Question about Car Audio & Video
How do I remove the radio from my 2006 F250 there are no knobs and no holes to remove front plate what can I do to get it out.
    Sniper:
  • 50 Answers
Hello... sorry to hear you are having a problem. If your truck is a Superduty F-250, this is the procedure to remove your radio.
-Engage the parking brake
-For automatic transmission vehicle ONLY, insert key into the ignition and turn to the "on" position and depress the brake pedal (DO NOT START THE VEHICLE!), then place the shift lever into the lowest position.
-Lower the steering column all the way down
-Starting at the top edge of the dash trim bezel, carefully unclip and pull forward the dash trim bezel to access all the wire harness connectors attached to the features on the rear of the trim bezel.
-Carefully disconnect all the connectors on the back side of the dash trim bezel and remove the bezel.
-Remove the (4) 9/32 screws securing the radio to the sub-dash.
-Remove and disconnect the radio.
I hope this has helped! Good luck with your venture!!
20 year car audio/video installer
Bay manager
Posted on Mar 15, 2011
How do i remove the stock radio from my 1993 geo metro 4 door hatchback
here is the online fsm quote
  1. Disconnect the negative battery cable.
  2. Open the glove box. Remove the glove box open panel.
  3. Remove the air conditioning switch connector and heater control unit lever knobs. Pull heater control unit cover plate from instrument panel.
  4. Remove the gearshift control lever upper boot and center console.
  5. Remove the ashtray.
  6. Remove the instrument panel center trim bezel and radio face plate.
  7. Remove the screw from the back of the radio receiver and the screws from the front face of the radio.
  8. Remove the radio.
Sep 30, 2014 | 1993 Geo Metro
How do i remove the face plate on the 2006 ford expedition
Should be tiny holes for your flat head screwdriver to slide into and pop it off.
May 08, 2014 | 2006 Ford Expedition
Broken channel selector knob on cobra DX IV cb radio
Remove the outer knob, you may have to remove the front plate to get at the nut, you should now be able to tighten it up for ease of use.
May 05, 2012 | Cobra Radio Communications
Need instructions to remove the front rotor on F250 Four wheel drive truck - 2001 year
  1. Raise and support the vehicle; Remove the wheel and tire assembly;
  2. After removing the tire, remove the brake pads;
  3. Remove the disc brake caliper by removing the two disc brake caliper pin bolts. Lift the disc brake caliper from the disc brake caliper anchor plate (2B292). If necessary, remove the V-springs.
  4. Remove the pads. Remove the front disc brake caliper anchor plate stainless steel rail clips.
  5. Remove the rotor.
  6. Note: Perform this step for DRW vehicles. Remove the eight hub extender nuts, the hub plate and the rotor. Remove the eight hub plate nuts. Remove the hub plate. Remove the rotor.
Mar 02, 2011 | 2001 Ford F250 Super Duty Super Cab
How can i get behind the radio
the radio removal process does require a tool.If you look at the face of the radio,you will see a small hole in each corner,if you will take two large paper clips,bend them to where they are in a U shape,insert one clip on the left side of the face plate and the other on the right side of the face plate,and push into the holes at the same time.This will release the radio.
Feb 12, 2011 | 2006 Lincoln Zephyr
How do i remove the dash on my 06 f-250 to replace the radio.
if the radio has 4 holes one in each corner then you can get 2 tools to push into the 4 holes and it then is loose to pull it right out
Jan 05, 2011 | 2006 Ford F-250 Super Duty
How to remove the passenger side door panel on a Ford F250 super Duty.
Front Door Trim Panel Removal and Installation
NOTE: Left front door trim panel shown, right front door trim panel similar.
  1. Remove the exterior mirror mounting hole cover.
  1. If equipped, remove the window regulator handle.
    1. Position the window regulator handle cover aside.
    1. Remove the window regulator handle screw and regulator handle.
  1. If equipped, remove the window control switch plate.
    • Disconnect the window control switch electrical connectors and if equipped, the memory set switch electrical connector.
  1. If equipped, remove the front door trim panel reflector or the courtesy lamp lens.
  1. Remove the screws.
  1. ani_caut.gif CAUTION: Do not pull directly outward on front door trim panel, as damage will occur.
    NOTE: Remove the front door trim panel by pulling it straight upward.
    Lift and remove the front door trim panel.
  1. If equipped, twist the courtesy lamp connector one half turn and remove it from the front door trim panel.
  1. ani_caut.gif CAUTION: Insert the lower panel tabs first or they can break when installing the front door trim panel.
    To install, reverse the removal procedure.
Feb 27, 2010 | 2002 Ford F250 Super Duty SuperCab
Removal of radio 2006 e450
you should see 4 holes on the face plate find a nail that fits in the hole push them inand leave them in. if you released the catches the radio will slide out
Feb 01, 2010 | 2005 Ford E-Series
I need to install a direct fm box in my 04 ford f250. this item is needed to complete xm radio installation and eliminate static. Can i access the radio from below or do i have to remove the radio. If so...
the radio is removed with a special tool set, it can be bought at any good parts store like NAPA, it is made by KD tools, the two U shaped tools go into the holes on each side of the radio face plate and release the spring clips that hold the radio in, a 30 sencond job.
Oct 21, 2009 | 2004 Ford F250
Adding a remote USB port
I solved my own problem.1 I removed radio1.gif face 2 I removed back cover of radio face to expose USB solder joints.3 I drilled a hole in the back cover of radio face over solder joints 4 I drilled a hole in front cover of radio behind face plate and lined it up with hole in back cover of face plate.5 I cut the male plug off of a USB extension cord and ran it through factory notch on the back of radio,through drilled hole on front panel of radio, thruogh drilled hole on back cover of radio face and soldered wires to back side of USB plug in. Wire colors from top to bottom are Red, White, Green, Black. Solder sheild to any of the three larger solder joints next to these connections. Make sure wires are not touching any other connections. Put radio back together and add screw that locks face to radio. Face can no longer be removed with this wire added. Now I can plug in my 8gb memory stick1.gif,hide it under the dash and have a clean looking installation.
Jan 17, 2008 | Kenwood KDC-MP435U CD Player
Car Audio & Video Logo
131 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
