Question about Hitachi Televison & Video
My tv is a hitachi hd ready flat screen plasma tv and i am using universal remote control The tv was working fine until i swtiched it off and hit one of the buttons on the remote - possibily the av button. Now cannot get it to switch back on -has come on a couple of times with message saying no signal then it counts down 5 mintues and switches off again, Can anyone help
    Sergeant:
  • 261 Answers
What are u using for a signal source? Cable, Satellite, Over the air? My best guess is that you hit a wrong button such as the "source" button and the remote doesn't know what device you are wanting to opperate. Press volume up then down and see what light lights up?
If it is other than "TV" then you probably have the wrong device selected... Hope this helps... Sincerely HDTV GURU JAY
Posted on Mar 15, 2011
  • Anonymous Mar 18, 2011
    Thank you but it did not work. Did not light up on the tv when i used the volume button. I do not know what to do now. Will I have upset things with trying to put in the code again to get it started? The tv will just not switch on.
Hitachi 55hdt51m unable to move horizontal position its blacked out and will not let me adjust.can i reset TV back to factory settings?Do i need the original remote?
I have had the same problem with the same TV .You need the Hitachi cable that runs from TV to control box.No other able will work,Whenyu have his it will autmaticaly change over for you.
May 25, 2014 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
I HAVE BROKEN MY TV REMOTE FOR A BUSH HD READY DIGITAL PLASMA TELEVISION MODEL NUMBER PT42GY638EB
It will be very difficult to get a universal remote control for this set. You have to contact the authorized service center for Bush at your town, to buy a new original remote control.
Oct 16, 2012 | Westinghouse 32 Flat Screen 720p Hd Led...
How can I program my Comcast remote (Silver body - Red OK button) to work with my Hitachi CMP4201U monitor. I tried the 5 digit codes in the Comcast manual, but they don't work.
Here are the 9 codes that could match your universal remote to your Hitachi televisions;
10145, 11145, 10151, 11960, 10679, 10165, 10386, 11993, 10842
if these codes do not work you can search for your code by following your instruction manual.
here are the instructions to do a code search if for some reason they are missing from your manual.
Searching For Your Code
If your home entertainment device does not respond to the remote control after trying all of the codes listed for your brand, or if your brand is not listed at all, try searching for your code.
For example, after trying all of the codes for your TV, you still cannot get the remote control to operate your TV, then:
1. Turn on your TV.
2. On the remote control, press TV once. Then press and hold Setup until the TV key blinks twice, then release Setup.
3. Enter 9 - 9 - 1. The TV key will blink twice.
4. Press and release the digit 1. The TV key will blink twice.
Note: Substitute 1 with 0 if searching for a Cable code, 2 if searching for a DVD, VCR or PVR and 3 if searching for an Audio device
5. Press Power and aim the remote control at the TV and press CH + one or more times until the TV turns off.
NOTE: In the search mode, the remote control will send IR codes from its library to the selected device, starting with the most popular code first.
6. Press Setup once to lock in the code.The TV key will blink twice.
Jul 02, 2011 | Hitachi CMP4201U 42 in. HD-Ready Plasma...
I have a 2006 Hitachi Ultravision 42 inch plasma
plasma tv units use a lot of power ,well into the hundreds of watts 9 some big screens use up to 800 watts to work)
I suggest that you consider a new led unit which uses barely any power and you will get a remote with it
Jun 24, 2017 | Hitachi UltraVision 42HDS52 42 in....
All of a sudden my TV remotes do not work properly
Since you said that the remote that originally came with the television does not work either, it's most likely a problem with the IR sensor in your television.
To make sure that something more important with the television did not fail, the next time this occurs, walk up to the television and attempt to manually change the options using its controls.
Nov 19, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
I need a remote code for a hitachi tv
Here is the setup copde page http://universal.dev.efocus.nl/?pag=54. I didn't see that model remote listed but many times the remote manufacturer will use the same codes.... So look at other remote codes for Hitachi and see which one works.
MM85
Jul 24, 2008 | One For All URC-3021 Remote Control
HP Plasma TV Remote Control Codes
Not all universal remote or dedicated universal remotes will work with every combination of devices.
Call the tech support for your TiVO, and also for HP to see if they have an answer.
Jerry G.
Jul 12, 2008 | HP PE4240N 42 in. HD-Ready Plasma...
Control for my tv
If you are referring to the original remote control, I am an authorized Hitachi servicer and I can get it for you.
Dec 23, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Televison & Video Logo
149 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
