Question about Mintek MDP-1880 8.5 in. Portable DVD Player
Need to find plug for dvd player - Mintek MDP-1880 8.5 in. Portable DVD Player
  • 902 Answers
Here you go http://www.amazon.com/Dvd-1710-Dvd-5820-Dvd-5830-Dvd-5861-Mdp-1810kit/dp/B001R2ERFY let me know if that solves it for you!
Posted on Mar 15, 2011
How to connect dvd player to tv
    1. If so you can get yourself a component cable and connect the DVD player to the TV using those plugs. Otherwise, you will need to get an RCA to HDMI converter.Nov 23, 2015
      Connecting old VHS/DVD Player to my Smart TV - Tom's ...
      www.tomsguide.com/.../id.../needed-connecting-vhs-dvd-player-smart.html
    Feedback
  1. 5 Easy Ways to Hook Up a DVD Player (with Pictures)
    www.wikihow.com/Hook-Up-a-DVD-Player
    wikiHowHooking up a DVD player to your TV will give you access to countless hours of movie-watching bliss, and most modern TVs and DVD players make the setup ...‎Setting Up your DVD Player - ‎Connecting with an HDMI Cable
    How to connect a standard DVD player to a TV - YouTube
    ? 2:57
    https://www.youtube.com/watch?v=8pARHjY8xoo
    Jul 5, 2011 - Uploaded by All About Home Electronics.com
    Lol I used my standard AV cables for the component, and I used an adapter to plug the audio into my speaker ...
Dec 30, 2015 | Televison & Video
I would like to find a dvd player compatible with xenta cy-1000 sorround sound
A standard DVD player will be able to give a surround-sound output. I do not think you will find a DVD player with a 6 lead connection.
Most DVD players I think have a Scart plug connector (rectangular plug with about 2x10 pins in two rows). You can get connector kits with a scart plug for the dvd and 6 phono plugs for the TV
If you search on Ebay for 'DVD to phono plug connector' costs about 3 GBP! Check the length of cable you need first.
Mar 03, 2014 | Computers & Internet
I cant get a picture only sound not sure its in the right plug?
if your tv and dvd player are good yes might be you have a wrong connection. this is how a proper connection between your tv and dvd player.
  1. first step in connecting a dvd player to a tv unit is determined what kind of connection you want to make, this usually determined to the outputs and inputs available on the dvd player and tv unit.
  2. if you are using a plasma or a lcd tv usually the inputs are: composite inputs- lets you connect a component source like a dvd, vcr, and laser disc. component inputs - lets you connect another component source such as a dvd player. DVI-HDTV - lets you connect an HD receiver with a DVI output.
  3. for example if you select the composite input what you need is a RCA plug which usually a 3 color plug.this picture is an example of commercial rca plug which usually the color yellow use for video and the red and white color for audio.vinceisaac.jpg.
  4. this is how you will connect those wire into your dvd player and tv unit.look for the component output jack of your dvd player .this picture is a sample of component output jack the color may vary depending tovinceisaac_0.jpgkind of brand or dvd player do you have.
  5. now get your RCA plug then the yellow plug insert it to the Y or video out the red and white plug insert it to the left and right AUDIO out of your dvd player.
  6. now look for the composite inputs jack of your TV unit then get the other end of RCA plug. the yellow plug must be insert it to the V label for video the red and white plug into L/R label which mean for audio input.
  7. after you connect the 3 wires re check all the connections make sure the RCA plug is good and properly inserted to avoid loose contact which can affect the picture and sound quality.
  8. now turn on your dvd player and tv unit.
  9. make sure your tv unit is set to right input you want to use like for example you are using the video 1 input, you need to set to the remote controller into video 1 so that your dvd player must be recognized by your tv. enjoy watching i hope it will help you thanks for choosing fixya as your solution to fix you problem good luck.
May 26, 2011 | Apex Digital Televison & Video
How do I connect the DVD player to my tv? My last DVD player had a place on the back to be able to hook in the cable along with the color wires. This DVD player does not have a place to hook in the...
What colour wires does the new dvd player have? The colours correspond with the socket that you plug them into. If your new dvd player only has yellow red and white cables then that is all you need. if they are red blue and green then you will also need to plug the appropriate audio cable into the dvd player. If you need more help please tell me the model of dvd player and the model of tv
Dec 25, 2010 | Televison & Video
Need to know how to hook up a Toshiba DVD player to a TV
To hook up a toshiba DVD player to a television, you need to get the prongs, that you will use to hook them up.
You have a prong with red and white tip, locate the audio out on the DVD and plug in one of the prong in it then locate the audio in on the television, then you plug the other prong in the video out of the DVD player also you plug it in the video in of the television.
That is all you need to do, then you ensure you have your television on the AV mode to enjoy the DVD player on it.
Take care and good luck
Oct 22, 2010 | Toshiba SD-2109 DVD Player
How do you connect the portable dvd player to your big screen tv?
Look on the side of the dvd player you should see a connector that says AV Out or Video Out, you will need a wire that plugs into that which depeding on the model of dvd player can be either the Red / White/ Yellow Phono Plug Leads or a Lead which has the Red / White/ Yellow Phono Plugs and at the other end what appears to be a headphone jack connector with 3 black bands on it indicating that its a 4 Pole Video output cable, then you plug the Phono Plugs into the Phono Sockets on your tv, using your Tv remote you will need to select which input you got the dvd player plugged into this will either be called
Source Or Input Or AV 1-2-3 ect.
jon
Aug 11, 2009 | Initial Televison & Video
Power conversion
Ram,
Good day mate, no problem you can plug your dvd direct to your outlet since it indicates 100 - 240V it only means your player is capable of having either 110V 0r 220V.
note: also try to check 1st if you will see a voltage selector at the back of your dvd player. it's either a slide switch indicating 110 or 220V. if no sign of this selector no problem you can plug your player straight to your socket.
cheers
mark
Jan 29, 2009 | Durabrand DVD-1002 DVD Player
Dvd player not connected properly to TV?
You might need one or both of:
RF modulator.
AV switch (perhaps from an old video game console)
The modulator accepts the RCA plugs from your DVD player (yellow, white, red) and outputs an RF signal.
You can then plug the ouput of the modulator into the aerial input of the skybox, via the switch, if desired.
Sep 28, 2008 | Cyberhome CH-DVD 300 DVD Player
Disney Princess dvd player will NOT turn on or eject.
On front of television is the video, left and right audio plug ins. This is where you will plug the adapters from your dvd player. They are color coded for easy installation. Step2Make sure the adapter is also plugged in to back of dvd player. Step3Plug dvd player into power source and turn on. Step4On the front of television there is a tv/av button. Press this button twice or until it says video 2 in upper left hand corner of television. Step5Insert movie into dvd player and enjoy. To get your tv back to cable press tv/av button once.
Apr 20, 2008 | Disney Princess MCP DVD2050P DVD Player
DVD PLAYER
what kind of dvd player is it, is it for your home? car? and what kind of tv is it goin to? get back at me, jason
Dec 28, 2007 | Sharp 25H-M60 TV
Mintek MDP-1880 8.5 in. Portable DVD Player Logo
51 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
