Question about GE Profile J2S968 Dual Fuel (Electric and Gas) Kitchen Range
M y dual fuel GE oven has no display showing it just went blank, but when you open the oven door the light goes on
I had the same problem as devlin50 with my GE duel fuel 918 model.
If you trip the circuit breaker off and leave for one minute before switching the power back on then hopefully the panel will be flashing, worked for me. Worth trying as replacement panel is not cheap, about $220 here in Canada.
TonyM
Posted on Sep 13, 2012
5 Suggested Answers
SOURCE: dual fuel kithen aid F 02
Welded element relay on the control board.
Brian
Posted on Apr 18, 2008
MNTECH
  • 1543 Answers
SOURCE: My broiler works - but the oven does not - GE Dual Fuel range
Thanks for providing the full model number, which allows us to look up part numbers and see exploded views of your product.
Most likely the bake ignitor is bad (even if it still glows, it may not draw enough amperage to allow the gas safety valve to open). One way you can test this on your model is to swap out the broil ignitor for the bake ignitor, as they are the same part number on your model. (part number WB13T10045) The broiler is normally used much less than the oven, so the part does not fail very often on the broiler. You will have to take the cover off the floor of the oven, then the flame spreader, to reach the burner area. The ignitor is the rectangular part at the back, on the side of the burner. (only two wires to deal with) (By the way, for future reference, your model number ends is SS, as in stainless steel, not a 55)
Posted on Jan 15, 2009
SOURCE: Ran Self Cleaning - Display went blank & Oven Door stayed locked
Solution #3 was very helpful. Took off the back panel and found the small black fuse. Removed the fuse and joined the two black wires, oven now turns on and oven door opens. Don't think it would be to safe to leave like this but going to get the part and put the fuse back in myself. Very easy to fix (just a million screws) so save yourself the expensive service charge!!!!
Posted on Apr 14, 2010
  • 9 Answers
SOURCE: The oven door cannot open. The self cleaning
Sounds like my problem two days ago. I have a Kitchen Aid free standing gas oven/range model
KGRI801PWH00. I read online that the thermo-fuse might've blown. I found the thermo-fuse after removing the rear panel. It was at the top/center. Mine is T-O-D (brand) 60F24; Westinghouse #8300802. I ordered mine from appliancepartspros.com for only $34.75; arrived in 36 hrs with regular shipping!! Easy to fix, sure beats several hundred $$ to repairman.
Don't bother to call Kitchen Aid - they'll just blow you off just like the hundreds of complaints said that I found online.
Posted on Jan 28, 2011
GE Model J S968S0F4SS. During bake display goes bake, oven turns off.
Oven Does Not Heat, But The Burners Heat - GE Appliances
products.geappliances.com/appliance/gea-support-search-content?...
Range - Oven Does Not Heat, But The Burners Heat. To minimize the ... Turn yourrange OFF and either remove the fuses or turn the breaker OFF. Then unplug ...
How To Fix Oven With Little or No Heat When Baking ...
Troubleshooting Why Your Oven Won't Heat ' PartSelect ...
? 2:54
https://www.youtube.com/watch?v=ketJHf3rrSk
Sep 14, 2011 - Uploaded by PartSelect
In this video you'll learn why your oven may not be heatingproperly. ... Neither the bake or broil elements ..
Oct 31, 2015 | GE Kitchen Ranges
Maytag cwe4800acb oven shuts off and display goes blank during heating
Display on maytag oven 8114p471-60 went blank - Fixya
www.fixya.com/.../t16018814-display_maytag_oven_8114p471_60_we...
Jan 20, 2013 - Stove top electric ignition still works fine, so there is power going to the .... maytag cwe4800acb oven shuts off and display goes blank during .
Oct 10, 2015 | Maytag CWE4800ACB 2.6 cu. ft. 24" Single...
I have a GE profile spacemaker xl 1800 microwave. I used it once this morning but then upon a second use some time after, there was nothing on the display, as if power was lost on it. I opened the door and...
The door switch may have become defective, cutting off power completely. When the oven restarts, it prompts you to set the clock just as it would if there had been a power interruption. It is possible that something has failed in the control logic and that probably will require attention from a repair technician.
Oct 31, 2013 | Microwave Ovens
Display turn off and the buttons are not clickable
The owner's manual is here. Be sure you have the clock set correctly.
You can also try a hard reset by unplugging the oven for a couple of minutes, plugging it back in, resetting the clock, and trying again.
Sep 04, 2012 | GE Microwave Ovens
My GE Advantium SCA1000HSS LED display is blank. The display just went out one day when I opened the microwave door. I can microwave using the "add 30 second button". Also the timer works if you...
Sounds as though you'll have to replace it again. There isn't much else it can be. Is there a chance that the house is not well grounded? Lighting and the such can do this.
given the cost of parts....Look to price shop a new one before fixing this one.
Jan 31, 2011 | GE Advantium SCA1001HSS Convection...
I was using the self cleaning function on my kitchenaid dual fuel range when about half way through the cycle the digital display went blank (i.e. no lights were on at all) and now 2 hours after the cycle...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Aug 19, 2010 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Display went blank during the self cleaning cycle
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
uiitu
Apr 29, 2009 | GE JTP28 Electric Double Oven
Self-cleaning error message f90
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 30, 2008 | Kenmore 79383 Dual Fuel (Electric and Gas)...
GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Feb 14, 2008 | GE Profile JGS968 Gas Kitchen Range
GE Profile J2S968 Dual Fuel (Electric and Gas) Kitchen Range Logo
253 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
