Question about Refrigerators
My refrigerator is not staying cold and i have a layer of ice on the back wall of my freezer. ge model GSS2OIEPJWW
    Guru:
  • 1,524 Answers
Most likely the "Adaptive Defrost Control" aka Motherboard is bad.
Posted on Mar 15, 2011
Ge refrigerator is not cold enough and ice is not working
What is the model number?
The ice maker will only run if the freezer is at the correct temperature.
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 27, 2012 | Refrigerators
I have a GE Refrigerator TFX26KPDAAA and the refrigerator part will not stay cold
Nov 26, 2012 | Refrigerators
The freezer is not cold enough to freeze nor is the temperature in the whole refrigerator cold.
most likely you have a bad computer board if the freezer is getting warm too.if there's no ice on the back wall of the inside freezer wall then it's the board.you can check this site out
http://fixitnow.com/wp/2009/11/30/ge-refrigerator-motherboard-recall-list/
Feb 01, 2011 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Refrigerator purchased March 2008, model # 59665969700, freezer on bottom. Refrigerator stops being cold. Freezer seems to get colder, icing up on back interior.
That icing up on back interior im assuming is in the freezer. If its a layer of frost, you have a defrost problem, and should check continuity through the defrost heater and the bi metal thermostat, both located on the evaporator coil behind the back wall of the freezer. If either fail, replace, if both of those pass the check, then your defrost control is failing to switch into defrost and needs to be replaced. If the icing up is like frozen sweat drips on the back wall, replace the evaporator fan motor.
Dec 10, 2010 | Kenmore Refrigerators
The refrigerator part is not staying cold. The freezer is wrking correctly and is freezing food. I vacummed all the dust out of the back but the refrigerator is not staying cold. It is running...
This can be a defrost problem or the fans may not be running. If the fans are not running then check the fans. I would need the model number to tell you if you have an electronic model or not because checking the fans is a lot different.
If it is a defrost problem the back wall of the freezer will be covered with ice.
This website has very good info on thses problems
http://www.appliance-repair-it.com/Refrigerator-repair.html
Sep 24, 2010 | GE 19.5 Cu. Ft. Bottom-Mount Refrigerator...
The refridgerator party not staying cold... Freezer part is staying cold
Look into back of freezer and see if a layer of frost is building on rear panel. If yes unplug and manually defrost until you can get back with me with the model number. What you said is the first symptos of defrost not taking place. Look around door frame for the model and I will be back later with part numbers. Thanks, Sea Breeze
Mar 19, 2010 | GE Profile Arctica Stainless Steel Top...
Maytag MBB1952HEW won´t make ice. Where is the fuse to icemaker located? It´s not in the bottom freezer coil area.
back wall of freezer has thick layer of ice frosting over, freezer not cold frig compartment seems to be ok.///????
Oct 14, 2009 | Maytag 22.1 cu. ft. Bottom Freezer...
My 2001 sidexside 24 cubic foot refrigerator and freezer is slowly losing it's ability to stay cold.
Look for a ice buildup on the freezer back wall. If so. Replace the defrost components in the freezer. If no ice in the freezer. Check the compressor fan motor is it running? If yes, replace the main control board.
Jun 08, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frost in Freeze
Hi Frezer Frost.
It sounds like your defrost circuit in the refrigerator has gone south. This melts the ice off of the cooling coil in the freezer section every 8 - 10 hours of run time.
If you are old enough to remember the manual defrost refrigerators, that is why you had to defrost them occasionally. The ice layer on the coil acts as an insulator, preventing the coil from working properly.
Greg.
Aug 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
145 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
