Question about Home
I need to replace the flappers on 2 Jacuzzi toilets. I have the numbers from inside the tank but cannot find any on line source to order the replacements. Can you help me? zip code 94901
    Genius:
  • 1,739 Answers
This site is an authorized Jacuzzi distributor.
http://www.guillens.com/index.jsp?path=find
If the link does not take you to the selection of Jacuzzi toilet flappers, select Jacuzzi for the Brand and 'toilet flapper' in the search filed at the top of the page. Click FIND.
Posted on Mar 28, 2011
Water is seeping past flush valve causing tank fill valve to refill tank
Replace the flapper unit and if needed the lower unit it drops into, one or the other is causing this and Flapper is the most common.
Dec 13, 2012 | Jacuzzi Bath Perfecta EZ33 959 White round...
I have a 3 yr old jacuzzi 3 inch value /flapper. need to replace the complete inside tank and gaskets to stop leaking.loew s is the place i went to purchase parts but they do not have them.no one has...
A local plumbing suppy may have it or order it for you... worth calling a well known local outfit...and having a chat with a live person.
Otherwise call Guillens Supply 1 800 222 7855
www.guillens.com
Their website is maddening.. unless you have specific part numbers from the owners manual or can access a parts diagram.. a phone call or email request or even a fax would be better.
Be very clear about what parts you need..
Best of luck
Apr 17, 2011 | Jacuzzi BK37959 White Era?? Two-Piece...
Looking for the 3 in flapper gasket for a jaccuzzi brand toilet. The local jaccuzzi store told me LOWES has it, but they dont and my toilet is currently out of service for it. Is there somewhere i can...
The Jacuzzi website sends you to dealer websites; Lowe's is the only one that stocks toilet flappers. Of the 34 different flappers they stock none are specifically mentioned as a replacement for a Jacuzzi product. You are probably best served by choosing the Universal model that approximates the style in your toilet and connects and operates in the same manner.
Check the on-line listing of toilet flappers from Lowe's here. You can locate a nearby store with stock or order on-line and choose to have the product delivered.
Jan 30, 2011 | Home
Jacuzzi sent me new rubber gasket for attaching flapper assembly to tank-(held in place with a large white plastic nut) Does the totally flat side of the rubber washer face the tank or away from the tank?...
The rubber washer goes to the inside of the tank under the flush valve which gets screwed on with the large plastic nut on the bottom side of the tank. Then the foam gasket fits over the plastic nut which goes into the toilet bowl hole for the water to flow into the bowl. Tank needs to be removed from the toilet bowl.
Aug 31, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
How do you replace the flapper for a 1.6 gallon, two piece Jacuzzi toilet
http://www.ccowhirlpool.com/web-pdfs/Jacuzzi_Whirlpool_Bath/Toiletry.pdf
The top link has diagrams of internal working's of different types of Jacuzzi toilets. Most of them have a tab's on the over flow tube that the flapper will fit on. Shut water off and flush tank to get most of the water out and take a look on how the old one is connected. And replace with a new one. Check out the chain or plastic string which connect's flapper to handle to get proper adjustment for flushing toilet.
http://www.google.com/search?q=replacing+flapper&hl=en&sa=G&rlz=1T4GZAZ_enUS363US364&prmd=v&source=univ&tbs=vid:1&tbo=u&ei=S3AcTNrBGYL6lwfN1NmnDg&oi=video_result_group&ct=title&resnum=4&ved=0CCoQqwQwAw
This link will instruct you with video on how to replacing the flapper.
Jun 18, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Need to replace all the parts inside the tank of Jacuzzi toilet
Had a simular problum.
For about $130 you can have a 1.6 LF new in box and start saving water.
Hope this tip helps.
R/
David
Jan 22, 2010 | Jacuzzi Bath Maxima EL61 959 White...
I am looking to replace the part inside tank that lifts flapper
Remove the entire chain, and take it to a hardware store, or home center (Home depot or Lowes) and ask for a suitable replacement.
Or you could replace the entire flapper that comes with a chain, at any of the above named stores.
Dont forget to take the flapper with you...
Good luck
Feb 21, 2009 | Jacuzzi Bath Era BK37 959 White toilet...
Toilet not flushing properly
there are allot holes around rime inside they get clogged over time because water quality very hard to get there to clean best bet replace toilet
Dec 28, 2008 | Jacuzzi Bath Era BK37 959 White toilet...
Home Logo
262 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
