Question about Microwave Ovens
Hi - I need to know what the cost would be on the replacement glass top. It is a General Electric. Model # JBP80B0K1BD one of the burners is not working. Thanks
    Guru:
  • 1,524 Answers
Call Bi Coastal Appliance Parts @ 1-800-673-1262
Posted on Mar 15, 2011
I have a gas Viking range. The oven burner ignitors light up and ignite the gas burners but quickly shut off - then go on again and off again- intermittently but frequently. This does not permit the...
Here is a test you can use to check the ignitors, Ignitor test. I also would like to you turn the thermostat knob slowly from the off position, When do you hear the click in the knob? You should hear it before the warm or lowest numbered setting on the knob. If you don't, replace the thermostat as it has failed. Need full model number to get you part.
Good Luck
Stay dry out there!!
Aug 28, 2011 | Microwave Ovens
Ovens will not work, glass top burners do
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Feb 15, 2011 | Microwave Ovens
GE model J KP85B0A3BB over range will not heat up. Both control panels for microwave and range work, interior light comes on when door opens, and glass plate will turn...
The most likely problem is the magnetron, it works with the high voltage capacitor and diode which can be a factor. The three work together to generate the high voltage that heats the food. If the repairs are done by a professional the cost will be high when you consider parts and labor.
Feb 09, 2011 | General Electric Microwave Oven
A pan stuck to the glass top on the front right burner when the burner was on. When I removed the pan it took a couple of chunks of glass with it. Now there are two chuncks of glass missing from the...
Sorry to read about your problem, I hope this helps you out.
You are not going to like this, and you did not give the model number of your unit. But glass replacement tops, will range from $600.00 to $800.00 just for the glass top. and their is not a way to make repairs, because it is a special glass.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 01, 2011 | Microwave Ovens
Replace door handle
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle (if required) usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
NOTE: If you wish to remove the door, all you need to do on most models is open the door all the way and lift straight up at the hinges.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Aug 23, 2010 | General Electric Advantium 120 Microwave...
Our electric frigidaire oven doesnt heat up all the time the electric burners under the smooth top work fine PLES389ECG
its time to replace the coil for the oven,get model number and serial# and fine parts dealer there easy to replace.
Jun 16, 2010 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
