Question about Ingersoll Rand Electric Driven Two Stage Air Compressor 2475N5
Hi i have an Ingersoll rand 80 gal, 7.5 hp, model #2475 air compressor and the electric motor is arcing when trying to run then blows the breaker. Any ideas? thanks
It sounds like either a problem with the brushes in the motor or the engine shaft is jammed. Have you on many previous occasions run the compressor on that circuit with no problems? It may be as simple as the breaker is not sufficient for the power draw of the compressor.
If you have had the unit for awhile and it has been run lots and the engine shaft spins easily when turned by hand (unplug first) then it may be an issue with the brushes on the electric motor. Take the engine apart and replace the brushes with new ones from an electric motor shop. Take pictures as you disassemble the unit so you will be able to refer to them when it comes time for reassembly.
If the motor shaft does not turn by hand, remove the belt that connects it to a compressor and try again. If this works, reconnect the power and see if the electric motor now works with power on and the belt off. If the motor works and there is no short to throw the breaker, then your compressor is in need of a rebuild and that will cost money and time.
Posted on Mar 15, 2011
WILL T21 SELECT OIL WORK IN A MODEL 2475
The solution was easier than I expected. Ingersoll Rand "Select" oil is a synthetic oil recommended by Ingersoll as better than mineral oil. T30 (mdl 2475) and T21 are different styles of compressors. So, yes "select" oil can be used in the Model 2475 compressor.
Jun 25, 2014 | Ingersoll Rand - Rand Type - 30...
I need a manual to rebuild a Type 30 Model 2475 ingersoll rand air compressor. Thanks
Dear Joe Bell,
This is Rodciel L. Camacho of VISMIN compressed air care center we are specialize in ingersoll rand air compressor.
You mean a overhauling kit?The part number of that is 34319469.
Hope i can help you..
May 07, 2012 | Ingersoll Rand - Rand Type - 30...
I have an ingersoll rand 30t model 253 compressor 80 gal tank. what should the start and stop pressure settings be? what is the run time to fill tank and cycle off?
Hi
I'm not sure but I operate my'n at about a 145/150 top and about 110/120 min.
However others my have a differant perspective
Cheers
John
Jul 09, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
I R Ts4 5hp 80 gal 175 psi 230 volt Air leaking from near pressure switch. Replaced switch but still leaking near 1/4 tubing. Thanks
You have a receiver tank check valve leaking. If you loosen the 1/4 tube slightly and air blows out more and will not stop replace the tank check valve. If you follow the copper line for the compressor HP head back to the tank you will see that the line screws into the check valveand the check valve screws into the tank. Bleed all air from the tank,remove the 1/4 line and the 3/4 line from the check valve. Then unscrew the check valve. Install a new check valve and connect the lines. Problem solved.
Apr 30, 2011 | Ingersoll Rand 2340/2475 Electric Air...
I have a new ingersol rand 80 gal 7.5hp air compressor 230volt single phase and was wondering what size breaker it needs to be put on
Your owners manual spec sheet should give you that answer. However since that unit at max loads should pull 32 to 35 amps I recommend 1.5 times max amps. So approximately a 50 amp breaker. This all based on standard wire size and length of wire run. Also when checking your voltage at load you should be showing 235 to 240 volts.
Jan 09, 2011 | Ingersoll Rand - Rand Type - 30...
I had a 242-5D on a 120 horizontal driven by a 5 hp Dayton motor. I changed to a 2475N7.5 on a 80 gal vertical with a bad motor. I want to reuse the Dayton 5 hp motor. What can I expect?
Im not sure if iv;e got this straightYou had a 242running on 120 v driven by 5 hp dayton motor You have a new 80 gal tank with a bad 7.5 v motor and want to put the 5 v motor on it What was the size of the old tank if it was 60 or more you should be ok the 5 hp will have to work harder as long as you can make it fit you may want to consider droping down the blow out valve presssre spec 10 to 15 lbs depending on the size of the old tank
Nov 21, 2010 | Ingersoll Rand - Rand Type - 30...
I believe that the motor starter circuit on my Ingersoll Rand 2475 5 hp 80 gallon compressor is incorrect. It's a 30 amp single phase compressor
You should not be pulling over 30 amps. If you are you may have low voltage, incorrect wire size or to long of a run for wire size. I would use a hand held meter and check the amps at full load.
Nov 14, 2010 | Ingersoll Rand 2340/2475 Electric Air...
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
Correct rotation of copressor
Checked all the IR compressors in stock and all turn counter-clockwise facing pulley, however you could check the pump for fan angle on pulley. The fan on the compressor pulley blows air towards the pump. Generally, pumps turn CC because that would allow for the use of gasoline engines which all turn CC. Please email you questions, and Good Luck.
Jan 27, 2009 | Ingersoll Rand 2340/2475 Electric Air...
Ingersoll Rand Electric Driven Two Stage Air Compressor 2475N5 Logo
206 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
