Question about Denon DRA-685 Receiver
I have a denon 1801 and the master volume goes to +60 which is all the way up and i cant seem to lower it, the knob turns and everything else works just fine
  • 26 Answers
First solution would be to try and use the remote. If the remote is able to, the problem is in the knob. If the remote does not work, the problem resides in the volume board.
The problem resides in the circuitry that the knob is controlling. Unfortunately this knob has a full range of motion, which means that it is simply controlling a computer chip within the unit. (i have an 1801 as well). What has happened is that some component on the volume board has gone bad, which is resulting in your non functioning volume knob.
Unfortunately this is usually a job for a professional.
If you have standard electronics skills (soldering / disassemble / reassemble), you can open the case and find where the volume knob leads to. There should be a smaller board, and see if you can access it. Usually they are rather hard to get to, or to get free to actually see what is going on. The best solution would be to find a parts receiver, and swap boards. This shotgun approach changes everything. Otherwise, look for any damaged components on the board. Swap out any components that are damaged, or appear damaged with comparable replacements.
Posted on Mar 16, 2011
The volume on my plasma tv goes up to 100 and when i lower the volume it will take a second volume for the volume to go up to 100 how can i fix my tv to lower the
The tact switch is most likely defective which is keeping the volume up engaged. Replace the tact switch should fix the issue. If not the button assembly pcb will need replacement. You can get replacement boards from www.tvcircuitboards.com
Dec 10, 2012 | LG 60PC1D 60 in. Plasma Television
Power amp 2 channel connection to Denon a/v amp
You don't mention which AR amp we're talking about.
I think you're trying to say you want to know where to extract the front channels from the Denon to feed the AR amp. Right?
That would be an output on the Denon to an input on the AR.
Basically, take an RCA cable pair from the Denon's Pre Out F & L and connect them to the (presumed) L & R inputs on the unnamed amp.
Set the AR amp at a reasonably high volume (if it has a volume knob) and leave it alone. Run through the speaker level adjustments on the Denon to match the Front to everything else and it will control the volume going forward.
May 28, 2010 | Denon AVR-3300 Receiver
My friend has a Denon AVR-1801 receiver that is stuck on ''Standby'' and does not seem to want to fully power up. Can you give me some general directions to look before actually shipping it off for some...
hello there could be number of things if i was repairing it i do visual check first with a good light 1 check for burn't parts resistor cracked transistor bulging capacitors if seems ok then i check underneath the board for a dry joints these can cause a lot of problems . if that seem ok then i try and find a bit more info i'e schematic diagram this when you will need to test the components and voltages .i hope you get somethink sorted good luck
regards
shaun
May 07, 2010 | Denon AVR-1801 Receiver
Deneon PMA-250 amplifier -Volume knob not working correctly
Well, it seems you have your finger on the source of the problem. If accessible, try some tuner cleaner inside the potentiometer.
Mar 05, 2010 | Audio Players & Recorders
Denon AVR 1910 Volume Level
My Pioneer VSX-36TX (circa 2002) does the same thing. Modern AVR's count up from minus something to 0db and go just a few db higher into 'plus' territory. It seems arbitrary but that's how it is.
Ask yourself this: who ever really turned the volume knob up to maximum on any amp on purpose, and had speakers survive it? In other words, why have all that capacity on a potentiometer if you never use it?
Little known fact: With that in mind, Bose Corp actually designed a product that intentionally used the full physical travel of a volume control - the Bose Acoustic Wave Music System.
Feb 11, 2010 | Denon AVR588 Receiver
Remote wont change the volume... Zone 2 problems...?
you have to turn off zone 2 it mybe on the back of the remote unit the door after you do so the master volume will work
Aug 23, 2009 | Denon AVR-2308CI
Tuner not working - denon AVR 3805
turn left hand knob to select tuner (round knob on top left front side)
Dec 31, 2008 | Denon AVR-3805 Receiver
Pioneer DJM-600 Bad feedback when i turn up the master volume
It's not your ground wire with the issue, but your RCA cables. Try disconnecting both turntables, and connect 1 at a time, and do the same test, this way you can isolate the problem. Once you've isolated the problem, then you'll need to have the RCA cables replaced on your turntable.
You might also want to check the Cartridges as well. Sometimes a bad cartridge or headshell connection will cause this issue. Worst case scenario, its your tonearm, but that should be test last.
Also, on the rear of your mixer, there is a gain volume pot, make sure this is not maxed out. Keep it about 3/4 of they up. Again, this is on the rear of your mixer where you connect everything.
- OPTiC
http://djproaudio.com
http://djprolab.com
Dec 04, 2008 | Pioneer DJM-600 Silver Professional DJ...
Denon DRA-685 Receiver Logo
165 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
