Question about E-Machines eMachines Desktop PC
Where can i find a digram so i can put the wiring back the way it should be i have replaced the power supply but still i get nothing so i am thinking i must have some thing put in the wrong place. it is a modle W3653
    President:
  • 1,851 Answers
Go to www.emachines.com - search for 'diagrans' it will show up or just call AND ask then to mail you a schematic.
Posted on Mar 15, 2011
Wiring digram for power windows for a 2005 dodge stratus
In the engine compartment relay box, check 10A FUSE 14 which provides power to 30A FUSIBLE LINK 5.
Sep 15, 2016 | Dodge 2005 Stratus SXT
No power to radio pontiac grand am 2004
Do you know how to do automotive electrical testing ? Following wiring diagrams , checking B+ voltage at different points along the circuit . Did you use a interface module with the aftermarket radio ? The GM radio is hooked to the class 2 serial data network . Your best bet , take it to a qualified installer .
Apr 04, 2017 | 2004 Pontiac Grand Am
I stopped using my acer aspire l100 when I got a laptop. I wanted to use it again so the other day I hooked it up and I got nothing. There is no light on the computer and the power will not switch on. My...
First things first if you put the wrong RAM in it would still turn on but it would beep at you. If the front switch isn't sticking I doubt it is that. You can test it by following the wires from the switch to the motherboard, disconnect the wires and use a flat screw driver to make contact between the two pins or if more pins make contact between the + and -, if it turns on then yeah it's the switch. The small 3v battery is only used to save your BIOS settings.
Lastly, yes it most likely is the power supply. I'd really just start with the power supply as it is the most common component to go out.
Comment back if you need more assistance.
Aug 25, 2011 | Acer Aspire L100 PC Desktop
Pc will not turn on, blue light flashes on power button and fans turn for a sec. then nothing
The power pack has failed and needs to be replaced, they are easy to change, take the side panel of the tower, there should be 2-3 screws at the back holding in place, the power supply will be in the top corner with a bunch of wires coming out of it, unplug all wires from the motherboard and peripherals inside the pc ensuring you write down where each one goes.
There are 4 screws holding the power supply in place, they are placed at the back of the tower, near the top, undo the screws and the power supply should just pull out of the case, take the power supply to your local store and get a replacement, normally they are priced between ?15-50, put the new one back in the same way and try to boot the pc, it should now be fine.
hope this helps.
Aug 20, 2010 | Computers & Internet
Wires came out of my pin block on the back of my Kenwood kvt-715dvd. would like a digram to put them back in.
hi,
although this is not wiring diagram of your gadget but still this will help you little bit. or atleast you will get some idea about wiring so by further thinking you can solve your problem...
http://www.the12volt.com/installbay/forum_posts.asp~TID~74637~PN~1 .... http://www.the12volt.com/caraudio/caraudio.asp
Hope this has helped you... Thanks...
Jul 21, 2010 | Kenwood KVT-715DVD Car DVD Player
My dur therm air conditioner fan turns on but compresor does not
it could be the (LP) low pressure switch which would shut the unit down
Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
Psu blinking green light, no power
I read all the solutions, followed the manufacturers instructions exactly, replaced the cmos battery and nothing solved the problem (blinking light on PSU after a power failure and no startup at all). I had ascertained that the PSU was intact by disconnecting all the PSU connections to drives and motherboard at which time the PSU LED stopped blinking and was constantly on.
Just before throwing my computer away I decided to follow the instructions listed by "guest" to unplug the power to the motherboard and then with the power supply back on to plug the cables back into the motherboard. No only did sparks not fly, but it started up and ran perfectly! Many thanks to "guest."
Oct 31, 2007 | HP Compaq Presario SR1230NX (PJ518AA) PC...
Beep code and nothing on monitor
You may be correct about it being a power supply but you need to know the manufacturer of the mother board and check out their website for error codes. Please list your motherboard name and model. A power supply is cheap enough to test your system and you can return it if it does not work. They are real easy to replace too. Unplug your system and leave unplugged for half hour before opening your system. There are 2- 4 screws on the back upper part of your computer and a harness connector that the power to the motherboard goes. It's a good idea to bring in your old power supply to match it with a new one.
Oct 26, 2007 | Computers & Internet
E-Machines eMachines Desktop PC Logo
60 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
