
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter.
Here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 15, 2011
Why is it not cleaning dishes?
Contact one of the Asko authorised repairers in your area and they will be able to tell you the likely cause provided the water in your machine is heating up to the correct temperature and not trying to wash luke warm and without the powder dissolving properly.
Set the machine for a hot wash and stop it and open the door mid wash cycle and check how hot the water is. It should be extremely hot and you should get a mass of steam rushing out when you open the door.
Jan 10, 2016 | Asko 24 in. D3121XL Free-standing...
Asko 20004 washes but won't spin
This is a motor fault issue. As I don't know your ability in repairing or what tools you possess. Simple solution: other then have a repairman do this, the motor has something causing a fault. The vast majority of times in an asko because the motors spin at high speeds then most others is that the brushes wear out. So they most likely need a repair. Turn off machine, remove motor replace brushes. There other possibilities such as electrical problems but I reckon brushes are the problem, could cost $60 for the pair and takes maybe an hour or two depending the skill of the person attempting. This is not complex just dirty I do not endorse repairing any appliance without proper experience in repairing appliances. This is only informative.
Nov 18, 2013 | Asko Washing Machines
Asko w6221 Washer just spins back and forth for hours in wash cycle. It fills with water, then simply rotates back and forth...it will do this for a well over an hour. I have to manually select the rinse...
This seems to be a fault with the controller unit as there is no program cycle execution . So remore the power plug and let the processor reset, now try with different programs and if the cycle does not move it is possible that the controller unit is faulty.
Sep 21, 2011 | Asko W6221 Front Load Washer
Hi, I have an ASKO 1253 which is working fine except that the rotors aren't spinning anymore. I have taken the trays out and the rotors off to check for blockages/obstructions but they are fine. I...
HI,
When you refer to rotors, are you talking about the spray arm that circulate water? If you have no water movement within the dishwasher, this unit has 2 motors, one for wash mode and the other for drain. If the unit drains but would not wash, I would think the wash motor/circulating pump has failed or jammed. The only was to see if the motor is jammed is to manually rotate the motor from the back of the unit. There are vent fins that you can safely rotate to see if the motor was jammed, if after rotating the motor the unit fails to run, need to replace circulation pump.
I hope this helps.
Aug 09, 2011 | Dishwashers
Have an asco 12505 front load washer. instead of spinning, only rotates back and forth like wash cycle. Why?
may be timer or lower board if it has one,hard to tell without being there,it wont be the motor
Jun 05, 2010 | Asko Washing Machines
Asko washer 20004 stopped mid cycle, water is
Do not play with water and 240volts or 120 volts....it is a LETHAL cocktail.
Get a techo to save you the headache and possibly YOUR LIFE!
Oct 19, 2009 | Washing Machines
I have an asko wm200 washing machine. I have an F3 error, which is stopping me from opening the washer. The washer is also still full of water. Just need to know how to get the door to open and the water...
open the little door at the bottom or remove the toe panel... then there is a coin trap... that will let you remove the water there is a black hose with a plug on the end remove plug and drain the water...by turning it and pulling it you can remove the coin trap and you my be able to remove somthing stuck in it... also there is a red string you can pull it and release the door
Hope it helps if NOT let me know more about your problem... and I will help
Jul 08, 2009 | Asko W6761 Front Load Washer
Asko 12605 overheating the wash water
(even not taking in hot water when filling before the wash stage which seems good)
The washer fills with cold water then heats it up 3 degrees a min. Your problem does sound like a faulty thermostat. Especailly if the glass door does get hot even if it is on 85f.
May 29, 2008 | Asko Washing Machines
Asko W620 washing machine not spinning
Sounds like the motor brushes need to be cleaned or replaced. Take the back off the washer, remove the motor and gently scrape the excess carbon or debris off the brushes with a pocket knife. I did this and it ran well for about 50 loads before building back up. I am ordering new brushes now because when I checked the brushes last week they were obviously worn more than 4 weeks ago.
Dec 11, 2007 | Asko W620
Asko washer 20004
where does the leak appear at?
Sep 17, 2007 | Asko W6441 Front Load Washer
Asko W6761 Front Load Washer Logo
131 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
