Question about Kenmore Vacuums
Mine is a much older Kenmore 840 which for years has only retracted the cord part-way. I expect there is dirt in the retrieval mechanism but can't get at it. HOW do you open this type of vacuum when it seems sealed all around and there are no nuts, bolts or screws visible?
reddevil6
  • 1673 Answers
SOURCE: vacuum base removal-kenmore whispertone 300
Most of these you have to take off the cover on the back end where the cover retrack button is. Usually it has a catch, 2 on each side, use a screw driver, pry up near each corner to release it, then you can get to the cover over the moter and cord reel. Remove the 2 screw and put up and out.
Posted on Jan 14, 2008
  • 30 Answers
SOURCE: retractable cord
I'm assuming that you have bought the new retractable cord assembly. If you have so, I believe the cord should retract going counter-clock wise (pulling it makes it spin clockwise).
Posted on Mar 08, 2008
  • 1214 Answers
SOURCE: open power cord housing on kenmore 116 vac
You can go to the Sears Parts Direct website and type in your Model number. It will return both an exploded view and parts list, with pricing for replacement parts. You can also order from them, and they can tell you stock status as well.
Posted on Jan 15, 2009
ukvacfan
  • 328 Answers
SOURCE: electric cord won't retract
Depends on the machine. If its a Sebo K model then usually pulling on the cord will re-automatically retract the cord anyway. Any other brand and it will need to be replaced by a qualified repair.
Posted on May 08, 2009
  • 3 Answers
SOURCE: I have a Kenmore Vacuum
The retraction mechanizm is likely jammed. Mostly likely the cord has jumped it's groove in the retraction wheel/hub. If you are good with tools there is a 70% chance you can get it to work again with a basic DCR operation. Most mechanical problems can be solved using this simple rule: Dissassemble Clean and Reassemble.
CAUTION: The retract mech has a powerful spring inside, avoid exposing. Most retract mech units are rivoted closed so consumers won't poke thier eye out.
CAUTION: UNPLUG THE UNIT
Open the unit from the bottom and the top lid of the canister should come off.
The retract mech should be obvious as it is where the cord comes into the unit.
Look for the cord being bound by iteslf either on top or underneath (lie two cordes in one groove)
Remove any binding.
If you see no debris or obsticals for the cord to retract (where it is getting stuck)
Your spring could have sprung!
Do you feel and retract at all?
Can you locate the releae mechagnism?
Does the Release button seem to function? When Pressed it should take pressure off of the cord hub.
The retract mech may need replaced. Overall the cost will be about $60 for parts.
Posted on Feb 12, 2011
Kenmore 116.26212602 cord won't retract completely
This is a common Kenmore problem. The cord may have kinked inside the cord reel, You can remove the top by taking the screws out some are hidden under the switch. If the cord gets too close to the edge of the reel it can bind. Do be careful as the spring in the cord reel can jump out and it hurts. I would take it to a dealer.
Jan 31, 2014 | Vacuums
The power cord does not retract or rewind when the button is pushed. How can I repair this?
Sometimes you can help get the springs working again, by gently pulling the cord out a little further and then let it slowly in while pushing the cord retract button.
Nov 08, 2012 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore canister vacuum retractable cord jammed
go and buy it from www. repairclinic.com
God bless you
Jul 06, 2012 | Vacuums
I have a Kenmore Vacuum cleaner 116.24212. The retractable electric cord won't retract. How can I fix it?
Remove any binding.
Feb 12, 2011 | Vacuums
Eletrolux lux7000 manu and how to retract the power cord?
For the user's/owner's manual, go to the below link, click on the arrow below where it says "Older Models", click on Lux 7000, click on "download". If you want a service manual, they are only available to Aerus Electrolux stores.
For retracting the cord, try tipping vacuum up on it's back end and gently pulling and releasing cord. This will often cause it to retract. If not, keep in mind that the canister portion of this vacuum has a 7 year warranty on it, so depending on when you purchased it, the cordwinder may still be covered. The warranty does not cover normal wear and tear, or abuse. There are other things that will void the warranty.
Nov 26, 2010 | Electrolux Lux 7000 Bagged Canister Vacuum
Electric cord won't retract
May 06, 2009 | Vacuums
Power cord retrieval
Depending on which model you have, take the bag door or lid off by pushing it back and it will unhook and come off, there are 4 screws that hold the cover on over the where the cord rewind button is, take that cover off and you can get to the cord reel.
Feb 12, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Retractable cord
Feb 22, 2007 | Kenmore 23613 Progressive PowerMate Bagged...
Vacuums Logo
200 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
