Question about HP Pavilion F1703 17" LCD Monitor
Monitor dead I just checked my computer and the monitor was off. After unplugging it for awhile and plugging it back on, the blue light turns on for less than a second and nothing. Ive done it about 40 times now and have got the same results. Is there something wrong with the cord/adapter or is the monitor done?
  • 37 Answers
The monitor has a bad circuit shorting out it's power supply. Could also be faulty electrolytic capacitors in the power supply.
Good luck.
Posted on Aug 26, 2008
The monitor does not power up. no power light comes on, there is nothing that shows up on the screen. All cables are well connected and yes the power switch is on.
check by changing the power cord if this does not solve the problem the fault is in the power of the monitor better call technician or take it to the service centre
Aug 02, 2011 | Samsung SyncMaster 940UX LCD Monitor 19...
My screen turns black upon startup. For awhile when my screen was on, it would flicker on and off but remain on. Now, the only time I can see the screen is when I unplug vga cable then plug back in but...
You mention a VGA cable so I assume its a stand alone monitor for a desktop PC.
It can be repaired,this fault is usually indicative of a capacitor, maybe two or three bursting in the
a) Power supply.
b) Back Lighter.
or
C) Inverter.
As its 6 years old, I would suggest replacing would be the most cost effective resolution.
Jun 10, 2011 | Gateway Computers & Internet
Have a Pavilion Desktop HP with upgrade from vista to windows 7 ultimate. Turned the power on and no blue light and no monitor yet the fans were running. Computer monitor said no input and went back to...
Your computer has served you bravely and is now wounded in battle.
arfoob43 either your power supply has died or you computer mainboard is toast.
See my published guide dealing with this matter it is entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
To actually fix it requires a bit of electronics skill. First you will have to diagnose the component that has failed and then solder in the replacement component.
Take care
damnor01
Apr 15, 2011 | HP Pavilion a6750f PC PC Desktop
No pitcure, but the power light is on
My first bet is on a dead power-inverter. Get it replaced if you can still see a very darkened picture. OR... if there's no picture at all, call warranty support or take it to a repair shop. Also, if you're fine with electronics, I can guide you step-by-step to diagnose the fault.
Mar 06, 2011 | Samsung SyncMaster 910MP 19" LCD Monitor
Monitor will not stay on
First of all check your mains lead make sure it is not fused. then check the lead from the monitor to the computer make sure it is connected ok then check your video card You can try connecting the monitor to another computer to see if it works on that one
May 01, 2010 | LG 22" FLATRON LCD Monitor
I shut down my computer at night. When I come back the next morning the computer is off and the monitor is in standby with an orange power light (so far so good). When I turn the computer on, the monitor...
that blue light show and error or faulty problem internally or there a problem with in the connection or computer but first check the makers website or manual for troubleshooting.
Dec 13, 2009 | LG L1932TQ LCD Monitor
Acer X223W monito won;t wake up after sleep.
I have a dual monitor system, both are the x223w. Same problem but only on the second monitor. Backlight shuts off.On/off light stays blue. I have to turn off the monitor and turn it back on. I returned it and Acer could not find any problem so I got it back. No problem for awhile and now a few times over the past couple days. Not good...
Aug 10, 2009 | Acer 22" X223w LCD Monitor
Damn Blinking!
You can buy a used monitor about $50.00 in the US. or You should take the monitor to an authorized repairman. IT IS NOT recommended to fiddle by banging a defective unit WHICH has HIGH voltage running through it.
Jul 26, 2009 | HP Vs17 17" LCD Flat Panel Monitor
HP w2007 monitor will not turn on. When unplugged and re-plugged (power cord) the little blue light in the on-off button flashes once, then nothing. The blue light in the pwer button remains unlit, and...
The only troubleshooting step I can offer here, is unplug it, and press the power button down for about 15-20 seconds, to flush any trickle power remaining in the unit. Then plug it back in, hook it up and try turning it on again. If this solves it, great! If it doesn't though, then I would check either with HP directly or with your place of purchase to see if your issue can be covered under limited/extended warranty. If you are out of warranty though, LCD repairs tend to jump pretty high, and usually end up being more than what the monitor is worth, so it may be more economical to replace it at that stage.
May 10, 2009 | HP W2007 LCD Monitor
Sceptre X7g Monitor Flashing Red & Blue Lights. Blank Screen
i fixed this problem by unplugging the monitor, unplugging the video cables. Then hold down the power button while plugging it back in. Release power button and then press power button for on. It worked then. I got the icon for no signal, i plugged back in my monitors. Sceptre X9W
Sep 11, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
53 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
