Question about Panasonic KXDT343 Phone
Missed call light is on, how do you clear it?
2004 Lincoln LS 3.0 multiple miss fire issue.
A bad injector also shake the pcv and see if you hear it
you should have been had a check engine light with those will turn on check engine light how old is the fuel filter
May 04, 2017 | Lincoln LS Cars & Trucks
Check engine lite on .pull codes p404. Also has lite miss on easy acceleration from stop.Need to pass state emissions test
P0404 EGR circuit range just replace the EGR,the light miss is from your egr pintle being stuck open. either you clear the code with a scan tool or if you dont have one it will take 2 trip of no emission problem for the ECM to clear the check engine light,
May 05, 2011 | Chevrolet 1500 Cars & Trucks
Blinking error light CH will not let machine turn on
side door of copier is open just close it properly .if error stills just check by pressing start key what is sub code if 00 developer unit is missing if 01toner catridge is missing .just check all connectors of developer unit and toner unit.code will bi removed
Jan 20, 2009 | Sharp AL 1631 Copier
Miss on # 3 cylinder
Check the plug and plug wire to #3, if they are ok test the fuel injector and test the compression on that cylinder.
Nov 09, 2008 | 2002 Ford Mustang
97 dodge neon
make sure your not getting oil down into the holes where plugs go this can mess with the wires.Is it actually skipping?
Sep 10, 2008 | 1997 Dodge Neon
Panasonic KXDT343   Phone Logo
172 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
