How to adjust time, as digital number style. - Computers & Internet
  • 27,725 Answers
If you are talking about the time on your computer click start control panel date and time you can make your adjustments to the date and time from there or right click on the date and time and you should see Adjust date and time internet time tab hope this helps you
Posted on Mar 15, 2011
I have an asus eee pc 4g (linux) and i want to change finnish languge to english. please help....
Changing Languages:
  1. Click on start
  2. Control panel
  3. Regional and language options, there you have the option to change the language to pretty much any language that you want
Sep 26, 2011 | ASUS Eee 4G Notebook
I haven't been able to put closed captioning on tv. I don't understand how and what code to use to get the closed captioning to work.
Enable Caption Using the Original Remote
  1. Press the [CCD] button to change the CCD mode.
  2. Using this button will set the Closed Caption mode when viewing a DTV or TV channel.
Enable Caption Using the TV Menu
  1. Open the Menu screen, select the third icon, in the middle, this is the Setup Menu.
  2. In the Setup Menu, choose the Caption option.
  3. Caption: There are three items in it - Analog Closed Caption, Digital Closed Caption and Digital Caption Style
  • Analog Closed Caption: CC1, CC2, CC3, CC4, TEXT1,TEXT2, TEXT3, TEXT4.
  • Digital Closed Caption: Service1, Service2, Service3, Service4, Service5, Service6.
  • Digital Caption Style: There are two Caption Styles. One is the automatic function set as the broadcaster, while the other is the custom style where you can adjust the font size, color, opacity, background color etc., accordingly.
Mar 10, 2011 | Element ELC-HS321 32 in. LCD TV
Dvi port specification
The DVI [Digital Visual Interface] is a standard for high-speed, high-resolution digital displays.
Below is a 24 Pin DVI Female connector seen at the Computer. The connector diagram and pin-out table show a DVI-I Digital and Analog [RGB]; 29 pins [modified D style] connector. A DVI-D Digital only connector with 24 pins [modified D style] looks about the same with out the 4 analog 'C' pins.
The DVI interface is found on a number of devices including TVs, Computers, Monitors, and Video cards.
Digital Visual Interface [DVI] was developed by the Digital Display Working Group (DDWG).
Note that the Digital Display Working Group disbanded around 2006, so don't expect an up-grade for DVI.
Digital Video Broadcasting/Digital Audio-Visual Council (DVB/DAVIC),
developed by DAVIC [inactive] and DVB [dvb.org].
Adopted by European Telecommunication Standards Institute (ETSI) and
International Telecommunication Union (ITU)
DVI has a number of different types connectors:
DVI-D Digital only connector; 24 pins [modified D style];
DVI-A Analog only; [modified D style], I don't think this is part of the standard
DFP Digital Flat Panel, Digital only connector. Pinout is listed on the DFP page
Styles of DVI Connectors
Jan 13, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
How to adjust time on g shock? Daylight savings time
http://world.casio.com/wat/download/en/manual/
There are so many applications use of the manual will be mandatory.
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
Mar 17, 2010 | Casio Watch style # GLX-5600-7 Watch for...
Konica 3135 with error code 45-1?
F45-1 shortly after power up.
Solution:
PROBABLE CAUSES:
1. The ADU driver board has failed, causing a loss of 24V DC to the lens drive motor (M7).
Disconnect CN151 from the main CB, if the copier powers up the ADU driver board is at fault. Verify that the side guide drive motor (M502), and the rear guide drive motor (M503) are not faulty. If necessary replace any faulty components, then the ADU driver board (p/n 12JA-9010).
2. The AC driver board is not providing 24V DC for the lens drive motor (M7) or the mirror drive motor (M8).
Replace the AC driver board (p/n 25JE-9016).
3. The pulley on the adjustable motor assembly cracks, causing no drive to the second V-frame.
Order the new-style adjustable motor assembly, (p/n 25BA-7404).
Note: Order the adjust drive (B) panel assembly (p/n 5400-6331) at the same time. The new motor will not mount to the old-style plate. Both parts must be replaced at the same time. Machines with serial number 25ME02578, and above have the new style parts.
4. There is a loose wire on the main CB.
Reseat CN30-B12 (mirror home) on the main CB. This signal is used to inform the DCDB when the mirror drive motor (M8) is in the home position.
this infotmation is very technical..hope you are a technician..check you optic wire and make sure the optic moves smoothly no binding .look for signs of wear on the optic cable..good luck
Jul 14, 2009 | Office Equipment & Supplies
Unlock att blackjack so i can put my tmobile sim in
Hi
On the AT&T Network, to unlock the Blackjack :
  • Power on without SIM
  • Type in #7465625*638*Unlock code# (8 digit unlock code*)
  • Device should say: “Network Lock Deactivated”
  • Phone may automatically reboot
The 8 digit code can be obtained by calling AT&T Technical Support and given the representative the IMEI number. In exchange they will give you the Subsidy Unlock Code.
To obtain the IMEI number press *#06# on your mobile device.
Feb 11, 2009 | Samsung Blackjack SGH-I607 Smartphone
Lg puk for cu720
PUK code is not a password on the phone it's related with the SIM. you need to speak to your network operator to get the PUK Code.
Jan 06, 2009 | LG Shine CU720 Cellular Phone
Canon PowershotA75 takes blurry purple streaky pictures?
I just had this same problem. Check the canon web site, search for you camera and look for the CCD Image Sensor Advisory. They are aware of this problem and will fix it for free. Just call the customer service number.
Nov 14, 2008 | Canon PowerShot A75 Digital Camera
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
