Question about Casio FX-9750GPlus Calculator
I need to clear the screen What resets the screen How do I get the calculator to degree mode instead of radian
  • Casio Master
  • 7,993 Answers
To clear the screen press the AC/ON button (All Clear). To setup angle unit in degree rather than radian get the calculator in RUN screen. Press SHIFT MENU to enter SetUp. You see a screen similar to the following one.
Use down arrow key to bring cursor to the line Angle. Once the line is highlighted you will see three tabs at the bottom of the screen. Press the F1 key, under the TAB deg (degree). Press EXE to quit the setup screen
Posted on Mar 19, 2011
Ti-nspire cx CAS gives answer in degrees even though it is in radians mode.
When you set some configuration parameter you must scroll down the setup until you reach the OK button. Press the OK button to validate.
Oct 09, 2014 | Texas Instruments TI-Nspire CX CAS...
How do I get to degree mode instead of radian
Hit the DRG key to the right of the pi key. It should cycle from radians to gradians to degrees. A "D" should appear at the top of your screen rather than the current "R".
Good luck.
Paul
Apr 01, 2014 | Sharp el-531x scientific calculator
My calculator is not computing sin^-1 or cos^-1 correctly, I put sin^-1(0.184) in and it came out with 10.60283... when I should be getting 1.39. HALP?
When the angle unit is in radians
sin^-1(0.184)=0.1850543940 radians
When angle unit is in degrees
sin^-1(0.185)=10.60283581
Your calculator is calculating the functions correctly)
In the following screen captures the sine of the values is calculated with the unit specified inside the formula (degree symbol and radian symbol are inserted to show you the unit). In the last calculation the value of the sine is practically 0.184
Remember that when angle is in radians, for very small angles (less than 10 degrees), sin(x) and tan (x) are about equal to the value of the angle in radians
Mar 25, 2014 | Casio FX-115ES Scientific Calculator
What does DEG on screen of TI-30Xa mean
It means your calculator is set to degrees mode. Angles can be measured using three different units: degrees (360 degrees in a circle), radians (2pi radians in a circle), or grads (400 grads in a circle).
Pressing the DRG key cycles through the three modes. No matter which mode you select, one of the annunciators will appear on the screen to indicate the current mode.
Dec 07, 2013 | Texas Instruments TI-30XA Calculator
How do I get from degrees to radians? For some reason my TI-84 will not convert degrees to radians.
Press the [MODE] key to access the mode comfiguration screen .
Set angle unit to to radian (see above)
Enter angle value in Decimal degrees only, use the [2nd][ANGLE] key sequence to have access to the degree symbol. The degree symbol must imperatively appear at the end of the angle value.
Here are some examples
If you use angle values in DMS, it will not be converted to radians, but to decimal degrees.
If you omit the degree symbol there is no conversion.
A general formula is Pi radians =180 degrees
Feb 10, 2010 | Texas Instruments TI-84 Plus Calculator
How do i enter 35 degrees 20 minutes into my TI-81 calculator
As far as I know, the TI-81 doesn't have a degree-minute-second entry mode the later TIs have. But to answer your question, you can always do it as:
 35 + 20 / 60
followed by ENTER if needed.
If you're in Radian mode instead of Degree mode, you'd have to follow up with MATH 6 to specify degrees instead of radians.
Sep 29, 2009 | Texas Instruments TI-81 Calculator
Don't know how to change it from degrees to radian mode
if you press the |mode| button (at the top right of the calculator) until you see Deg Rad Gra on the screen (I believe 3 presses of the mode button) and just hit the number below the rad option on the display. This will permanently change it to radian mode until you repeat this step, or clear the memory.
There is also a way to change to radian mode for just one operation if you will be mostly using degrees for example
at the bottom there is a DRG> as a shifted function. I would just recommend changing it in the way I initially outlined as there is less room for error when making calculations.
Apr 22, 2009 | Casio FX-300MS Calculator
Ti84 "Sin/Cosin/Tan" Problem...
The problem is that you have the mode in radians. You want them in degrees. This is a simple fix. Press mode and then go down to radians and select degrees
Jun 24, 2008 | Texas Instruments TI-84 Plus Calculator
Degrees to radians
Press "2ND" "MODE" to enter the mode screen. Press down-arrow twice to get to the angular mode. Press right-arrow or left-arrow to highlight the desired angular mode, then press "ENTER" to select it. Exit the mode screen by pressing "2ND" "QUIT"
Oct 15, 2007 | Texas Instruments TI-86 Calculator
TI-89
Angle mode, Degree/radian setting, Chapter 2, pg 53 (pg70 of 623) Tan instructions pg 510 (appendix A pg 527 of 623) Here's your manual, download this file: http://www.ti-89.org/uploads/ti-89-manual.pdf
Jun 07, 2007 | Texas Instruments TI-89 Calculator
Casio FX-9750GPlus Calculator Logo
112 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
