If you put the iron on all electric gos off - Washing Machines
    Problem Solver:
  • 30 Answers
Resistance (heater) is broken. Buy a new one, it's cheaper.
Posted on Mar 15, 2011
Can i put the cord of my rowenta iron together with electric tape one of my grandsons cut it
Well you could, but the real question is would you want to ESPECIALLY with loved ones about. I would say no...the long cord is easily replaced and you can get here:
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Aug 22, 2011 | Rowenta DG-980 Iron
I'mnot getting any steam from my tefal steam iron.
Please bring your unit or call a service center accredited by manufacturer of your unit. The temperature needs some adjustment inside the unit. Check also if the unit has electric power and hope you do not forget putting water in the steam.
Jun 14, 2011 | Tefal Pro Express GV 8120 Iron
How to repair aan electrical iron
If the iron doesn't heat, make sure power is on to the outlet, check the electrical chord, and check the thermostat and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical chord . Also test and, if needed, adjust calibration of the thermostat.
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the sole plate. If the iron stains fabric, clean the sole plate, clean the tank with a commercial cleaner, and use distilled or filtered water.
The tools you will need are
  • Screwdrivers
  • Toothpicks or pipe cleaners
  • Sewing needle
  • Commercial electric iron cleaning solution or vinegar and water
  • Commercial sole plate cleaner or baking soda and water
  • Steel wool
  • Emery cloth
Please rate my solution.
Jun 25, 2010 | Rowenta Professional Luxe DM880 Iron
The electrical connection is failing, and the iron is only months old. I really liked this iron and it bothers me that it broke for no reason. I bought the iron at Walmart and no longer have the receipt or...
I would buy the iron at walmart and put the broken one in the box, take it back with your recipt and get your money back.... just like that brand new iron
Feb 23, 2010 | Euro-Pro Shark GI490 Iron
The door got slammed, I heard a piece of plastic fall inside the door, and now it won't start.
That was probably the saftey switch. You will have to take the machine apart and see if it can be put back in it's place
Nov 07, 2009 | Whirlpool LER4634J Electric Dryer
T-fal ultra glide easy cord iron stopped working while ironing
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jun 03, 2009 | Tefal UltraGlide 1569 Iron
My Rowenta iron will not heat up. The yellow light just continues to blink- so I know that there is some electrical current. I have a friend with the same issue with the same iron. Is there a trick to this...
Inside the iron is a piece of thermal metal the is supposed to make contact with a small ceramic pin with a metal cap on it. I think this was intended to be a safety device but they fail and the iron will not heat up. The part does not seem to be available so easiest way to fix is to put a small bead of glue on the housing that forces this to make contact.
Mar 01, 2009 | Rowenta Professional DM890 Iron with Auto...
When i am ironing all the power in the house goes off and it is a brand new iron
Patrick,
The iron may actually be ok. If not, remember that because it's new it will come with a guarantee.
Did you put the plug onto the iron yourself? Check inside the plug to make sure that there's no bare wires that can touch as the cord flexes as you iron. This would cause it to short and throw the power in the house.
Try using the iron in a different room. If you get the same problem then there's possibly a wiring fault (maybe a broken/worn insulation on the wires of the iron cord ... though as it's new, I would doubt this).
Are you using an electrical extension lead to plug the iron into? If you haven't overloaded the socket with other electrical appliances it may be that the extension cable has a broken/faulty/loose wire inside that when they touch, causes the power to go off. A few years ago the power in my house used to go off on occasions whenever someone went to the fridge. The fault was traced to split insulation on one of the wires in the extension cable I was using. Whenever somebody stood on the cable it shorted out and cut the power.
To be really sure - go into a neighbours and use the iron! If the power goes off - it's the iron at fault. If not, it's probably just a small problem like worn insulation/loose/broken wire in an extension lead in your own house.
Sep 19, 2008 | Conair Compact Garment Steamer Iron
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
