Question about Dryers
No heat coming from drum when spinning with our indesit idc75 drier can u help? looked for reset butten but cant find one can u please help
  • Dryers Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Mar 20, 2011
Indesit tumble drier, the drum won't turn, belt is ok and it is heating up
Check the motor for voltage. If voltage present then with motor or brushes faulty. If no voltage then pcb fault
Jan 17, 2018 | Indesit Dryers
Hi I have an indesit condenser dryer Model: IDC8T3B And it’s no longer heating. It spins but no heat.
A few possibilities, is the blower motor going? If it is not working then it would appear to not be heating.
If it is not blowing it could be the blower drive belt located under a cover in the back. If it is blowing the it may have dropped a thermal switch located on the outer drum, inside the case (if you have a multimeter, measure the resistance across the 2 tabs, open circuit means it is broken). If it is more than that a new heater or switch or timer call a service technician. or buy a new drier
Nov 28, 2017 | Indesit Dryers
Indesit idc75
sounds like its a drum glide worn out
Jan 04, 2014 | Dryers
Indesit IDC75 belt change
Your tumble dryer is a little different than I am accustomed to, but there are millions of dryers in the U.S. with the same sort of system. Try this. I think ( I hope) the belt goes as follows:
The small black(?) pulley should be spring loaded, so that you can either push or pull it toward you or away from you. I think the belt goes around the motor shaft first, then goes back around the black pulley, then to the drum up above. When you are done, the belt should be upside down S shaped, with the motor shaft in the bottom of the S and the black pulley in the top of the S. I cannot type an upside down S on this keypad. When you pull or push the loose pulley, it should allow the belt to slip by on one side or the other to go around the back of it.
Be blessed.
Apr 27, 2013 | Dryers
How do you remove the water pump on an indesit idc75 condenser drier?
This easy to use white Indemnity condenser dryer will make a welcome addition to any kitchen. The 10 minute cool tumble and reverse tumble option will help keep creases in your fabric to a minimum. Energy efficiency ratings & performance: Energy efficiency rating: C. Maximum drying capacity 7kg. Condenser dryer features: 160 minute timer. Including 10 minute cool tumble. 2 dryness levels. Manual control. Reverse tumble option. Reservoir full indicator. Fluff filter. Size H85, W59.5, D58.5cm. Drying programmes Freshen up cycle. Manufacturer's 5 year parts and 1 year labour guarantee. Technical specifications: Energy consumption: 4.48kWh per cycle based on dry cotton cycle. Energy consumption: 336kWh per year based on dry cotton cycle.
please comment on my post or vote for the solution.
Dec 21, 2010 | Indesit Dryers
Indesit 70c drier is working but the drum is not spinning
Please if the drum is jammed mechanically. if so you will need to reset with a mechanical job , Please check supply to drum, if absent check the controller unit for failure of the driver. If present then the motor is faulty, if capacitor is present for staring check for failure or attach one in parallel to confirm.
Dec 15, 2010 | Indesit IS70C Electric Dryer
I have just bought an Indesit tumble dryer model no IDC75, the dryer is working ie the drum is moving but there is no heat being generated from the machine
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 10, 2010 | Indesit Dryers
TUMBLE DRIER-INDESIT IS70C
hi did u check the hoses from the pump and check the pump for any obstructions.
Feb 14, 2009 | AEG Washing Machines
Re washing and drying
Hours? It sounds like your machine has a problem.. Have you tried clearing the filter on the outlet after the drainage pump? The Indesit only has a 1200 spin speed so it's not the most efficient drier anyway (rated B for spin efficiency).
Personally I dislike Indesit as they release some models which do not permit replacement of the bearings because the innner and outer drum assembly are crimped/pressed together during manufacture. Instead of replacing bearings and seals (At most about £35.00) you would need top buy a complete drum assembly at about £125.00, and throw away a large lump f stainless steel. Presumably Indesit want you to throw the entire machine away, and to buy a new one. Not a brilliant idea in my opinion, as it is unlikely that a frustrated ex Indesit owner will but an Indesit as a replacement, and that sort of wastage (bearings last around three years in regular family use) makes a complete nonsense of energy efficiency ratings. The cost of manufacture and disposal over a three year usage period will have a massive carbon impact in comparison to the energy efficiency savings even of the most efficient of machines.
The planet can't afford to buy cheap machines and then thropw them away.
Apr 28, 2008 | Indesit W 123 Front Load Washer
Indesit Washing Machine not proceedding with the cycle programme after filling with water.
Cant understand how the machine will revolve on the 'spin cycle' & yet you can hear the motor on the 'wash cycle' but yet it doesnt revolve!!
Nomally if the water fills, & the tub revolves without the programmer advancing, its because the heater is not working. ie faulty thermostat, heat element, or maybe a wire burned off in the 'heater circuit'. Check if you have 240 volts at both ends of the heat element, with a meter or 240 volt bulb
                         !! BE CAREFUL OF 240VOLTS!!
Oct 29, 2007 | Indesit W 123 Front Load Washer
Dryers Logo
410 people viewed this question
Top Dryers Experts
