Question about Lenovo IdeaCentre B510 - 77121VU (Black) - Intel Core i7-870S ( 2.66GHz 1333MHz 8MB ) PC Desktop
B510 - unable to open the back panel (manual useless)
  • rheil56 Mar 15, 2011
    Am still helpless. The back panel is ONE piece, right ? Am scared to break anything. Computer is just 3 weeks old and 4 GB RAM waiting to be put in... :(
    Scholar:
  • 169 Answers
I will providing you link where you can access the step by step procedure on how to remove the back panel of your system.
Note: Make sure to remove the eight (8) rubber caps on top of the screws then remove the eight screws after.
Here the link and access page 32 to 33 for your reference.
http://consumerdl.lenovo.com.cn/UserFiles/UserGuide/en/User's%20guides%20and%20manuals/B510/Lenovo%20IdeaCentre%20B5%20Series%20Hardware%20Maintenance%20Manual.pdf
Cheers . .
If there is still any problems, leave a comment so that i could further troubleshoot.
Posted on Mar 15, 2011
  • 3 more comments
    Thanks for your quick response. I already tried to follow that manual - I removed all the screws and then could not find any "Tabs". Tried to lift both sides carefully with a screwdriver, was stuck then (am not the only one by the way ...) On the right side there is only the drive and the power button which seems to be in the way.
  • Dino Dichoso
    Dino Dichoso Mar 15, 2011
    the tabs are the left and rigth cover at the back of the computer, I have check it with my own system try locate any locks that prevent you removing the tabs, It would be much better to remove one tab at a time.
  • rheil56 Mar 16, 2011
    I still cant work it out. Afraid to break something. Pc is only 3 weeks old and 4 GB RAM waiting to be put in ... :(
  • kashari Apr 22, 2011
    I'm also having this same problem of trying to install additional memory, were you ever able to remove the back? I don't see any tabs nor did I have any 'rubber covers' to remove from the screws. If someone has been successful with this operation, can you please provide more details as to exactly where the 'tabs' are and what they look like?
  • nick0789 Sep 24, 2011
    I know this is an old post, but I just got my back panel off. This is what I did:
    1. Remove the 8 screws
    2. Pop up the two top corners (opposite the speakers) slightly; You should feel it release
    3. Across the top (where the orange mesh is), push in slightly and pop up. Continue until you have gone all across (Those tabs like to reattach when you get past midway, so put a precision screwdriver (rubber side in) to keep it from reclamping). I also used the screwdriver to help get leverage to pry up the mesh, but be careful; just use it so you can get your finger in, not to PRY.
    4. Now you should have the whole top part un-tabbed, go halfway down on each side and just above the disc drive and just above the memory card reader/headphone jack, there is a pop tab. It takes a bit more effort than the top piece, but don't go crazy on it.
    5. Now focus on the bottom part of the panel: in the middle (inbetween the speakers), you can pop up the back panel a little; If I remember correctly, there are 3-4 tabs.
    6. Now the biggest pain the **** for this back panel: just below the headphone jack and just below the CD drive, there is a very sturdy pop tab. What I did was put a precision screwdriver in the part of the speaker panel that is angles (45 degree part) to help "pry" it up. DON'T wiggle to pry up too hard, that plastic is soft and you can make a divot in it with the screwdriver.
    7. After you get past step 6, go back to the top and lift up from the top corners (lift towards the speaker, like you are standing up the panel). There are two small pop tabs at the bottom that will/should release when the panel is pivoted. It not, go back to the speaker area and make sure the tabs are popped up enough.
    8. You're Done.
Removed inner door panels on my 11 Pilot to reupholster arm rests. After I reassembled the panels I am unable to open the doors. I put everything together properly, do Pilots have a door tamper secu
you must have either broke a plastic clip at the lock area look good or one of the little arms came off look good you will find hte problem .bothe doors , did you brake a wire ? look good
Dec 01, 2014 | Cars & Trucks
Right back door handle is broken, unable to open door
You have to get the door panel off....then you can open doot
Jan 26, 2014 | 2002 Lincoln LS
Epson B- 510 DN printer error printer restart 0x95 error
Epson Printer Error 0x95 occurs when the printer head has gone empty or you can say that it has become completely saturated. The reason for this Error may be issues in installation of windows, update of application of Windows, etc. Follow these steps to resolve the Error.
Steps to Fix Error 0x97 in Epson Printer:
Solution 1: - Check Epson Printer Ink Head
Printer ink becomes dirty because the ink pad is full. Due to unbalanced ink it generates the problem or displays a message of Error Code 0x95. Unplug the printer completely and leave it for a while. Then users must need to remove and replace the sponge and clean the eye.
If this step is not working to fix Error Code 0x95, then go to next step.
Solution 2: - Manually Perform Steps with Epson Printer
  • Switch on your Epson printer.
  • "press+hold" together to stop ink power buttons.
  • Wait for sometime while the printer switches self OFF.
  • Switch ON again and your error should have gone.
Solution 3: - Run the System Under Safe Mode
You should try to run the computer under safe mode, and then you may receive a message from the system about your error existence is effectively solved or not.
Solution 4: - Uninstall Current Installed Software From System
  • On your Windows "Start" button, go to "Programs and Features".
  • In the "Control Panel", tap "Programs", and then tap "Programs and Features".
  • Choose that software program that you have just installed, and then tap on "Uninstall" button.
You can visit Epson Printer Support Number if you are still unable to resolve the Error.
Jan 24, 2014 | Office Equipment & Supplies
Epson B510 DN error 0xf3
SAME PROBLEM WITH ME :(, DONT FIND ANY SERVICE MANUAL OF EPSON B510DN
Jul 02, 2012 | Epson Office Equipment & Supplies
I have the Ideacentre B510, 77121VU and I want to change the size of the partitions. How shoul I do that, or that's other thing to do, cause my drive C is already full. Thank you!!!!
I would recommend that you download Easeus Partition Manager 3.0 Home Edition. Its a free application and has a very easy and intuitive interface which will allow you to resize or create logical partitions.
Apr 11, 2011 | Lenovo IdeaCentre B510 - 77121VU (Black) -...
Chair has been idle for years. I tried to turn it on and nothing happened. I plugged it in and waited 2 hours, all the lights came on. Looked at the owner's manual and it was pretty useless to me. So, all...
Robbin,
It will not help to try to charge those batteries. No amount of charging will bring them back You will need to buy 2 U1 batteries if your chair is a smaller Jazzy or Jet. The heavy duty chairs take a bigger size battery Hope this helps you Check if there is a battery distributor or store in your area they will be cheaper than going to a provider that sells chairs
Sep 05, 2010 | Jet Health & Beauty
I have a canon laser class 9500, i am unable take fuser
Hello sir ; The user manual you get it online, instrction to remove the fusing unit quit simple, open back door ( sometime require to remove back panel ) you may findout two blue knob release it and may be aalso need to removed two screw pull out this unit half way the unpug the connecter , whole unit coming out.
Aug 18, 2009 | Canon Office Equipment & Supplies
Lenovo IdeaCentre B510 - 77121VU (Black) - Intel Core i7-870S ( 2.66GHz 1333MHz 8MB ) PC Desktop Logo
503 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
