Question about Whirlpool ET8CHEXSQ Dryer
Whirlpool dryer model CEW9200LWO hums but will not start drying
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Mar 20, 2011
Whirlpool dryer runs, hums, then quits
Sounds like the motor is on it's last legs. Replace it. But, before paying huge money for a motor and the labor to install it, I suggest that you price a new dryer and compare it to the repair costs. It may still be a little more for a new dryer, but....IT'S NEW!
Mar 20, 2017 | Whirlpool Dryers
Whirlpool gas dryer takes longer to dry though it heats up and turns, yet it has a humming/buzzing noise. What could be the problem?
Had the same problem. There was a bit of a kink in the vent duct which caused lint to build up in duct and also inside the dryer itself over years. I replaced the duct and took dryer apart and cleaned out the air passages.It works great now. As for the humming, mine started about 2 1/2 years ago and I still don't know why.
Jun 04, 2012 | Whirlpool Dryers
I just replaced the thermal fuse and the dryer works fine but I noticed the timer switch hums quietly when it's in the 'off' position. Is this normal? We never noticed this before. When I was diagnosing...
greetings,
the push to turn switch usually just has two wires..if yours does then there should be no problem with bypassing it. check to see if the timer stops humming when you more the knob more into off...or let it advance by itself..Does the dryer turn itself into another cycle? or does it stay in off..? If it stays in off, but hums,,its not normal...if it advances by itself out of off its not normal and would need a new timer...this is sight unseen of coarse....
Feb 03, 2011 | Dryers
I have a whirlpool LP Dryer model #LGR5848E that won't start.
can you turn the drum by hand.
if not i would be concerned that you have a sock or something stuck in the blower sqiral cage.
if you can turn it by hand and it sspins freely, then you may have several issues, broken belt, is where id start,
the fact that you can hear a hum say the motor is trying
Oct 05, 2009 | Whirlpool Dryers
Whirlpool electric dryer leq7030kq1 wont turn without help
Sounds like you have a dead zone in your motor...could be a replacement motor is called for. or continue to spin the drum by hand till the motor goes kaput...its cheaper
Sep 26, 2009 | Whirlpool LEQ9858P Electric Dryer
Heater works, dryer won't start
Replace your dryer belt.
Sep 19, 2009 | Whirlpool Dryers
Dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
ELECTRIC DRYER WON'T TUMBLE
Possibly the belt assembly. if you open the door and try to turn the drum does it turn with a little resistance, noises? this model has rollers, pulley, and a four groove belt 92 1/4" , sometimes the pulley sticks after yrs of use, belts wear, drum misaligns. the humming should be the motor trying to work.
Feb 03, 2009 | Whirlpool LER7646E Dryer
Humming noise, runs and stops thru out drying process.
You have a motor that has a thermal overload built into it. This is for the dryer's protection. My best guess is to replace the motor. But before you do all that, make sure the wiring is good from the receptacle to the controls in the back of the dryer. It could not have a good connection thus causing this noise.
Jan 29, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool ET8CHEXSQ Dryer Logo
88 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
