Question about Microsoft Computers & Internet
Steps on how to insert a table in publisher. - Microsoft Computers & Internet
  • 55 Answers
If you are using Office 2007 or 2011 just create a new document and click the inset tab. Once you click that select table and select your dimensions. If you are using Office 2003 just look for the insert option sometimes just by doing right click (but im not sure about 2003). Hope this helps and dont forget to rate. Thanks
Posted on Mar 15, 2011
I followed the steps that were suggested solution, but it still does not boot on cd.Ce to do in this situation?I followed the steps that were suggested solution, but it still does not boot on cd.Ce to do...
You must go to bios and change the booting sequence to CD drive and you need to check if the cd from which you are trying to install windows xp is a boo table one you can do so by inserting the cd in a different system and try. IF not then check if your cd drive is working by inserting any cd in it.
Regards
Samson Ved
Oct 18, 2013 | Fujitsu Siemens SCENIC P300 PC Desktop
Tip
Deleting Rows & Columns from the table
You can also remove columns or rows from the table. Once a row or column is deleted, it can be undeleted by using Undo command. You can delete the columns or rows or cells by using one of the following ways.
By Table Menu
To delete a row or column by Table menu, follow these steps.
  • Place the insertion point in the column or row that is to be deleted.
  • Click Table menu and then select "Delete" from Table menu, a submenu of Delete is displayed.
  • Select Columns or Rows or Cells command to delete the selected element (column or row or cell) from the table.
By Popup Menu
To delete a row or column by popup menu, follow these steps.
  • Select the column's you want to delete.
  • Right click the mouse, a popup menu is displayed.
  • Select "Delete Columns" command, the selected columns will be deleted.
OR
  • Select "Delete Cells" command, "Delete Cells" dialog box is appeared.
  • Select "Delete entire row" to delete a row or select "Delete entire column" to delete a column etc. from the dialog box and click "Ok" button.
on Jan 29, 2010 | Computers & Internet
I have changed my XP for a Windows 7 with Office 2010. I cannot find the facility in Word 2010 to draw lines between text, erasor, etc. (which I find very useful when constructing Family Trees.) Is there...
Almost all the features of Older versions of MS Office are available in Office 2007 & 2010.
If you are working with tables, and wish to add/ draw lines using pen and use eraser, then after drawing the table, click the drop down and select 'Draw Table' and the table borders editing options will be displayed after clicking the table (the pen and eraser). The picture below shows the steps:
Hope it helps! Good Luck!
CreativeTECH
Apr 12, 2011 | Computers & Internet
How to make a 7 row and a 7 coloum in a spreadsheet
Creating a table in Microsoft Excel 2007 allows you to work with that data independently of the rest of the worksheet. First you must define your table, though, which you can do either from scratch or from data already in the worksheet. The process is a simple one. Read on to learn how to define a table in Excel 2007
  • Start off by doing one of the following: Select the range of cells that you want to make into a table within your worksheet then proceed to Step 2 OR Start immediately with Step 2.
  • Click on the "Insert" tab at the top of the document.
  • Find the "Tables" group, then click on "Table." The "Create Table" dialog box will appear.
  • Type in a range for your table if you did not select a range in Step 1. If you did already select a range then that range will automatically appear in the dialog box.
  • Check the "My Table Has Headers" box if the data set you selected already contains the headers you want to use. If you don't check this box, the table will display default header names, which you can then go in and change.
  • Hit the "OK" button at the bottom of the Create Table dialog box to create your table.
  • Thanks for choosing Fixya............ Sandeep
    Mar 18, 2011 | Computers & Internet
    I don't know how to save and insert a video Please help me, cuz I must use that in a week later for my report
    to insert a video click go to insert then on the right side of the tab you will see object then link to the video to save on the top left is a circle click it to save or save as . i suggest using .wmv movies in word. same goes for publisher and powerpoint. if this helped let me know via testimonial or thumbs up! hope i helped ya let me know!
    Mar 15, 2011 | Microsoft Office Professional 2007 Full...
    I have a craftsman table saw model 113.27870. I need a table insert for a dado blade. I looked on the sears website and it said parts for this saw are no longer available. Will a table insert for a newer...
    Maybe you could try using the outline of the regular insert to cut a new insert out of a piece of polycarbonate (lexan) or ABS plastic. The clips that hold my dado insert barely hold it in place on mine, and I've seen other saws that use plastic.
    Aug 02, 2010 | Craftsman 10" Table Saw
    Recently im doing a data entry job, im typing a jpgfile to ms word...how can i match my MS-word file with the image files to find out my mistakes
    Unlike publisher, MS Word is not a pagination suite, it will varry slightly when converted or even if you print to a different printer. The best way to try and resolve this is to do all your formatting using tables instead of tabing and creating free floating objects. This takes longer but will force the objects to adhere to a structure within the page.
    Dec 03, 2009 | Computers & Internet
    Hi! Please help me..can i ask a question?? what are the special symbols in dreamweaver and in what tab can those symbols be found?
    Try these steps dude :
    • Open insert menu --> choose Character --> the character to be inserted
    • or
    • Open insert menu --> choose Character --> then more to see more special characters
    Feb 01, 2009 | Macromedia Dreamweaver MX 2004
    Steps in saving file in excel to database
    severals solution :
    - save file as text separated by comma and use sqloader from oracle
    - use function in excel to concatenate insert order : "insert into TABLE_NAME (field1,...,fieldn) values (A1,B1,...,??n);". Save file as text with sql extension. Connect against roacle db and execute file previously saved.
    - use ODBC from MicroSoft
    Dec 11, 2008 | Microsoft Computers & Internet
    Budgets in excel
    Dear Madiha35,
    I would recommend the use of the Table Function in Excel.
    Here are the steps in Excel 2007, if this does not work for your version please add comment for me to reply to.
    Conversely, If you would like the softcopy of the screenshots, I would be happy to email them to you.
    Excel 2007 had a budget format workbook
    New workbook, Select Budgets in the last hand navigation, Select Personal Budget.
    Step 1:  Enter your data into the worksheet.
    Step 2:  Create Table
                 Highlight the relevant data
                 On the insert tab, click on Table
    Step 3:  Verify Table range is correct, Click OK
    Step 4:  Select the cell you where you wish to Sum Data.
             Click on Autosum.
    Step 5:  To Insert new data
             Click on the sum row in the table, (Not the entire worksheet row)
             Right click, Insert, Insert Table rows from above
    Step 6:  Enter new data in row
    Step 7:  Data is automatically calculated in formula.
    Oct 22, 2007 | Computers & Internet
    Computers & Internet Logo
    43 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
