Question about IBM ThinkPad T40 Notebook
Hi There, My IBM T40 Think Pad keeps on losing connection with hard disk frequently, Before i tried to remove it & Reattached it again & it has worked, But now it's not helping any more Regards, E. M.
  • funlovin420
    funlovin420 Apr 08, 2012
    Mine did the same up until the point where it quit working unless you press the spot where the hard drive plugs into the motherboard in between your fingers like vice grips and it has become useless.Has anyone found a solution to this problem?
    Problem Solver:
  • 11 Answers
If the hard-drive is losing connection even after removal you should test to make sure that the drive is still functioning.
Try to see if your system has an on-board diagnostic, (f12 on startup, before the windows loading screen) this will tell you if the hard-drive itself is actually broken, or if it is just a connection.
Posted on Mar 15, 2011
After changing out fan IBM think pad t40 screen goes black after windows xp screen finishes losding up
Wait Black Screen? AFTER you changed the fan... hmmm... I think I know what the problem is. Okay solution one; You might of hit a wire or cord in the computer when you changed out the fan. Two: You might have the virus 223, get it fixed and it should be going again! Hoped this helped! :D
Mar 25, 2013 | IBM ThinkPad T40 2373 Notebook
LOOKING FOR THE ON/OFF WIRELESS SWITCH FOR AN IBM T41 THINK PAD, I THINK IT GOT TURNED OFF ACCIDENTIALLY. LENORE07407@YAHOO.COM
Try pressing Fn+F5, this is the standard on IBM laptops for enabling/disabling the wifi connection.
Jan 18, 2011 | IBM ThinkPad T40 2373 Notebook
IBM t40 think pad wireless won't turn on, I can see the light but will not connect
Try to restart the Services of Wireless Zero Configuration or Wireless Auto configuration in the Services Section. To open service, type "services.msc" in the run command.
May 03, 2010 | IBM ThinkPad T40 2373 Notebook
T40 2373 no wireless connection
Hi it sounds like your driver is missing or corrupt , this may be the case if u have recently installed windows, go to control panel click on sytem icon then click on device manager button under the hardware tab, have a look then under network adapters to see if there is a yellow warning icon if so make a note of the name and you should be able to download the driver from this location. its near the bottom under networking wireless.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-46258
please rate ! hope this helps :)
Feb 10, 2010 | IBM ThinkPad T40 2373 Notebook
I have an IBM think pad T40 that does absolutely nothing when I try to turn it on. It's actually my daughters, she sid it was working just fine then she shut it down and when she came back an hour later it...
Try taking the batter out and booting using just the power cord and Vice Versus'. Also when the power is plugged in does the charging light (Battery Indicator) blink or light up? If you know the Power Supply is good, then the Mother Board may have fried. If it's under warranty, take the Hard Drive out and send it in.
Dec 20, 2009 | IBM ThinkPad T40 2373 Notebook
T40 ibm think pad connections
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Jan 25, 2009 | Visioneer OneTouch 5600 Flatbed Scanner
IBM THINK PAD 390X LAP TOP INVALID SYSTEM DISK
check that you have no floppy disks in the drive and also no usb memory sticks/Hard drives plugged in as if they are and are not bootable you will get the error you describe
Dec 11, 2008 | IBM ThinkPad T40 2373 Notebook
Think pad T40
It's possible that this is a hardware problem, but it sounds more like a loose connection to me. Start by removing the keyboard and checking all visible connections. You should be able to see the touch pad, keyboard, and screen connections with the keyboard off, and, yes, I realize that you cannot check the keyboard connection with the keyboard off, but you can when putting it back on. For some reason I keep getting people that love to point out the obvious lately, so I'll throw that in there right off the bat. Also check the hard drive to see if it's seated properly. If the problem persists, you may need to take the cases apart and check all connections on the board.
Aug 22, 2008 | IBM ThinkPad T40 2373 Notebook
Status lights flash, but no bodys home!
remove the hard drive and try to see if that boots up if does bad hard drive if does not do anything change the internal batery and try again i think that will fix the problem
Dec 30, 2007 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T40 Notebook Logo
75 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
