Samsung hls5087w tv comes on but shuts back off in a few sec
  • toddwalker36 Mar 23, 2011
    thanks is there a way to check the bulb the tv is geting a good picture but then shuts right back off so to explain i press the power butten the lamp light will blink the tv then comes on with good pic and sound and turns right back off then all 3 led lights blink
    Sergeant:
  • 261 Answers
It could be one of 3 problems. 1st and easiest, is to check and see if the lamp has taken a dive!
2nd you need to check the color wheel....To achieve this just listen for a whirling noise as the lamp is trying to turn on! If you hear a faint dentist type drill sound color wheel most likely is good. If it is loud or vibrating or you saw the screen change color just before it shut off... It is most likely the color wheel. The Power Supply Ballast could be bad. Most likely it is fine though. If lamp turns on this is not your problem... Good luck and let me know what u find... Sincerely HDTV GURU JAY.
Posted on Mar 15, 2011
  • Jay Henderson
    Jay Henderson Mar 23, 2011
    I still think your lamp is bad. Replace the lamp... If you give me the part # off the lamp i might just have one in stock....502-773-7969 and ask for Jay
Samsung HLS5087W picture keeps turning off. Sometimes it happens after a couple of hours and then every 10 minutes after that. recently changed both bulb and color wheel. Tv only 6 years old.
I would first check the lamp is properly seated and was it a Samsung or a generic brand? Also not indicated is does sound remain or not.
Dec 05, 2012 | Samsung HL-S5087W DLP TV
Lamp comes on but without picture
The color wheel is the likely problem here.
Nov 27, 2012 | Samsung HL-S5087W 50" HDTV
My Samsung HLS5087W keeps turning off by itself.
need to replace the lamp to correct this issue
Dec 17, 2010 | Samsung HL-S5087W DLP TV
Samsung 50 inch DLP has power will not turn on
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs,It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator, it could be time to replace the lamp.Note lamp sometimes doesnt look bad when it's bad.The lamp you need is BP9601472A you can find it here http://www.discount-merchant.com/Samsung-HLM437W1X-OEM-Replacement-LAMP-BULB-p/samsung-hls5087w-lamp-sm.htm?Click=48173.Have a blessed one!
Apr 29, 2010 | Samsung Televison & Video
TV KEEP SHUTTING OFF
If your unit is about 6 years old, probably. I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which explains the problem, how to fix it and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the great rating!!!
hardrocko
Apr 27, 2010 | Samsung HL-S5086W 50" HDTV
HLS5087W DLP Samsung Fan problem
Replace it if fan to Lamp stops running this will fix problem Call Mats 1-800-628-1118
Sep 16, 2009 | Samsung HL-S5087W DLP TV
When turning on the TV, I hear a banging/grinding sound.
If you hear a grinding,whirling,spining or buzzing sound, that sounds to me like the COLOR WHEEL,the reason for that is because your color wheel spins at 5,000 rpms(revolution per minute) and something that modifies the balance of the disc can cause different things,Unfortionatelly the only way to check that the color wheel is working properlyis you need to check it out physically
I did some research and I found the color wheel at DM;http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm?CLICK=52978
Please keep us posted.
Jun 14, 2009 | Samsung HL-S5087W DLP TV
Darkerning picture
Please replace Lamp in TV and lamp replacement procedure is written in instruction manual if you want to do it yourself.
Feb 04, 2009 | Samsung HL-S5087W DLP TV
Mitsubishi WS-65313 - Will not turn on
The most common failure are the two convergence integrated circuits part # 267P173010. The two pico fuses may be open as well, which come from the power supply and provide +24 volts and -24 volts.
Feb 15, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Electro Med Services...
