Question about Seagate FreeAgent Go 320 GB USB 20 Hard Drive
I have a Seagate 320 GB 9kw2ag-500 that I have had for a couple of years it worked fine until one day I did not pull out the plug correctly and now I cannot seem to get power to the unit (as all the little lights on top dont light up any more when plugged in). I think I wrecked a connection in the plug. Is there a way I can talk this thing apart to restore the connections long enough to transfer data to the main computer hard drive and then onto a newer model hard drive that I have purchased? There appears to be no way to open the unit up to even see if I have cracked a circuit board or wrecked any connections. And, by me unplugging the unit (the way I did) I believe any warranty is out of the question. Please advise? Bill
    Sniper:
  • 69 Answers
Just open the case, it contain a normal harddrive that you can place inside your computer or in a new enclosure so you can get the data backedup.
Here is how to open the enclosure:
Posted on Mar 15, 2011
When my seagate external hard drive connect to PC it only flashing & wont open or connect.
Posted on Apr 02, 2011
    Master:
  • 346 Answers
Billyboy -- Firstly, did you try it in another USB port or another computer's USB port? Secondly, you might have damaged the cable but it's unlikely that you've cracked a circuit board or anything that drastic.
As you know the unit has a five-year warranty and from your description of what happened there is NOreason to assume that the warranty is voided. I would NOT go cracking open the case and certainly voiding your warranty! I would call Seagate about service and getting an answer to whether they do anything to preserve the data on a returned external USB drive under warranty.
So until they tell you they don't try to save data I would be calm for now and don't try to be a PC Tech if you don't have the experience. Then you can decide how to proceed.
Good Luck,
Mikeywaf
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Seagate 9sd2a3-500 320 GB Problem
Improve the Fixya experience for everyone by voting!
It sounds as though you have one of the following problems:
  1. Dirty contacts that can be cleaned with CRC electronic component cleaner;
  2. A faulty drive that may have been dropped at some point in time. Your drive may have a three-year warranty and Seagate will replace it. Just go online and provide the serial number; and.
  3. You may have to reinstall the drivers. The Seagate website can provide this if needed.
Apr 14, 2012 | Seagate 320GB Portable External Drive ...
I have a 500 GB Seagate portable external hard drive model 9ZA2AH-500. It was working fine untill yesterday. Now when I plug it in all I get is a faint beeping sound Then it stops. I have tried plugging it...
It may be the interface that has failed but I suspect the hdd has failed.
Take the hdd out of the case and fit another drive. If that one is OK the hdd is dead. If it doesn't work, try a new usb to SATA interface.
Sep 25, 2017 | Seagate Free Agent Go Small 12 GB USB...
SEAGATE FREEAGENT GO 320 GB USB HARD DRIVE P/N 9KW2AG-502 320GB SN:2GE7114P THIS HARD DRIVE NOT SHOW IN MY PC SO I REQUEST YOU TO SOLVE MY PROBLEM...... THANKS
Feb 24, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
I have 3 Sata drives in an Asus p5vdc-mx 1 x 320gb & 2x 1TB all Seagate & it randomly lose 2 x 1TB sata drives. The system runs fine for days or weeks then both drives disappear at the same time...
Switch off the mother board .
Please remove the cmos battery and press power switch.for 40 seconds.
Install again and set bios for your requirement.
If same as before . change all the cable
Hope this helps
Jan 24, 2011 | ASUS P5VDC-MX Motherboard
Hello.pls my seagate free go version 320 gb harddisk fell down and afterwards its not being detected again on my vista o/s.pls any corrective measure is really appreciated
dropping a hard drive is one of the worst things you can do to a drive specially if it was running. More than likely if the heads crashed against the platers you will need to replace the drive.
Jul 28, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
External 500gb hard drive not readable
Check the partition size in Disk Management (if running Win7 - download a free Partition Manager if not) and see if the system is seeing the partition correctly. Seagate has recovery software available on their website but you may just have to repartition and reformat.
Apr 25, 2010 | Seagate 320GB Portable External Drive ...
My seagate 500 gig free agent desk external drive has suddenly stopped working. It was working fine 2 days ago and then yesterday it apparently wasn't connected so I reconnected it and then it seemed to be...
Do a FULL POWER DOWN Reboot. and try a different USB outlet in the PC... same Laptop to see if it is in your PC that is causing the problem.
Note: Most of those Drives do stop unless they are connected to the PC... energy savings.
If that didnt work... you could have a failed drive. Seagate should help you do some diag if it is in warranty... typically 3 years.
Dec 31, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate SATA 160 GB (ST3160827AS) fried!
Are the logic board model numbers the same? How about year and batch manufature? check on that.
Sep 20, 2007 | Seagate (ST3160827AS) 160 GB Hard Drive
Seagate FreeAgent Go 320 GB USB 20 Hard Drive Logo
641 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
