Question about Skil 338501 9inch Band Saw
I am just setting up my new Skil bandsaw, and the table is not level--won't go to 0 degrees. Is there an adjustment I'm missing?
    Problem Solver:
  • 13 Answers
Usually there is a stop bolt under the table that you can adjust so that you are able to zero out the table. it should have a lock nut so that when you get the table set to where you want it you can lock down the bolt so that the table is easily re set after moving the table for an angle cut.
Posted on Mar 16, 2011
I have the same problem. The table is level front to back but not left to right. I do not see a specific bolt for this direction. The table gets worse (left to right) as I tighten down the front to back tilt lock. As I read these posts, I'm learning that I just bought an entry level tool. I hope I do not suffer buyers remorse on this one.
Posted on Jan 07, 2013
How to adjust the blade on skil bandsaw 3385 that will not stay on
This is one of most common problems with Skil saws. Make sure that you set the correct tension and track the blade properly. It could also be problem on the blade specially on the weld. I suggest you visit bandsawblog.com for helpful band saw techniques and sawblade.com . I get my blades from them.
Sep 18, 2014 | Saws
Where can I get the parts for the upper and lower blade guides for my skil 10" bandsaw model 3104
Try to contact Skil, if they can't provide you. Check with Carter Products ; they supply bandsaw guides for all types of saws.
Jun 12, 2014 | Skil Saws
Blade is not square to table
There are manuals for the Skil 3400 available online.
Centering the blade to the table simply requires a screwdriver, a good square, and some patience. Basically you're loosening up the points that hold it vertically and horizontally (front to back), checking them against the table with your square, and then tightening them up when everything looks nice and ninety degrees.
It's not the best saw in the world, but with a little work, I've been able to get it to make 90 degree cuts and perfect miters with a miter sled and a cross-cut sled I built using aluminum (I think?) T-shaped replacement runners that would normally be used for the worthless miter guide that comes with it.
Apr 23, 2014 | Skil 10" Table Saw 3400
Where can I get a thrust roller for a skil bandsaw 3104
I've been purchasing replacement parts on www.bandsawparts.com . But they don't have for Skil bandsaw. Have you tried checking on toolpartsdirect? Do you happen to know the correct model number of the part?
Feb 15, 2013 | Skil Saws
Where is the jam nut located on a skil saw table saw 3310
I called skil & they emailed the pictures taken by the techs. Not sure why they don't have the pictures on their frequently asked questions part of their site.... seems like if they took the time to take the picture, they would know it is going to be a frequently asked question... lol.
Aug 23, 2012 | Skil Saws
What is the motor rpm on a skil 3385-01 rt table bandsaw?
This Band Saw is designed to use a 1700 RPM motor. It
is wired for operation on 110-120 volts, 60 Hz.
Taken straight from the Owners Manual found here.
https://mdm.boschwebservices.com/MDMCache/English%20[US]//t10/0000001/r01047v-1.pdf
Let me know if you need anything else!
Nov 24, 2010 | Skil 3385-01-RT Factory-Reconditioned 9"...
Bandsaw stops cutting
the pressure you are pushing could be too hard or a dull blade. what is the HP of it? I use one for cutting metal bar up to 6 inch and wood. the HP of mine is 15 horsepower and wood will cut quick when solid steel is very slow. of course mine is industrial size with a 3 foot depth
Feb 21, 2010 | Skil 3385-01-RT Factory-Reconditioned 9"...
Have a Skil #3305-01 table saw. Need to set blade
The jam nut is on the end of the bolt you are adjusting, directly underneath the table. The easiest way to get to it is to place the saw on it's left side, and move the saw blade to the maximum bevel position (45 degrees). You can then reach up -directly underneath the location of the bolt on top - and access the jam nut.
To be clear - the bolt you are tightening is about 2 inches long with the jam nut on the end with the purpose of tightening the bolt into place once you have established the correct adjusted position.
And yes, the directions for this step were terrible.
Nov 03, 2009 | Saws
Brand new Skil bandsaw 3385 will not work
if the motor has a capacitor, that may be bad, or bad centrifical switch in motor, or miswired
Sep 02, 2009 | Skil 3385-01-RT Factory-Reconditioned 9"...
Bought model 3400 skil table saw. have no manual. can't find control for tilting blade. how do i tilt blade
This model does not have a knob on the side.
There is only a locking lever on the front next to a single rotating wheel for height adjustments. To tilt the blade simply twist the locking lever to the left and push the height adjustment wheel to the right. It can be a bit stiff at times to move.
Feb 26, 2009 | Skil 10" Table Saw 3400
Skil 338501 9inch Band Saw Logo
198 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
