Question about Bakers Pride Convection Oven Electric 63 and one quarter""
I have a bakers pride 1/2 size convection oven model# x 300 L code B88 serial# 2680 its old but needs elements,9900watts 208volts (it has been working on 240volts 1ph) .Am told parts no longer available though one suplier sugested if I could get the original part # they may be able to cross reference it and see if it is available. Can you help? Thanks,James.
Hi. If you want, i'm selling my oven. It is the same model that you're searching for. If you want email me. nicolas.masy@gmail.com
Posted on Apr 25, 2017
  • 125 Answers
SOURCE: bakers pride pizza oven not lighting
Hello. Usually this problem is related to the pilot being dirty, and not heating the bulb for the safety device properly/hot enough to fully open the valve. If you have a general purpose mini torch you can heat the metal bulb near the pilot with it, if this is the problem, the safety will open, and the main burner will come on. CAREFUL, you are not on/around the main burner, as it will allow gas to come on to the main burner, and if your pilot is not working properly, might not light the gas. Get the pilot cleaned and adjusted.
or... :) I know... your safety has failed, allowing gas to the pilot, but internally is not opening, this requires replacement. Last though, it could be your thermostat, its last in line, and would require replacement. The safety, and the thermostat are mechanical valves, open or closed depending on its function.
If you have a more current type, they will have a combination valve, and thermopile/thermocouple that are electromechanical, your thermostat at this point can be either mechanical, or electromechanical. This system has a few more possible causes for your symptom.
You can tell which you have by how you light the pilot, have a red button on the front of the unit, by the on/off valve? this is the first type.
Have to open a small door to access a knob, turn it to pilot, and hold in? this is the latter type.
ask if you need more help.
Hope that helps, and thank you.
Posted on Feb 22, 2009
  • 81 Answers
SOURCE: pilot light still going out
If this oven has a "stack" (where the hot gases & heat vent to your hood) air could be blowing down the stack affecting the pilot. Simple test, Bic lighter lit at the top of the stack in the middle of the opening. If the flame is being sucked down the stack, then you have air blowing the pilot out. How old is the thermocouple on this unit ? Pilot flame heats this up to send a signal to your main gas valve to open up so the burners light. A weak t-couple could be your problem. Hope this helps
Posted on Jul 25, 2009
jyackle5
  • 8197 Answers
SOURCE: Baker's Pride P-44s P44s
You can get parts here at this link.
http://www.tmeinc.biz/xbpride.htm
Good luck and please rate
Posted on Sep 24, 2009
  • 417 Answers
SOURCE: bakers pride electric deck ovens aprox 10 yrs old
It depends on the ampere rating, you will not normally be able to get a single phase supply in the UK at more than 100 amps total.
If the total oven rating is not more than 60 amps you may be ok.
Conversion would involve altering the wiring in the oven which may be costly and not worthwhile on a 10 year old oven.
Posted on Jan 06, 2010
  • 193 Answers
SOURCE: I have a bakers pride
Several things to check. First be sure the pilot light flame is directly striking the thermocouple. It is a pencil sized rod that is next to the pilot light. Sometimes people reduce the size of the pilot flame to save gas. You may need to increase the pilot flame. Follow the small gas line from the pilot flame back to the gas valve. There is a screw where the small pilot gas line goes into the valve. Remove the screw and then deep in the hole is a tiny screw that can only be reached by a tiny flat blade screw driver. Turn the screw counter clockwise to increase the pilot flame. The thermocouple needs to be red hot to work properly. The second item to check is to see if there are any breezes that occasionally blow through the kitchen. Sometimes the hood fan will draw air under the ovens and actually blow the pilot flame out. Same fix, increase the flame. You may also experience low gas pressure to the appliance during heavy usage. You would need a manometer gauge to check for proper gas pressure. In short, if the oven goes out during your busiest time when everything gas powered is on, the oven may be starved for gas.
Posted on Sep 09, 2010
Oven wont light, pilot is lite but the burners wont ignight
Bakers Pride used several different safety valves over the years. If your oven has a pilot valve that has a beige know that you hold in and turn to light the pilot, then after it lights you need to turn the beige know another half round to the "on" setting. If you push in a red button to light the pilot, it may not be getting enough heat on the thermocouple where the pilot flame should be heating it up. Be sure the main gas valve on the front of the oven is turned to the on position also. On some models the pilot will light with the main gas valve in the off position. If you look at the pilot flame while it is burning, make sure that it is hitting the pencil sized thermopile enough to make it glow red. If not bend it slightly to improve the heating.
Sep 07, 2010 | Bakers Pride Y-600 Gas Single Oven
Need a wiring schematic for a Bakers Pride p44 double pizza oven.
hi..there is color coding on the wires..BLACK WIRE is the live wire(wire #1) which should be connected on top of the terminal supply of your oven (if vertically positioned) and sometimes to the leftmost right(horizontally positioned),then the RED WIRE to the bottom (vertically positioned),or rightmost part (horizontally positioned) and the WHITE WIRE is at the center(both horizontally/vertically positioned0 and the GREEN wire must be connected to the grounding of the unit just below/beside the terminal supply of your oven..hope this helps
Apr 15, 2010 | Bakers Pride P-44S Oven
Bakers pride electric deck ovens aprox 10 yrs old
Jan 06, 2010 | Bakers Pride CO11-G2 Gas Double Oven
One of our ovens has part of the bottom pealing off inside the oven. Is there a fix for this?
Unplug the unit, remove the conveyor belt and replace the bottom of the oven with a Stainless Plate from Bakers Pride or from a local machine shop
Nov 30, 2009 | Bakers Pride APC-18-1 Electric Single Oven
Sep 24, 2009 | Bakers Pride P-44S Oven
Pilot light still going out
Jul 23, 2009 | Bakers Pride FC-616 Gas Single Oven
Bottom oven pilot light goes out intermitantly.
adjust the flame so that it stays on the thremal couple and keeps it hot if it is off by 1/4 inch it will not work.
Jul 22, 2009 | Bakers Pride FC-616 Gas Single Oven
Pizza oven bricks need to be changed
You must use a long crowe bar lift the brick and pull it out need the size of the brick to let you know how much and where to get it if it a 2inch thick they are no longer sold most lilkely it 1 1/2 inch
Oct 16, 2008 | Bakers Pride BAK-DS805 Gas Single Oven
Door on my bakers pride y600 pizza oven
Theses are called 3/4 door busings and should be changed when you replace the left side door rod (complete)and are available from any parts depot that sells bakers pride parts
Jan 20, 2008 | Bakers Pride BAK-DS805 Gas Single Oven
Bakers Pride Convection Oven Electric 63 and one quarter"" Logo
143 people viewed this question
Top Bakers Pride Ovens Experts
ashburton
paulcarew
Dan Webster
Dan Webster
Are you a Bakers Pride Oven Expert? Answer questions, earn points and help others
