Question about Maytag Neptune MAH5500B Front Load Washer
We can do an entire load of wash and when finished often the items in the middle are dry not even wet , we do not over load weve been using this for eight years and this started in the last 6 mos?????????????? whats up
    Brigadier General:
  • 6,277 Answers
This sounds as if not enough water is fed in for any cycle, wash or rinse. I suspect the water level sensing is not doing its job properly and that there has been only a little water in the drum each time for the past 6 months!
Sorry but you will need to call a service engineer as there is nothing that we could do remotely to help ;-0(
Good luck,
John C
Posted on Mar 15, 2011
I have tried just using the gentle dry for little items but they still come out wet. What I am doing wrong?
gentle dry is usually for extra small loads with delicate items such as silk ect. most clothes are cotton or polyester which just require a normal dry. this also depends on your dryer. refer to your manual on what your gentle dry can handle. if you do not still have your manual if you could provide a model number i could pull up the info for you.
Jul 13, 2016 | Washing Machines
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
Will not spin the clothes dry it's seem it is not balanced ?
You may have One wet heavy item (one sweatshirt or one bath towel) that is not evenly dispersed within the wash tub, and this will prevent the machine from reaching and completing the spin cycle.
Jul 21, 2014 | Maytag Neptune MAH5500B Front Load Washer
The dishwasher dose not get hot at all and when it has finished washing every thing is still wet
  • Well, the dishes inside the dishwasher will still be wet unless you use a dry cycle at the end of the washing cycle. Not all dishwashers have this option. Even though mine does I rarely use it as the dishes will dry on their own in two hours.Saves a little money. Even when washing on a normal cycle the dishwasher itself should not get hot. It may blow a little steam out the front vent. Hope this helps.
Regards, Tony
Jun 08, 2011 | Dishwashers
The automatic delicate drying cycle does not dry
The delicate cycle is for damp, not wet delicate items. It is more warm air then hot and will not dry wet items forsay. If you have delicate items that need more drying try putting them inside a pillow case and tying the end closed long with a higher setting. Works great with stuffed toys too
Feb 24, 2010 | Whirlpool LTE5243D Top Load Stacked...
Some clothes not clean or even completely wet after wash cycle finished
Ebay item number 200262803398 is a cheap PDF service manual for this model.
prem
Oct 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
HOTPOINT BWD129 CAN'T GET IT TO TURN BACK ON WHEN IT FAILED HALF WAY THROUGH A HOT WASH
check if you splash a lot of water specially at the center of the unit. there is this water sensor that would turn it off once this sensor is wet.
do you have any error codes?
tnx 4 using fixya,
drcool
Oct 06, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wd440 heating but not drying
yes, the dryer is pants im afraid. weve had ours going on 4 years & it has broke down every 6-10months - seriously! the dryer will leave clothes hot & steamy but when hung up for 1/4hr they r dry! _ Hotpoint advised us that he machine is esigned his way - but dont believe a word from their corporate b***hit mouths!
Aug 11, 2008 | Hotpoint Aquarius WD640 Front Load...
Neff washer/drier
soap drawer is just a slide fit - give it a good yank. for the dryer, take the top off and there should be a mainifold across the top with stats mounted on it. one or two may be re-settable stats ie have a little button in the middle which press to reset. if this works, cause of stat popping out is usually a lint blockage in the dryer manifold
Apr 28, 2007 | Neff V4380X0 Front Load Washer / Dryer
Maytag Neptune MAH5500B Front Load Washer Logo
21 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
