My screen is blue. says cable. i dont have cable and cant get the tv to do any chanel.
    Sergeant:
  • 261 Answers
What is the make and model of the television? If it has a HDTV off air decoder then you can try this....A little trick i learned years ago. Get a paper clip and bend it into an "L" position and then insert that into the very center of where the cable goes into and then scan for off air channels. You will know if this is working when it says it found "x" amount of channels as it is scanning thru the channels. Give that a try and see if that at least gives you a picture... IF that works then you can get off air signal HDTV for FREE. And you might want to invest in a HDTV OFF AIR ANTENNA.. For free tv. Let me know how that works for you and then we can go from there. Good luck and have a great afternoon. SINCERELY HDTV GURU JAY
Posted on Mar 15, 2011
I have a flat tv olevia 332 b-11 my problem is that that I have no idea where the antena goes and the screen is blue and I don't know how to program the local chanels because is no hole in the tv
Ifyou look at the rear of the TV, you will see a round thing with threads on it. That's the antenna connector. You will probably see ANT or ANT INN marked nearby.
Dec 21, 2012 | Televison & Video
TV is turned on-only see blue screen that says Video
if only see blue screen indicate no video signal, check the yellow cable.
Apr 13, 2010 | Sanyo DS13204 TV
My sony trinitron tv is off the normal chanel 3 an I cant get it back on there. I have AT&T CABLE my son touch the tv an switch the chanel. My problem is I dont have the orginal remote. An I have...
Hi, if you have a "menu" button on the front of the tv go into the menu & "auto-program" the channels, if your set does not have the menu button on the front you will have to call a local tv shop with the model number of your tv and they can order you one, gl, video-tek
May 18, 2009 | Sony Televison & Video
Digital channels have stopped working, only blue screen!
Try resetting the TV:
  1. Switch on TV and switch to any analogue channel.
  2. On the TV: Press and hold the MENU button.
  3. Menu screen will appear on the display.
  4. Do not release the MENU until the menu screen disappears.
  5. TV will go blank for about 60 seconds and then display initial set up screen.
  6. Follow the on-screen prompts to re-tune the TV.
If this does not work then the problem is likely to be a loose ribbon cable or main small signals board inside the TV.
May 17, 2009 | Philips 37PFL5332D 37 in. LCD Television
Blue screen on tv
DID YOU TRY TO CHANGE THE CHANEL MANUALLY? OR CHECK THE INPUT BUTTON
May 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Dont no how t put it in HD
as long as you are hooking the cable or satilight box with an HDMI or componant cables(componant=Blue-red -green-red white)you dont have to do anything the tv will automatically show in HD, as long as your on an HD chanel
Jan 09, 2009 | Televison & Video
Blue screen
the problem of ur tv is tuner,try to solder the tuner
Sep 28, 2008 | JVC AV-27120 27" TV
Tuning TV onto AV chanel
How do I get the TV screen back to an AV chanel?
I cant get a slide show to view on the TV screen.
Apr 01, 2008 | Televison & Video
When i hook up dvd/ps2 i cant get it to show up on the screen
You have to have a remote control to set the chanel to 00. You cannot set the chanel to 00 with the chanel buttons on the front of the tv.
Jan 02, 2008 | RCA F20352SF TV
Mono setting?
What channel is it and when they tune in that channel, is the picture nice and clear or is it grainy and snowy before the screen goes blue? On some sets, if the signal is weak, the picture will go blue. This is called Blue Screen and is there so you do not see very poor, grainy and snowy pictures. Some sets will have an option in the menu to turn the blue screen off.
Aug 27, 2007 | RCA 24F512T 24" TV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
