Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
ICE MAKER PROBLEM
I replaced the water filter on frige and stop making ice
Model Whirlpool GC5SHEXNS?
Do you also have cooled water?
I did this and didn't get the filter in correctly.
Take everything off the shelf under the filter, take the shelf out.
Un-install the filter and look at the bottom that connects to the filter frame.
You will see that the filter has to be PUSHED UP on the "O" rings on the frame and then turned to make the tight seal need to let the water flow through the filter.
This shoud correct you problem if you are using a GE filter.
Posted on Oct 05, 2008
  • 74 Answers
Could be air in the system
Posted on Aug 28, 2008
Ice maker not making ice in whirlpool model #wrx735sdbm00
Check the Ice Maker itself (not the bowl). Is there ice cubes stuck in there? If so, that means that the ice is stuck and the the "pusher" doesn't have enough force to drop them into the bowl.
Mar 11, 2014 | Whirlpool GC5SHEXNS Side by Side...
No water going to ice maker
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Whirlpool GC5SHEXNS Side by Side...
There is a smell from outside the frige
check drip pan for smell see if ice maker lever switch is up for noise
Mar 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
ICE MAKER FREEEZES
my suggestion is unplug frige. for a couple of days! yes you will have to vacate everything. let all ice melt.. have mops and buckets ready for a poss. flood due to so much ice buildup. see if you can disconnect any hoses after thaw and blow in them. make sure fridge is disconnected!. look for any cracked plastic since these can become brittle in time and use 100 percent silicone to seal.
hope for the best!
Mar 18, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Model ED20PK does it have a water filter and where?
Yes it can. Water filters will allow less and less water to pass through as time goes on. For that reason, resturants install pressure gauges before and after the filters to moniter water flow. If there is no water then the ice maker cannot make ice. Please let me know if there is anything else that I can help you with.
Feb 19, 2009 | Whirlpool GC5SHEXNS Side by Side...
Ice maker is not making ice, any ideas?
might be the module.this controls the icemaker
Nov 04, 2008 | Whirlpool GC5SHEXNS Side by Side...
Whirlpool Side by side Ice maker
check water valve for ice maker how old is the ice maker is more than 3 years then it might need replacement as well
Nov 03, 2008 | Refrigerators
I have a Whirlpool Gold side by side frige Model # GDYHA Ice maker stopped working tried to troubleshoot it but still does not work...Have any idea how to fix it. Thanks
THE ICE MAKER CYCLES WHEN THE INTERNAL THERMOSTAT REACHES 10 DEGREES. IF THE FREEZER IS WARMER THAN 10 DEGREES, FIND THE REASON FOR THE WARMING TREND.
CHECK THE ICE MAKER TO SEE IF IT HAS ICE OR WATER IN IT. IF NOT, CHECK THE FILL TUBE TO SEE IF IT IS FROZEN. REMOVE THE ICE FROM THE FILL TUBE IF IT IS FROZEN OFF. IF THE FILL TUBE IS O.K., CHECK THE WATER VALVE ON THE BACK OF THE REFRIGERATOR TO SEE IF IT HAS GOOD WATER PRESSURE COMING TO IT.
ALSO, CHECK THE FRONT OF THE ICE MAKER BEHIND THE PLASTIC COVER. THE WHITE GEAR IS SUPPOSE TO BE HELD IN PLACE WITH TWO TABS IN THE CENTER OF THE GEAR. IF ONE IS BROKEN OR BENT INWARD, THE GEAR ISN'T MAKING CONTACT WITH THE CIRCUIT BEHIND IT. THE CONTROL MODULE WOULD NEED TO BE REPLACED. OR IT MAY BE JUST AS WELL TO REPLACE THE ENTIRE ICE MAKER.
Mar 09, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
81 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
