Question about Kenmore Elite 45986 Front Load Washer
I've gotten the error code DL and then F, I tried sanding, unplugging but it still shows me the error. How can I fix it?
  • 668 Answers
Initially unplug the washing machine.While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for five seconds.
Plug the unit back in, and run a rinse and spin cycle to test if the DL code is cleared.
If you still face the problem then follow the procedure:
Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Plug the washer back in and press [Power] to turn on the washer.
Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Press [Start/Pause] to begin a drain only cycle.
After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause].
This will remove excess soap suds and light residue from the drum.
Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Shane
Posted on Mar 15, 2011
Our Neptune Washer won't start up. It shows a Code (ol). What does this mean? We;ve tried unplugging & and Re-loading it. Still OL code.
From the FAV6800A/FAV9800A Service Manual page 14 that error code = oL Machine Paused-Load Wedging
Google this "16022808 Revision 0 December 2003" to find the Service Manual if you are going to DIY the fix.
Mar 26, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My wash is showing a error code of F dL.. It will not let me restart the washer. It basically is froze
The dl code is door lock. The manufacture explanation of the code is here then my comments follow.
A Door Lock Error occurs if the door cannot be locked. It
will try to lock it six times before displaying the error code.
Possible Causes / Procedure
■ Door lock mechanism is broken or removed from door.
■ Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/
lock unit and Central Control Unit (CCU).
Phil's comments------>
It it almost always a failure of the door latch mechanism. The part number is 8182634 and cost around $45.00
Here is a parts break down to show you where the component is located it is part #7 in this drawing.
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fW0111040-00002.png
Apr 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Lid does not lock. When it DOES, it beeps and shows "dl" on the screen
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
"FE" Error code on Lg Washer #2277HB
FE means overflow condition. That means sand or trash has gotten into the tube going from tub to water level switch. So find that hose and blow it out. Remove the standing water and retry.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | LG Washing Machines
Code DL then F What does this mean?
i just finished fixing this problem on mine. DL = Door Latch. i am guessing you hear 6 clicks (processor trying to latch door) then the error. while i was poking around inside the unit i found a service manual inside (behind the bottom cover, remove 3 screws to gain access). the service manual reminded the tech to always try unplugging and replacing the connectors on the processor since oxidation is a major problem. the manual also noted the connector numbers (DS3... i think). i removed the top cover (3 screws on the back, slide back, lift off), found the processor, unplugged and reseated the connectors (did some others just for good measure), plugged the unint back in (ALWAYS UNPLUG BEFORE WORKING ON IT), and it worked. in case that doesn't fix it, you couldtry replacing the latch assy for about $50. good luck
Sep 17, 2008 | Kenmore Elite 45986 Front Load Washer
Error code ER FF
The error indicates the freezer fan is not functioning properly. The fan supplies cold air to the refrigerator that is why it seems warmer.
The fan may be frozen, try unplugging it for a few hours to let it thaw. Also check to see if something may have gotten into the vent holes in the freezer that could be blocking the fan from turning.
Mar 11, 2008 | Refrigerators
Kenmore Elite 45986 Front Load Washer Logo
629 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
