Question about Smeg 24 in. DWI612 Built-in Dishwasher
DWI612C wash cycle runs on and on and on. Believing to be a problem with water heating I tried putting a couple large pan fulls of boiling water into machine during wash cycle and this did move it on from wash to rinse. How do I replace the heating element I cant see it it is not in the dish washing compartment? I dont want to call out a repair agent as one can probably buy a new machine for what that will cost. Thank you.
  • 52 Answers
SOURCE: My Smeg dishwasher DWF 64 SSE won't go onto rinse or dry
Easy one first try this to see if it helps
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Posted on Jan 29, 2008
  • 8 Answers
SOURCE: bosch dishwasher SHU66C02UC - Rinse Agent issue
Does soap draw open at right time?
Same solenoid opens soap draw as injects rinse aid.
Turn up hardness counter ?
Any blockages in dispenser unit its-self?
OTHERWISE CALL IN THE PROFFESIONALS !
Posted on Apr 25, 2008
codfish124
  • 36 Answers
SOURCE: Dishwashing detergent in rinse aid compartment
not good there is no way to drain it out. you might be able to take the door apart and take off the rinse aid reservoir and clean it out
Posted on Dec 20, 2008
SOURCE: Dishwasher leaks when jet dry rinse is added everytime.
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Posted on Feb 11, 2009
  • 51 Answers
SOURCE: dishes not clean, water spots
You might have really really hard water which would leave mineral deposits on your dishes,,, something could also be blocking the wash arm from rotating, or the water from shooting out of the wash arm which would result in very poor cleaning results
Posted on Mar 13, 2009
Soap leaves behind after wash cycle
Could be using too much soap, soap that's too old will clump and not dissolve completely. If your soap is clumpy and very dry, dissolve it completely with boiling water in a pan, then put it in the unit.
Jun 15, 2014 | Maytag Neptune FAV6800AW Top Load Washer
U-line service for 2010
In order to prevent any confusion or potential damage, just empty the freezer, turn the power off, and leave open for a couple of hours.
To expedite the process, place a couple of large pans with boiling water inside the freezer and shut the doors.
Remember, unplug or turn the frig off in the process.
May 19, 2014 | U-Line Refrigerators
How do you install a heater core for a1991 Mazda Navajo
remove dash assembly try to back flush first or drain cooling system put water back in add cascade dish washing soap and drive a couple days if heater starts woreking better turn heat on high run engine open drain with a hose nozel on high and a large pan under drain flush all water out with engine running refill system with heat on high and vehicle running if heat still weak remove heater hoses the top should be the return line put a hose about 8 inces long on both out lets run the bottom hose to a high area where it can be suspended put a funnel in upper hose poor clr into hose until it comes out top of lower hose let set for hour and a half then flush out with water into a clear jug flush water vthrough upper hose then if u have air compressor have a 6 inch hose attatched to upper pipe and blow out core into same jug until the jug has clean and clear water refill cooling system and drive if heat doesnt work at first put engine under a load to release residule deposits in heater core and it should start flowing
Apr 01, 2012 | Cars & Trucks
I want to serve three kinds of soup in my Rival roaster oven with the three pans. Must I put water in the large pan that the three small pans rest in? Must i put water between the large pan and the...
Your Owner's Guide for the Rival 18 qt. Roaster Oven with Buffet Server can be found here:
http://www.rivalproducts.com/manuals/MANUALS/RO180BR-C_43_18972586.PDF
Refer to page 6 for complete instructions.
You do not add water or anything below the roasting pan. You fill your roasting pan 1/2 to 3/4 full with water, place in the empty serving dishes, then preheat at 350 degrees until hot (about 1/2 hour).
Then fill the serving dishes and reduce heat to 250 degrees. You may need to adjust heat and more hot water if necessary.
Feb 21, 2011 | Rival 18 Qt Roaster Oven with Buffet...
Machine keeps stopping and showing fo5
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Oct 22, 2009 | Washing Machines
Kenmore Ultra Wash 3 (6651694193) stuck in wash cycle
There should be 2 thermostatic switches in the heater area. They are just simple bi-metallic "button" switches.
One will trip at the correct temperature - and tell the programmer to advance now the water is hot enough. The other will cause a shut-down if the water is over heated.
It is the first one you need to replace - I wouldn't bother testing it.
Obviously - disconnect everything before opening up (I have to say this) and only if competent to carry out a repair.
However - you don't know which is which?
To test them. Remove one, put inside an empty can , and put 1" of water in a pan onto boil. Test continuity with a meter when cold - and when sitting in boiling water.
Turn off heat, and see which trips first. That is the over-temperatue one. When a little cooler, the other should trip. This low setting one is likely the faulty one - so will not trip or contacts will be faulty.
These are available online from various appliance retailers.
Aug 15, 2009 | Dishwashers
Bleach and softener is going in with it's cycle
Pour a pot of boiling hot water through the softener side. Try this a couple times. Let me know how it works.
May 29, 2009 | Kenmore 43042 Front Load Washer
Cleaning the "showerhead" on a gaggia expresso machine
Take it off, and heat up a pan of boiling hot water and add 1 cup of vinegar to two cups of boiling water. Once the water starts to boil, shut off the stove, and put the head in the pan, cover the pan and let it sit for about 30 minutes to 1 hour. Afterwards wash it really well then you will be good to go. The head does twist off
May 16, 2009 | Gaggia Classic Espresso Machine
Smeg 24 in. DWI612 Built-in Dishwasher Logo
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
