Question about Sega Genesis Console
Whats on the inside of a sega console then? - Sega Genesis Console
    President:
  • 894 Answers
whats on the inside of a sega console then? - images?q=tbn:and9gctpztfyxhc_jeftsyqyv7r8rs-aazzrhyaagaecxtlltpibcnj8iq Well this might show you then.
Posted on Jun 16, 2011
Cant get power on sega cd 2. hooked up with genesis 1 console. both ac adapters work and genesis works fine. don't see any fuse inside sega cd
the fuses are solid state fuses, one is a small white top surface fuse on the bottom of the board the other is a green "resistor" looking fuse. both are marked with Fxxx ( the x's are numbers) check them with a meter for continuity so you dont change a good one.
Oct 20, 2013 | Sega Mega-CD Console
My sega genesis has a clear picture but static sound can someone help?
Try an older TV set. I am not joking. It might very well be the case that newer TV sets/high-end TV systems can't handle the signals of the older video game consoles. Because the newr tv;s don't have the signal transfer inside of them to make the old consoles work so you could use the genesis av cables to hook up to a digital tv instead of the rf switch.
gen_av_cable_2_3_tmb.jpg&maxx=130&maxy=120gen_av_cable_v1_tmb.jpg&maxx=130&maxy=120
Mar 17, 2012 | Sega Genesis Console
Bought a Sega Genesis on ebay. It displays the games correctly but will not respond to the controller. The controller has been tested to work with another system. What could be causing this?
Its the controller ports inside of the system that controlls the controllers to function is broken or loose then and needs to be resoldered. I had a problem with my sega after i resoldered the 2nd controller port it worked again then.
Sep 09, 2011 | Sega Genesis Console
When i put a game in the sega it dosn't read the game and the screen goes green.
Well it might be a power supply issue or the grphics chip inside of the console is going bad and starting to wear out then.
Jan 14, 2011 | Sega Genesis 2 Console
Sega genesis isnt working...
Have you cleaned the Sega? What I mean is where the casset game goes. Push down the little flap, and there should be a little strip with contacts on the inside. Just clean it with a cotton swab and alcohol. And also, clean all your games also the same way.
Hope this helps.
May 09, 2009 | Sega Genesis Console
Sega not working no matter what.
Does it power up,,if its just not playing the games,, take some quetips and dip them in alcohol,,use it to clean inside the genesis where the games go in and clean the games with it,, if you have the sega cd addon system ,,also clean the place on the side where u connect the sega cd,, hope this helps,,i have 4 or 5 sega genesis,, and the sega cd system,,,thanks
Oct 05, 2008 | Sega Genesis Console
How to clean the contacts inside the Genesis.
Honestly, especially with those older consoles, I wouldnt trust any type of liquid with it.
Mar 10, 2008 | Sega Genesis Console
Sega console
If there is no response it sounds like there is a bad connection between console and controller. I would clean the connectors. If that doesn't work take the controller apart and make sure the wire is connected well to the board inside the controller. You can try to unconnect it and reconnect it. Clean the board inside, that might help.
Aug 24, 2007 | Sega Genesis Console
Sega Genesis Console Logo
27 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
