Question about Sharp Televison & Video
My opc led burns when i turn on the tv - Sharp Televison & Video
  • Sharp Master
  • 736 Answers
You can leave it on and enjoy the tv self adjustment feature or turn it off by pressing menu. Navigating down to opc and pressing enter. Navigating to off. Pressing enter and then pressing menu.
Posted on Mar 15, 2011
Sharp aquos tv opc and power led flashing
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 01, 2016 | Sharp LC-52D62U 52 in. LCD HDTV
My tv doesnt show any images and the panel has the light of fopc on
Common problems on Sharp LCD tvs as tv it is agings,tv Power LED and OPC LED,LEDS lights flashes happen to mine Sharp tv many times and i had it two years,do this many times,tries to turn on the tv.By trying pushes the power button the remote again if OPC LED and power LED,LEDS lights flashes together.Everytimes the OPC LED and power LED lights flashes,just push the power switch on the tv remote and wait for the tv main Tuner signal board to kick in the backlight to light up tv to work.Have to do this like three or four times before the power supply board to kick it in to make Tuner signal to work.If u require to this more than 5 or 6 times the main tv Tuner signal board it is shorting out and beyond trying to kick in by the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
May 31, 2011 | Sharp LC-32SB24U 32 in. LCD TV
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
The power light is blinking and the tv wont turn on
I have two 46" Sharp Aquos tvs,so i know this tv model well.Tv have Power and OPC LED lights flashes?Yes.Tries tv unplug,replug it back like about an hour later.The tv should be working again.This problems happen to Sharp tv alots,later on,should it happen again,just tries push the power switch on the remote again and wait the backlight will light up and tv will work again,some it will go back to Power and OPC LED lights flashes again,just push power switch again and wait,sometimes,u have to do this three or four tines to make the tv Tuner signal board to take to make the tv to work again.If u have to pushes power switches 10 or 11 times and wait and Power and OPC LED flashes lights again,it time to replace the tv Tuner signal board,that the board,where that take the tv incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Jan 29, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My sharp Aquos LCD TV LC37D44U while watching TV suddenly witched off. Both the power led light and the OPC led light together started to flash twice, and then only the OPC led light three times, then...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem......
Jan 27, 2011 | Televison & Video
MY Sharp LC46D62U wont turn on
Power and OPC LED lights flashes?Common on Sharp LCD tv.Tv is still useable.Tv have Tuner signal board problems.Every times Power and OPC LED lights flashes.Just push the remote power button again and wait.Sometimes Power and OPC LED light will flashes require push power again wait again Power and OPC will flashes two or three time push power button and wait.Must do this two or three time before the backlight will light up and tv work.
Jan 07, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Tv wont turn on used it for two months and one day it turns on then the power led light flashes and the opc led light ...
This tv still under warrenty?Yes take ur warrenty repair.This problems very common on Sharp LCD tvs.I have one too.This tv have a Tuner signal board problems.But this tv still use able.Just push power button again after the POWER and OPC flashes.POWER and OPC some will flashes again and wait just push the power button again and wait.Sometimes have to push power buttons and wait power button push out of three or four times power button push POWER and OPC flashes.Than tv will work again.
Jan 06, 2011 | Sharp LC-52D64U 52 in. LCD HDTV
I have a sharp 37" lcd tv,model # lc37sb24u. no pix or sound, power lite comes on about 10 seconds then power and opc lites alternate on and off. thanks RON
This problems very common in Sharp LCD tvs.The Tuner signal board have problems,every times the power LED,OPC LED lites up,just push the power button on again,wait see if the LCD backlight lite up and works,not the Power lite and the OPC lite LEDS flashes again.You,just have to push the power button again,sometimes u have to push the power button at least 6 or 7 times to get the Power LED stable,and then LCD backlight,come on than the tv work.Not sure,but if the Power and OPC lites keep flashing,after u pushes the power button at lest 10 or 12 times,and the LCD backlight dosen't come on and the tv don't work.I think,it time to change the Tuner board is completely dead.I have a Sharp LCD tv, I do this everytimes pushing the power button at least 3 or 4 than the power LED stable,and the LCD backlight come on than the tv work.Not a plaw in the power supply like those capacitors in many LCD models tvs,but some included Sharp Tvs is the Tuner signal board is not very good in design,use the tv awhile the Tuner signal board have problems recieving the power to it Tuner board components.
Apr 15, 2010 | Sharp LC37SB24U 37 in. LCD TV
THE TV IS CUTTING OFF BY ITSELF AND THE OPC LIGHT IS BLINKING
This problems very common on Sharp Tv.Do ur tv LED power light turn on solid first.Few mins,than LED,OPC flahes.Power LED,OPC flashes,push power button again,do this at leat 5 or 6 times somtimes the backlight will come back on and work.The power LED,OPC light flashes,turn off/on more than 5 or 6 times don't work.Ur Tuner signal board is dead,must replaced.
Mar 30, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Blinking power and opc leds on front of unit
From the information you have provided failed capacitors in the power supply is likely causing the problem. The safety circuitry shuts the TV set down when it detects a problem. This model of TV has over 2,000 parts which include millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Integrated circuits and transistors can go bad. This can cause other components to become defective, which can have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. The only way to know for sure what is causing the problem, which parts that are no longer within factory specs and for proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment. The repair should cost about $250 if carried into a TV repair shop. A small TV repair shop will often charge less than a large repair facility.
Jun 04, 2009 | Philips 50PFP5332D 50 in. Plasma...
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
