Question about Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304)
Am not able to connect to the wireless with max signal strength.
  • Kasper Jensen
    Kasper Jensen Mar 15, 2011
    What kind or error do you get?
  • Belkin Master
  • 7,733 Answers
There is a great article at Working with Windows Wireless Networks
If you need more help post back! Thumbs and testimonial are welcome!
Posted on Mar 16, 2011
Itouch can't see my network
Not that I am aware of , but you signal strength will degrade if all the devices are on and using at once. Also your ISP MAY "throttle" your service/signal with high data usage. That said, Your iTouch and xBox, in the setting , wireless, the iTouch should see the signal, Is the wireless turned on? It's discoverable? If your wirell has a Password, has a setup box on the iTouch asked for the password? Use the Manuals for the devices to troubleshoot connections.
Dec 26, 2012 | Toshiba WRC 1000 Wireless...
Poor signal with WiFi on my zeepad
Having a wireless Internet signal in your home allows multiple devices to use the same Internet connection without having to run lengths of Ethernet cable to each device. Given that the wireless network is transmitted over the air, the consistency of your Internet connection depends on the strength of the wireless signal. If wireless signal strength is not strong enough to give you a consistent Internet connection, there are a few simple steps for finding the problem and improving your signal strength.
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home. Hope this helps.
b>
Dec 13, 2012 | Computers & Internet
Unable to stream novie sites with my linksys wireless-g router
Check the connection (signal) strength of your wireless connection in the status area of the task bar in Windows. Also, hovering the mouse over the wireless connection should reveal the connection speed. 54mbps is the highest you can expect on a wireless connection, which is generally OK for streaming video..Any less of a signal strength/connect speed will likely not be adequate for streaming video.
A poor signal strength is usually because of too much distance or too many walls between the router and the computer.
Hope that's helpful.
Jan 15, 2011 | Linksys Wireless-G WRT54G Router
The wireless network works intermittently.
and that is the problem with wireless. Wire runs 10 to 100 times faster and is 100% reliable. If you must wireless ... you might get better service if you go to 802.11B (older technology)
May 02, 2010 | U.S. Robotics MAXg(USR9108) Wireless...
My icon says I only have 80% signal strength, is
80% is a good signal strength....but if you want to increase the signal strength, then you need to move the wireless router to a very ventilated area, also the router should be placed atleast 5 feet away from other electronic devices like, modem, ups, microwave ovens,refrigerators etc.... also there should be a line of sight between the router and the wi-fi adapter... but in order to connect to a wireless network 25% of signal strength is enough....
Apr 17, 2010 | Belkin Computers & Internet
Low signal strength
Having many users connected to a single WAP (wireless access point) will not affect the signal strength. It will however, affect the speeds each user is capable of.
Most Linksys routers have a homepage address of 192.168.1.1 - Enter this in your web browser.
From there you will be able to find wireless settings and enable either a password or a WEP key for security.
If you found this helpful please leave feedback.
Feb 05, 2010 | Linksys Wireless-G WRT54G Router
Constantly locks up and loses connection under moderate traffic(3 users max) never recovers only solution available is to reset
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arid welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply)
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Nov 18, 2009 | D-Link DSL 500 (DSL-500) Router
When I go into other rooms I can't connect to router
How is the signal strength? Check and make sure the antennas are not loose. Is your house the old style concrete? Sometimes thick block or concrete walls are tough for the wireless signal to get through. They do make larger antennas or signal boosters for wireless routers. You may need to install one of these to boost signal strength. Also is it wireless B,G,or N? Wireless B has a very weak signal while wireless N has a very strong signal. Sometimes the router settings can be changed to adjust the signal strength and may be set too low also.
Sep 05, 2009 | Linksys Wireless-G WRT54G Router
Dell inspiron 6000 connects to the wireless modem but does not keep the connection
Check the connection signal strength, if the signal is low move the wireless unit to a better height to improve signal strength
Sep 04, 2009 | Dell Inspiron 6000 Notebook
Slow wireless connection
802.11b standard runs at 11Mbps. If you can only get 1Mbps from the router, you need to check your signal strength and your network card. If your wireless NIC in the laptop is only 802.11, you will max out at up to 2Mbps.
Mar 19, 2009 | Linksys Wireless-N WRT150N Router
Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
