Hello, I am wondering what SEER rating my RUUD condenser unit is? Model # uafd 036-jas Serial # 4082 M3091 1291. I am looking to replace the system and the only unit I can find is a 13 SEER and I need to know if that will work with the air handler.
  • 4 Answers
SOURCE: CAN YOU TAKE A NEW
Thats a big negative
Posted on Apr 15, 2008
  • 1073 Answers
SOURCE: we installed a 4 ton
you have a missmatched system, for it to work try removing the orfice on the high side txv it is not allowing the evaperator coil to fill with refrigerant properly coleman and intertherm dont like each other since they control a large market in the manufactured housing heating and cooling units electricaly connecting the componets together no issue prefromance sometimes is the issue hope this helps
Posted on May 08, 2008
  • 340 Answers
SOURCE: Looking for a Ruud 10 SEER condenser cabinet to replace
nope ive been down that road nothing new try one of your local contractors they may have some thing used for cheap. Tom
Posted on Jun 28, 2009
  • 582 Answers
SOURCE: ruud UAFD 03 JAS AIR CONDITIONER
THE MFD SHOULD BE ON THE SIDE OF THE OLD CAPACITOR IF NOT THE MOTOR IS RATED FOR 3 MFD THATS WHAT YOU NEED
Posted on Aug 19, 2009
heatman101
  • 43501 Answers
SOURCE: How to reset a ruud air conditioner 13 seer series
You can try to turn the power off and then on again at the disconnect for the outdoor unit...
However the problem is likely more complicated then that...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 25, 2010
What are the tons of a RUUD AC HANDLER MODEL UBHA-17J11 SO SFFA SERIAL NUMBER MOO500 03485 and what type of CONDENSER & TONS CAN IT HANDUE WITHOUT PROBLEMS?
You can find the tonnage in the model number which increases by increments of 12, so if the model number is 24 =2 tons. Model number on your a/handler is 17. Thats a ton and a half. Really should match the evap and condenser for the best efficiency. ...
Sep 24, 2015 | Ruud Heating & Cooling
I don't have a problem with my product...im trying to find out how many watts do my product use. Model #uamb-036jaz serial #6263f040410617
Brand: RUUD Manufacturer: RHEEM Model Number: UAMB-036J* Condenser Type: air-cooled Condenser Coil Model Number: RCGA-36A2 System Configuration: split-system air conditioner Cooling Capacity: 34,200 BTUHs per hour Efficiency: 12 SEER
10.5 EER Electrical Service: Single-phase Electrical Input: 3,272 watts per hour Voltage: 230 and 208
Jul 01, 2011 | Ruud UAMB Air Conditioner
How do you find the seer rating on a condenser is it in the model # or Serial #?
Hello my name is Heath it will be my pleasure to assist you. The model number will give you the seer number if its olde between 5 and 10 years its probably 7 to 9 seer if its newer then its probably 10 to 13 seer.
May 22, 2010 | Heating & Cooling
Going to replace hvac system. Don't know what
According to the model number it is a 2 ton or 24,000 BTU unit. It is very important that you change the indoor coil as well as the outdoor section, due to it being a 10 SEER unit, and the new basic systems are 13 SEER, the old coil cannot handle the higher SEER ratings.
Rheem and Ruud are the same equipment, just 1 number different on the model number.
I hope this has helped, please rate the new guy :)
Please contact me if I can be of any further help to you.
Have a great day!
Sincerely,
Paul Gibson
Apr 04, 2010 | Ruud Matching Split Air Conditioner
I need to know the seer number for an air handler. I'd
On the air handler take the top panel off, look to the left on the inside, this will give you general information on the unit on a stampede plate. This will
give you the date of manufactuer as well.
On the outdoor unit, there is a stamped plate on the
condensing unit. Should have year of manufactuer, it
should also say how many pounds of freon should be
in it. The Model number is what you need to know
to find out how big it is.
024=24,000 BTU= 2ton unit
030=30,000 BTU=2 1/2ton
036=36,000 BTU=3ton
040=40,000BTU= 3 1/2ton
and so on.
My guess is that it is an older unit and since I have
been installling units since 1995 I have only known
any older units to be at least a 10 SEER and no more.
Feb 16, 2010 | Heating & Cooling
Can you tell me the manufacture year and seer rating of a condensing unit with serial # 4397e02306?
Carrier puts this info or their data plates and have for a few years now. If it's not on this one, it's pretty old. If over 12 years, it will be around an 8 SEER or less. I you can supply a model number of the condenser I will be glad to look it up in my data base.
Oct 19, 2009 | Carrier Heating & Cooling
Ruud UAFD 03 JAS AIR CONDITIONER
Aug 18, 2009 | Heating & Cooling
Jun 28, 2009 | Heating & Cooling
Capacitor unable to read what size
If it's the condenser fan motor cap then look at the label on the fan motor for the size usally 3/5 mfd.
If its the compressor run cap then check the top of the compressor or the info. plate/sticker on the unit for the size of the cap. Let me know if you have any other questions.
Phil
Apr 10, 2009 | Ruud UBHC Air Conditioner
Model #uacc 030jas - BTU/H and SEER
that is a three ton unit and most likely a 10 seer rated seer rating are posted 6 months in cool and 6 months in heat to get the number on the unit if you are more interested in heating rating of heat pumps the aher or annual heating efficiency rating is of the most importance in this category the unit posted very well
Nov 14, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
80 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
