CD player does not seem to read discs, passing each one untill it gets to the start again, tried leaveing on to cure any condensation but no luck.
  • PHIL1207 Mar 16, 2011
    Thanks for the info, will try that..
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Probably the laser's lens is dirty. Try to clean it up.
Posted on Mar 15, 2011
  • essto Mar 15, 2011
    sorry.. just clean
After reading toc of my Marant zcd5003 the display is "error" seeking help to find out the cause
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
follow the steps and fix it.
God bless you
May 27, 2013 | Marantz CD5003 CD Player
When i put in a dvd, it makes clicking noises, after that a notice
follow this steps and fix it. God bless you
Does not play disc
Nov 14, 2012 | Sony Televison & Video
Hello, My GoVideo dvd/vhs player (model dvr4200) has been working great until a couple days ago. Recently it is not reading dvd's. After I put it into the player it will read the disc and begin to...
Hi;
This is and usual indication of a poor spindel motor that needs replacing it is the motor that spins the disc, it is the most common failue in DVD's and CD plyrs. You can't just replace the motor you will have to replace what called the mech assembly which will include the spindle motor/Laser/stepping motor etc...
Sep 08, 2011 | GoVideo DVR4200 DVD Player/VCR
When a dvd is inserted, the message "no disc" appears, what is the cure?
Hello.The problem is not in your television.It is in the DVD player,your player did not read the cd because,either your cd or the lens player is dirty.Now,try to clean the cd first then insert,if the "no disc "appear again try to clean the lens of your player using lens cleaner.Then if the cd and the lens is clean it may play.Thanks
Jul 09, 2011 | Televison & Video
5 disc cd changer CC4000 will not read
All players need cleaned from time totime. Do NOT try to clean it with anything other than a CD / DVD lens cleaner. They are available almost everywhere that sellsBlank media. It will clean the lens without scratching or smearing it.
Dec 06, 2009 | Marantz CC-4000 5-Disc CD Changer
Dvd/cd player model no dvd-cv52, displaying HO7. have unpluged from power, and cleaned disc.
HELLO
I have just recently posted a cure for this - but here we go again. Fault H07 is the fault code for the spindle/disc motor and to cure it do this!
With the lid of the player removed, locate the spindle and where the motor shaft goes into the motor itself, use a little light oil or WD40. Don't drench the area or you'll really have fun cleaning it up!
Let it soak in a while and try it again - you should now find it works.
I am now finding quite a few owners of Panasonic DVD players are starting to get this message on the display. The same happened to me!
I wish you luck! (:-)
Oct 03, 2009 | Panasonic Audio Players & Recorders
Sometimes my CD player won't read the cd's and other times it works just fine. I have leveled it and it seems to be working better but I'm not sure that's going to fix it.
HELLO
Have you tried cleaning the lens? Do this by removing the top cover of the player and by using a cotton bud and isopropyl alcohol.
Wet the bud (not too much) and remove excess liquid. Using a gentle circular motion clean the lens. Wait a few minutes to let it dry and try the player again. If you know what discs were a problem playing then use them.
If all is OK you have cured the problem - give it a try! (:-)
Sep 29, 2009 | Audio Players & Recorders
Displays ER-3:
According to the manual er-3 is a "Servo error or the disc is in upside down". I wish i were kidding but that is what the manual says.
Sep 01, 2008 | Durabrand DB1200 CD Player
CD PLayer no longer recognising CD RW discs
use fine cd on ur player. If some cd is not working ten do not try it again an again. Try different one. Thank You.
Aug 12, 2007 | Teac PD-H300 CD Player
DVD not playing
here is the link to the user manual, troubleshooting and venturer support contact details; http://www.1800customersupport.com/products.aspx?view=93&p=43&sc=5&sn=Portable%20DVD%20Players&pn=DVD%20Players%20and%20Recorders Hope this helps, please post again if not :)
Jan 30, 2007 | Venturer PVS177W Portable DVD Player
69 people viewed this question
 Grubhead
Grubhead
