Question about TurboChef TORNADO Electric Oven
My turbochef oven display wont turn on. i just replace the solid state relay
    New Friend:
  • 107 Answers
HI,
you said it won't turn on.Is that mean its not warming up or its totally off.
please reply me with questions.
I will be happy to assist you.
thanks
Posted on Aug 27, 2011
We have Turbochef NGC N6. The units high limit thermostat had tripped. Re-set thermostat and found cooling fan not working. also found thermal cut out ( top left rear looking from above ) had also tri
ur high limit trip because ur heater overshoots the program setting for the temp replace ur k4/k5 solid state relay for it controls ur temp for the heater.
Sep 21, 2014 | TurboChef TORNADO Electric Oven
Why turbochef tornado dont pass to ready to cook and de IR is adjusted to1000F and dont pass to 378 F.
Open right side pannal. Check the signs of arc or burnt wires. If you know how to use DMM the check its resistance if its 14.4 ohms then replace SSR relay. And that's it. Goog to go now MAKE SURE YOU DISCHARGE THE CAPACITORS.
Sep 23, 2011 | TurboChef TORNADO Electric Oven
Oven gets to hot and then it trips out. how many solid state relays do I need to replace?
Usually they put only one SSR(solid state relay).however just make sure how many do your equipment have. Just look at their parts list (that it dosent say dual SSR) . If yes then only one relay to replace But also check that I/O board isn't bad Sometimes the board gets wrong and we replace other components. Just check that when oven is hot I/O board isn't sending any voltage to the SSR Also , replace the thermostat tripper since after getting trip 4-5 times it's get faulty after some time . Thanks Please rate my work
Sep 08, 2011 | Ovens
My oven is on warming mode from last six hours. Please adivse
First, check the back of the oven. See if the lil red button can be pressed in. Then check the IR Element, usually you can see the wires burned or damaged where it enters the oven by the snap rings. This was a design flaw from the manufacturer of the element of which turbochef has taken care of.
COMPONENTS
IR Element
The IR element - a dual coil type heater - is located
in the bottom of the oven cavity. The first coil is the
heating coil. The second is the IR thermocouple
wire. The heating coil outputs 3000 watts at 208
VAC. The heating coil's resistance is 14.4 ohms at
room temperature.
The thermocouple coil is a Type K thermocouple
with a resistance of approximately 20 ohms at the
splices located approximately 6 inches from the
heater and 40 ohms measured at the extension wires
at the I/O control board.
The IR element is controlled via the K5 solid state
relay and the IR thermocouple via the I/O control
board.
Its typically an easy quick fix.
Nov 02, 2010 | TurboChef TORNADO Electric Oven
Turbo chef is not heating up, coming up on it reads, f8 low heat
the problem with f8 like you have said LOW HEAT
, IF the oven does not warm up in time , which is usually 8 min , it goes into f8 fault code
now please check the hi limit button , on the back of the oven , left hand side, bottom corner, if it reset and starts heating, please check bottom element and temp reading IR , IF it rises very quickly and the elemnt is glowing red , please switch off the unit at the power point , you have problem with the solid state relay, if the temp is slowly rising , then you might only have an issue with the hi limit reset button thermostat, FIRST JUST CHECK THE RESET BUTTON
Jul 03, 2010 | TurboChef C3 Single Oven
TurboChef C3 - no power
turn off button not working
Jun 24, 2010 | TurboChef C3 Single Oven
Our oven is not heating.
I need alot more info than that. Is there any blinking error codes do you hear fans turning on. do you see the temp info
Aug 12, 2009 | TurboChef TORNADO Electric Oven
OVER HEATING
Hello. If the SSR is closed, and the oven is off, then the SSR is bad. You can call turbo chef for a part supplier,if you are able to replace it yourself, at 1800 90turbo.
Dec 16, 2008 | TurboChef TORNADO Electric Oven
Turbochef oven
take the top cover off and then the left and the right side.
look on the left you will see the door position switches. these most likely need replacing. easy job to do
Feb 21, 2008 | Ovens
Warming up problem
This has nothing to do with the element. This oven should only be serviced by a qualified technician. If you were one, you would already know the solution. You need to go into diagnostic mode to determine if it is the solid state relay or the cc thermocouple. After resetting the hi-limit more than once, it will also need to be replaced.
Aug 24, 2007 | TurboChef TORNADO Electric Oven
TurboChef TORNADO Electric Oven Logo
98 people viewed this question
Top TurboChef Ovens Experts
Dennis Boxerman
Shehu Pro
Shehu Pro
Are you a TurboChef Oven Expert? Answer questions, earn points and help others
