Question about Microwave Ovens
My whirlpool microwave over the stove wmh2175xvs1. will not heat up ant thing.
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Whirlpool Microwave Model MH7130XEZ-2
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Oct 22, 2007
Fan comes on automatically
Actually, that's a feature! If you cook much on the range (stove) beneath the microwave, the heat will cause the microwave bottom to heat up quite a bit (just touch it!), and the microwave will turn on it's exhaust fan in an attempt to save itself from burning up. It will shut off in about 15 minutes after you turn off the source of heat.
Aug 15, 2014 | Whirlpool Microwave Ovens
May Spacemaker XL1800 stop heating food. Was working fine. Then just stop
Is this an over the stove type unit? I have had a few problems with my over the range spacesaver. I think the heat from cooking gets up into the microwave and damages it. The steam from me boiling things on the stove had mine quit heating and I purchased a new one. The parts to replace the faulty ones can be quite expensive over $150.00, so its better to purchase a new microwave.
Feb 24, 2013 | GE Microwave Ovens
Hot microwave door handle
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
Jan 08, 2013 | Whirlpool Microwave Ovens
Whirlpool microwave fan spontaneously came on
some of these unit detect heat from the stove while cooking.there are designed to turn the exhaust fan on until the temprature gets cooler to prevent any interior damage.
there also could be a problem with your microwave circuit board.
check with whirlpool and see if there is any recalled notices for you microwave
Jan 30, 2010 | Whirlpool MH7130XE Microwave Oven
Microvave does not heat the food
The Litz Coil or Magnetron Tube has failed. You can look for blown fuses when you remove it but there is usually another reason it blew and will most likely continue to do so if replaced. They are not worth repairing so it may be time to get a new one.
Jul 20, 2009 | Whirlpool GH4155XP Microwave Oven
Microwave wont heat
The manual says "while in standby mode, press and hold the '3' key on the keypad for 3 seconds until 2 tones sound and the 'DEMO' icon appears. Repeat to turn demo mode off."
You can download a copy of the manual here:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208206572.pdf
Jan 13, 2009 | Whirlpool MH7140XF Microwave Oven
Power out on Whirlpool over-the-stove microwave
Yes, There are fuses inside the keyboard panel. I would have to take a look at the manual for the specific model you have to identify the easiest way to check the fuse.
Before you go that far check above the hood and see if you can locate the plug end of the microwave. Most installations have a dedicated receptacle above the exhaust vent and microwave. It is usually a space too small for good storage so most housewives store small items and cookbooks in this space. It is usually the culprit for a microwave suddenly going out without someone placing metal inside the oven and heating it.
Heating a metal object or operating a microwave for an extended time will usually blow the fuse.
r_craig@basicisp.net
Jan 06, 2009 | Bosch HMT9626GB Microwave Oven
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Oct 14, 2007 | Whirlpool MH7135XE Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
