Question about Equator EZ 3710 CEE / W Ventless Washer/Dryer Combination
My washer dryer ventless combo spins but wont drain all the water or dry. the lint trap is empty and the dryer is working but the water is not fully draining the last amount out of the machine
  • Equator Master
  • 5,323 Answers
Washer will not drain:
Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue and even a no spin issue?. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement.
Read more:http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ
The washing machinedrain hoseis where the water flows through to get the water out.If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the waterfrom the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it
Thewater pump belt(to drain out the water) may have broke or become frayed or loose.If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing theNO DRAINissue and remove and replace if needed.
If thelid switchis not working as required it will cause your washer to not drain (and many other problems).This may be unlikely as a bad lid switch will usually cause your washer to alsonot agitate or spin.However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuityMy advice is free cuz God is good!
Fix Washing Machine That Won Drain Washer Not Draining Water
my washer dryer ventless combo - 8669576-wkaz2joxiaagz3w0xil1scpn-1-9.jpgoads/images/8669576-wkaz2joxiaagz3w0xil1scpn-1-9.jpg" alt="8669576-wkaz2joxiaagz3w0xil1scpn-my washer dryer ventless combo - 8669576-wkaz2joxiaagz3w0xil1scpn-1-14.jpgimg src="http://i.fixya.net/uploads/images/8669576-wkaz2joxiaagz3w0xil1scpn-1-14.jpg" alt="8669576-wkaz2joxiaagz3w0xil1scpn-1-14.jpg" class="h_mi" />
Posted on Feb 02, 2016
3 Suggested Answers
SOURCE: EZ 3612 CEE Water Not Draining Completely After Dry Cycle
ChicagoRandy,
You may be loading the washer with too many items. 8 pounds (wet) is the max for an Equator EZ3613 CEE. Mine would drain, but then wouldn't spin, leaving the clothes soaking wet. Here's what worked for me:
I turned it OFF, unplugged it for a while, emptied it of all items, plugged it back in, turned the dial to RESET, turned it ON and watched the Mode light flash quickly for a while, then watched it for over a minute, flashing about once a second, to ensure it really had reset itself. Then, I turned it OFF, turned dial to Cotton 1, turned it ON, and it performed the cycle properly when empty. When this strategy worked, it told me I had put too many items in it for it to spin.
April 5, 2008
Posted on Apr 05, 2008
SOURCE: Problems Drying Clothes
That's the way it works, kinda stupid, it would be good if it did that at first to loosen up clothes in case they're stuck to the drum but then move like a traditional dryer but that's just the way it is. BTW, here's a website with parts for it in case you need them. I never used them but just found them, I was lucky I never had any problems with my equator until now but I kinda can live with it (during rinse cycles it pumps water out but then when it does the short spins it does not, so rinsing is not as effective sinse it leaves a lot of dirty water in and then puts fresh water in and does it again, it does pump the water out during the final spin cycle though). Anyways, good luck. I bought mine in 2001 or 2002 and never had any problems except for the one I mentioned.
Posted on May 11, 2009
Forgot to put the lint trap back into LG Ventless Dryer DLEC855W. Clothing might have gotten stuck inside. Dryer now making grinding noise and drum is moving slowly. Is it time to call a repairman?
The filter simply allows the dryer air to pass through and trap the lint so it will not collect in the exit tube or on the outer vent parts. If anything, the clothes inside the bin will just spin around and be there when you finish. The noise inside the dryer could be from something that was in the pant or shirt pocket and was floating around.
Mar 01, 2014 | LG Electronics DLEC855W Electric Dryer...
My dryer is leaking water
When your dryer spins to dry, water will start to collect at the vent, vent hose and lint trap areas. Make sure to fully remove the vent hose and lint trap and clean both of them out fully you may have to purchase a new vent hose. Make sure you secure both of these parts in after cleaning this should fix the leaking problem along with keeping your house firesafe
Oct 17, 2013 | Kenmore Dryers
Whirlpool lsq9549lw3 washing machine wont spin
Hello.
If your washer is indeed a WFL2066, than the not spinning is directly relatedto the unit not draining.
These machines by design cannot spin if the drain is inadequate.
Here is the first step in resolving the problem, you need to access the drainpump/filter to clean it.
To reach the filter and clean it...
**Unplug the washer from the dryer or wall, or turn off the 30amp breakerat the home service panel...safety first**
1) Open the small square plastic door at the right bottom of thewasher.
2) Via the small hose drain any access water from the pump...this is where awet/dry shop-vac comes in handy, or a shallow pan with a few towels works a swell.
3) Then turn the pump insert/button trap counter clock-wise and pull out.Clean the trap out thoroughly running it under hot water and mild soap or your washer detergent and inspect inside the pump for any other foreign objects/obstructions.
4) Re-install the lint trap insuring it is good and snug/tight. Before closing up the small access door, run a short rinse spin cycle to check for leaks.
Let me know how you make out, or if you require further assistance.
Thank you for visiting our site please take a moment to rate the infoprovided for you here.
Thanks.
Sep 30, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
GE washing machine makes clicking noise and wont agitate. It will drain and spin
Hello.
If your washer is indeed a WBSE3120B, than the not spinning is directly relatedto the unit not draining.
3) Then turn the pump insert/button trap counter clock-wise and pull out.Clean the trap out thoroughly running it under hot water and mild soap or your washer detergent and inspect inside the pump for any other foreignobjects/obstructions.
Thanks.
Sep 30, 2011 | GE WBSE3120B Top Load Washer
My combo washer dryer spins but wont drain the water out.
its your filter itneeds emptyin if not then the washer belts come off
Jun 26, 2010 | Equator EZ 3710 CEE / W Ventless...
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have a Supra ventless washer dryer combo
Not enough information. Does the drum turn but no heat? Dryer won't start?
Nov 20, 2009 | Dryers
Red light on,check filter
Is this a ventless dryer? I.e. a condensing dryer?
If so, there is a filter that filters the lint out of the water in the condensing unit. Check your owner's manual to find out how to service this. It is usually a little door on the front, bottom of the unit.
If it is not a ventless dryer, then the only filter I know is the lint screen.
Good Luck!
Oct 10, 2009 | LG WM-3677HW Front Load Washer / Dryer
Apr 25, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Washing Machines Logo
123 people viewed this question
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Gerry Harvey
Gerry Harvey
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
