Question about Desa International White Wireless Plug In Door Chime
I have a desa TR-0081-BX wired door bell. When you push the button it only gives a short chime . If you hold the button down it goes thru a 8 note chime what can be done to fix this. There is only one button and it is wired to the front door contacts on the chime. Thank you Bill Dunn
There is a little "diode" that should have been provided as part of the unit...it's a little wire with a B-B-sized circuit in the middle that has to be connected to the push-button at the door. This "extends" the circuit from the button to the chime unit for the full 8-notes. Hopefully you still have that part (I just about threw out mine before I read the instruction manual thoroughly. My diode just "shorted" after I power-washed my house...and I am in search of that particular part. I contacted Heath Zenith...hopefully they will give me a solution on how to get only that part. In any case, you need that diode to get the chime to play correctly.
Posted on Mar 27, 2011
  • joshmaggie Dec 11, 2013
    RadioShack 2761103 diode on back of button
    or do a search for a 1n4001-50v-1a diode
Setting the codes for the door chime
Presuming that you are asking how to set codes for the Desa International door chime, here's a solution:
There are two components of the Desa door chime --- the ringer assembly and the door button. Inside each component is a set of eight pairs of pins and several square-ish plastic jumpers. To set a code, you must push jumpers onto the pair of pins for each of three different numbers. (You may find that you have more than three jumpers. If so, the others are spares which you can tell because they will only be covering one of the two pins in a pair.) Whatever three numbers you choose, the ringer and button must match exactly. 5-6-7 seems to be the default set-up as delivered from the factory. This is only a problem if anyone else in the neighborhood also has a Desa chime with this setting. If you use pin 8, the ring changes from a two-tone chime to a 16-note sequence.
Aug 26, 2014 | Desa International White Wireless Plug In...
Id like to change song on my doorbell Dimango model 4330 r cd chime reciever
The webpage http://www.dimango.com/dc-cd-quality-doorbells.htm
shows:
Wireless Doorbell CD Quality Door Chime
Model RC4300
No longer do you need a wired door chime or traditional doorbell with brass tubing to get amazing, rich sound. Our Battery Operated Door Chime from Dimango has CD quality sound while remaining completely wireless...
  • Plays three selectable sounds
    1. Ding Dong
    2. Dong
    3. Westminster Chime Click To Hear Sound!
  • Set sound conveniently at button
It seems that there is a button on the receiver/speaker. Try press once and see if the sound changes.
Nov 27, 2013 | Desa International White Wireless Plug In...
What is the diode size for an IQ America wired doorbell DW2403a
pODUCT OVERviewThe IQ America Designer Series Wired/Wireless Door Chime features a glass and pewter cover for a contemporary look, and it can be used as a wireless or wired chime for your convenience.
  • Big Ben 8-note, Big Ben 2-note, traditional 8-note, traditional 2-note, traditional 1-note, birthday song, Merry Christmas, Auld Lang Syne, Beethoven and U.S. national anthem sound options
  • Up to 300 ft. wireless transmission range
  • Adjustable volume control
  • Wired or wireless design (wireless use requires a wireless push button, sold separately)
  • Glass and pewter cover
  • Easily add any IQ America wireless pushbutton (not included)
  • Doorbell pushbutton not included
  • MFG Model # : PC-5610
  • MFG Part # : PC-5610
Sep 14, 2013 | Desa International White Wireless Plug In...
I replaced old DH840E that stoped working with same model same hook up with front door only. When I push door bell it dongs once only. If I hold door bell button it goes through the west minister chime....
Some door chimes of this type are designed with dual capability so that pressing the front door button produces the full Westminster chime and pressing the back door button produces a single chime. Your wiring may have gotten reversed inadvertently during the changeover
Aug 17, 2013 | Robert Thomas Carlon Recordachime By...
I have a IQ America doorbell with 5 chimes and 5 tunes and the bell only plays a sorta gong which cannot even be heard How do I fix this problem so that it plays a chime/tune?
We had a similar problem with a wired doorbell. There is a diode in the doorbell itself that causes the chime to ring fully. If the diode is backwards, you get just a small tone and can only hear the full chime if you hold the button down. If this sounds like your problem, open up the doorbell at the button end (or have an electrician do it) and reverse the diode.
Nov 07, 2011 | Desa International White Wireless Plug In...
We purchased the Heath/Zenith TR-0081-BX Wired Door Bell. However, we can not get the chime to continuously play without holding the bell down for expended period of time. How can we fix this? I lost the...
Mar 16, 2011 | Garden
I have a desa DD100S wireless door chime but for some unknown reason the bell push is not working, I have tried replacing the battery but still unable to ring chime. The actual base unit is fine and...
Sandra, the contacts in bell push may need cleaning, as well as some minor readjustment of the contacts. Insects love to get into the bell push and can clogged it up. If you find that this doesn't solve the problem, Contact the Zenith Company 800-858-8501 to purchase a replacement.
Mar 09, 2011 | Desa International White Wireless Plug In...
I have two door chimes with the same frequemcy, but different codes. I need to place the chimes in different rooms as I am hard of hearing. How do I match both codes so that they ring at the same time when...
You need to change the pin configuration in both the remote buttons to match each other, (as well as the bell unit) just make sure they match on both bell units. Also, since one works just use that configuration and change the button pin configuration that does not work to the button that does on the other button unit.
Mar 03, 2009 | Desa International White Wireless Plug In...
Desa International White Wireless Plug In Door Chime Logo
1,322 people viewed this question
Top Desa International Home Security Experts
Steven R
Julian Pearson
Level 1 Expert
Halim Hartono
Halim Hartono
Are you a Desa International Home Security Expert? Answer questions, earn points and help others
