Question about Craftsman 17026 Wet/Dry Vacuum
Cant locate model number on older 16 gal 2.5 peak hp wet/dry vac. i need a filter
4 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: 177611 wet/dry vac
Either you aren't getting the top on correctly so it will latch, or there maybe a problem with the latches. You should have a one year warranty on this, take it back to Sears and have them look at it.
Posted on Jan 15, 2008
shastalaker7
  • 1515 Answers
SOURCE: Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Posted on Jan 23, 2010
bugoy31
  • 1238 Answers
SOURCE: I was using my Craftsman
Good day!
Try to see the motor and the carbon brush that connected to it..
This are the step on how to open or remove the cover of the vacuum to reveal the motor.
  1. Take off the top panel.
  2. Loosening all screws that you will see inside that top panel.
  3. After that, the top cover of the vacuum release and the image of the motor reveal.
  4. Now try to look at the motor and remove it to the unit by unscrewing it.
  5. Next, try to spin it manually using your 2 fingers and hold the plate then spin it.If the plate is hard to spin,the motor is need to re-align.
  6. To re-align the motor you have to loosen the screws at the 4 corners then release the rotor then back again.
  7. After that,clean the bushing of motor and the rotor and apply the motor oil for lubrication.Then re-install it and tighten the screws on the 4 corners while you re-align the rotor.
  8. Use a rubber mallet to align the rotor,hit the body of the motor while you tighten the 4 corners screws.
  9. After that spin the plate again to test the alignment,if the plate spin it smoothly.the alignment is OK.
  10. After that you have to test the resistance of the motor to make sure that the carbon brush is contact to the armature of the rotor.Use a multimeter (range in ohms) then point the test probe directly to the carbon brush wire.It should have not more than 25 ohms depends on the horse power of the motor.
  11. When the reading is open the contact of the carbon brush is reaching the armature of the rotor.Replace the carbon brush.
If you accomplish all of the steps above and the you found a defective parts.Test the vacuum by powering it ON.
Thank you very much and wish you luck.
Posted on May 02, 2011
I have a wet/vac model 2010a 1..0 peak hp do i put the gray filter on to sick up water or to dry vac
The filter is only for dry use. When you are picking up water etc with it, don't use any filters. They get ruined.
Apr 02, 2017 | Filter Vacuums
I ran over the cord to the vac with my lawn mower ,I need to replace the damaged cord with a new one. How do I remove the old cord?
You need to remove the screws that are in the location of where the wire goes into the vacuum. Then you will see a cord grip and connectors for the wires.
May 13, 2016 | Craftsman 2.5 gal, 1.75 Peak HP Portable...
How to replace the power cord?
Follow cord to where it goes on mower, then connect the wires the same way you took them off. but be sure to turn power off!!
Wet vac wont turn on
That Model of Shop vac often has on/off switch failure.
Dec 02, 2013 | Craftsman 20 gal, 6.5 Peak HP Wet/Dry Vac
Need filter for craftsman6hp. 16 gal shop vac model 113.177060
They're availabe at Sears and Kmart. Lowes and Home Depot also have filters that will work.
Dec 27, 2012 | Craftsman 17765 Canister Wet/Dry Vacuum
Trying to vacum and it starts to blow
There are two outlets on a shop vac one to blow and the other to vacum.
Dec 13, 2012 | Craftsman 12 gal 5.0 peak hp Wet/Dry Vac -...
Genie 400PC 16 gal shop vac but can't find filters
If you need paper filters, you can easily use a bag filter cut in half, and have less dust clouds than the original filter. Remember to use the lock ring. Generic ShopVac mini's have the same filter in foam.
Mar 11, 2010 | Genie Company GV150 Wet/Dry Vacuum
Sincerely,
Shastalaker7
Jan 23, 2010 | Craftsman 17765 Canister Wet/Dry Vacuum
Moto Brushes Problem... Who could help?
where can i fine moter brushes for my ridgid 5.25 hp 16 gal. wet dry vac.
Oct 02, 2008 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Craftsman 17026 Wet/Dry Vacuum Logo
Top Craftsman Vacuums Experts
downhille
Andrew Taylor
Andrew Taylor
Are you a Craftsman Vacuum Expert? Answer questions, earn points and help others
