Question about XM Radio XM Direct 2 Mini-Tuner Car Kit for XM Ready Aftermarket Radios Satellite
After I shut my truck ('05 chevy silverado) off and let it sit for 4 or more hours, my head unit says searching but does not find the xm adapter. if I unhook the fuse (from the xm direct adapter) then hook it back up, I have xm again. If I connect the power wire from the adapter to the switched power in the truck, I get signal but it resets the presets every time. I've already replaced the xm direct adapter and still the problem persists. I don't believe it's the head unit(Alpine cda-105) because every other memory function works properly. Is this something Im just going to have to deal with sence it is a universal adapter and the manufacture can't accomidate all makes or is there something I'm missing?
5 Suggested Answers
SOURCE: Alpine CDA-9855 won't recognize SIR-ALP1
I also had this problem. I had to go through the menu into the setup and then into tuner settings. There should be an option called tuner area. If you set it to area 1 it should start working. For some reason the sirius only works on area one. Hope that solces your problem
Posted on Jan 06, 2008
SOURCE: XM Direct 2
On the adapter cable if there is a separate cable for power connect the positive directly to battery power as opposed to ignition. The memory resides on the xmdirect2 module not on the head unit.
Posted on Mar 29, 2009
SOURCE: kenwood firmware for the xm direct CNP2000UC
http://mobile.audiovox.com/xmdirect/xmdirect2.html
Posted on Jun 06, 2009
tss-radio
  • 62 Answers
SOURCE: xm check atenna connection
If you are getting the same "check antenna" message with two different antennas, it is likely that the tuner itself is the problem. You can get just the mini tuner here:
http://www.tss-radio.com/products/xm-mini-tuner-replacement-home-dock
As far as the two plug connection, there are adapters available. Its likely a dual fakra connection, though I don't know for sure. At any rate, this is one adapter available. (I would call to confirm)
http://www.tss-radio.com/products/sirius-dual-to-single-antenna-adapter
Posted on Jun 29, 2012
I have a 94 chevy Silverado 5.7l with 4l60 transmission will a 97 chevy Silverado 4l60 work even if the speed sender is on different side and made different on transmission
Chevrolet / GMC / GEO Transmission Look Up Table
www.autorepairmanuals.biz/page/372807
Blazer, 1993-, 4L60-E. Blazer, 1994 - Up, 6.5L V8 Turbo Diesel, 4L80-E. BLAZER/TRAIL BLAZER/JIMMY, 1995-2003, 4 SP RWD/4X4, L4 2.2L L6 4.2L V6 4.3L ...
Transmission Applications - GM Automatic Transmissions
www.gmautomatictransmissions.com/transmission_applications.php
Avalanche, 2001-06, V8 5.3L 5.7L 6.0L, 4 Spd RWD/4X4, 4L60E. Avalanche, 2004-06... Camaro, 1994-05, V6 3.4L 3.8L, 4 Spd RWD, 4L60E. Camaro .... Monte Carlo, 1997-05, V6 3.8L (W/S.C.), 4 Spd FWD, 4T65E. Monte Carlo ... Silverado, Sierra,1500-3500, 1995-06, V8 4.8L 5.0L 5.3L, 4 Spd RWD/4X4, 4L60E. Silverado ...
4L60E Transmission Rebuilt ' eBay
Dec 27, 2015 | Cars & Trucks
Done an alt. change after doing a tune up truck ran than just shut down now will not start
Truck ' DIY Forums
www.diyforums.net/truck-2418/
My 2003 chevy Silverado V6 truck turns over but will not start..it acts lik. ... iS IT HARD TO REMOVE AN OIL PAN ON A 4.3 VORTEC S-10 PICK UP TRUCK ...silverado 1500 ext. cab. my problem is while driving on the highway my truck ... mytruck then took off the terminal to see if the alternator was work and now i have no .
Chevy Silverado and GMC Sierra Stalling Problem - Car Forums at ...
forums.edmunds.com > GMC > GMC Sierra 1500
Apr 4, 2008 - 30 posts - ‎22 authors
I can feel the truck hesitate or bump while changing lanes on the highway (70-80 MPH) if it ... Now it idles ... My truck has a 4.3 with automatic. trucks runs great after about a hour it .... It will idle and drive just fine, but will simply shut down. ... the not firing problem, but shuts off after it finally decides to start. Chevy Silverado and GMC Sierra Gasoline Engine ...
Jun 14, 2010
Chevy Blazer Fuel Pump and Pressure Regulator Problems
Mar 10, 2010
Chevy S10 - GMC S15 and Sonoma Stalling/Dying ...
Dec 14, 2007
Silverado starting problem...
Nov 15, 2007
More results from forums.edmunds.com
Dec 26, 2015 | 2004 Chevrolet Chevrolet Silverado 1500...
After running my 2000 chevy silverado 4x4 if it sits for about 30 min it dose not want start with out giveing it gas
It might be your core pack. Try getting that checked at the auto store. Or it could be a gunked up fuel injector.
Feb 27, 2013 | 1999 Chevrolet Silverado 1500
05 chevy silverado, spark plug order
Wilson;
I am guessing a 350 V8?
if si it is
1-8-4-3-6-5-7-2 Driver side front to rear 1-3-5-7 other side is front to rear 2-4-6-8
Mar 27, 2012 | 2005 Chevrolet Silverado 1500 2WD
How to hook up XM to aftermarket head unit
o dont need a converter,u should be able to hook your XM thru the IPOD input on radio u will need the cable thou
May 31, 2009 | Car Audio & Video
Bass hits, but quits.
you will need a larger ground wire also try bolting it down in a new location if you have to scrape away any paint to bolt it to metal
hope this helped
Mar 02, 2009 | Car Audio & Video
Bluetooth XM not meshing
does xm adapter have a pass thru port on it as in mine is sirius and i have radio changer output pluged up to the sirius unit then from sir changer output i have the bt100 plugged up and mine works great
Jan 06, 2009 | Kenwood KCA-BT100 Wireless Headset
XM Direct 2
Oct 04, 2008 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
Trying to install i-pod adapter CD-IB100
go on crutchfield. It's called a passthrough which will allow you to have both items.
Dec 29, 2007 | Car Audio & Video
XM Radio XM Direct 2 Mini-Tuner Car Kit for XM Ready Aftermarket Radios  Satellite Logo
78 people viewed this question
Top XM Radio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a XM Radio Audio Player and Recorder Expert? Answer questions, earn points and help others
