Question about Whirlpool AWM8143 Front Load Washer
I have this written in my machine F06 what is that meanning
  • 668 Answers
The F06 code will indicate a drive motor tachometer error.This means the control is unable to properly detect motor speed and the machine will shut down. If the failure occurs during high-speed spin, the door will unlock after 3 minutes.
The error code F06 is likely a loose connection in the harness between the motor and the (MCU) or between the (MCU) and the (CCU). It could also be the tachometer circuit in the motor or an intermittent internal component connection within the (MCU). Since the (CCU) has already been replaced, the failure is likely a loose harness connection or the (MCU). I recommend calling a service technician to check the connection.
Hope this helps.
Shane
Posted on Mar 15, 2011
2 Suggested Answers
richardsimpl
  • 230 Answers
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Thank you for writing to fix ya.
Best regards Richard
Posted on Dec 12, 2009
What is error code F06
The "F06" fault code indicates a drive motor error. This means the control is unable to properly detect motor speed and the machine will shut down.
Mar 17, 2016 | Whirlpool Duet GHW9150P Front Load Washer
Washer error F06 E01
The error codes F6 E1 for Maytag Maxima 6000 front load washer means that the MCU AND CCU are not communicating. You need to check the wiring and plugs to make sure they have a good connection.
Feb 10, 2015 | Maytag Washing Machines
Indesit model iwe7125b problem f06 what does it means?
F06 : DOOR LOCK fails to close/open, door lock triac open/closed, frequency signal fault.
Action: Switch off the device. Disconnect power. Wait about 3 minutes. Open the door, then close, reconnect device to the network. Start device
Dado
Dec 20, 2014 | Indesit Washing Machines
What do these 2 codes mean on my maytag washer , F06 and E02?
The error code E02 and F06 on a Maytag washer could mean that the hot water solenoid went out. It could also mean that that the hot water control is not working properly.
Sep 23, 2014 | Maytag Washing Machines
Indesit 123 FAULT F06
I had this error and engineer said the meaning of the codes on the web are wrong as they don't like to disclose their real code meanings for pure protectionism reasons. F06 on IWD7145 is a burnt out door interlock IDC error. He replaced the part number C00085194 (replacement door interlock) and microritardator part number 085194 and it works ok now.
Sep 06, 2012 | Indesit W 123 Front Load Washer
F06
Hope this helps.
Shane
Mar 15, 2011 | Whirlpool Washing Machines
Often fails to execute spin cycle with error F06
THE F6 MEANS THE CONTROL IS NOT GETTING A READING FROM THE TACHOMETER ON THE MOTOR. CHECK THE CONNECTIONS FROM THE MOTOR TO THE MOTOR CONTROLLER,(THE CONTROL BOARD MOUNTED TO THE BASE).
Feb 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does the F06 code mean? My machine appears
The F06 code usually indicates a motor related problem. Some potential causes are loose/corroded connections of the wiring harness between the motor and the motor control unit (MCU) or between the motor control unit (MCU) and the central control unit (CCU). Sometimes this problem can be fixed by removing and reseating the electrical connections at these locations, but unfortunately I believe that your motor is shot. I say that because one of the ways to test the motor is to remove belt and turn pulley by hand. It should rotate freely. Then, run motor without belt (which you said you did). If the motor will run without the belt, but won't run under load (with the belt on), then this is a sign that the motor is bad. Really sorry for your trouble and I hope this helped. Best wishes.
Aug 24, 2009 | Kenmore Washing Machines
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool AWM 8023 -error F06
This erroe code means drive motor tackometer error Probably a bad motor or motor drive pc board or cable problems
May 23, 2007 | Whirlpool AWM8163 Front Load Washer
Whirlpool AWM8143 Front Load Washer Logo
393 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
