Question about Philips Televison & Video
I HAVE A PHILIP PROJECTION MODEL 60P8341A, THE CONERGENCY IS OFF MAINLY THE RED VERTICAL BOTTOM IS BEND,WE CHANGE THE 2 IC'S AND THE PROBLEM IS STILL THERE,CAN YOU HELP. THANK YOU
  • Philips Master
  • 8,617 Answers
Did you check and replace any of the 6.8 ohm resistors? A phillips will almost always blow at least one of the resistors when the ICs fail. If the blown resistor isnt replaced the new ICs will fail almost instantly.
Posted on Mar 18, 2011
The bottom portion of my screen is double vision witht the colors red and green only
p { margin-bottom: 0.21cm; }
hi,
ur tv has problem with vertical scanning section. may be dry soldering or vertical output ic faulty.
check for any dry soldering in that section. mainly the soldering of vertical ic. if see or not re-solder the leads of the vertical ic . then check is the tv is ok or not. if complaint remains replace the vertical scanning out pout ic. it will be fitted on a aluminum heat sink in the vertical section. u can see the heat sink on which the ic is mounted in the picture ( in side the small green circle). if u need more assistance feel free to contact through fixya.
regards
Ajin
Jan 05, 2011 | Panasonic PT-47WX53 47" Rear Projection...
60P8341A looks red
replace the coolant in the CRts . The blue and green coolant gets congealed and causes the red to become dominate and the picture will be dull. You can get the Phillipos CRT coolant kit at the following link the Kit contains the instructions on CD
http://servicemanuals.vstore.ca/
Sep 13, 2009 | Philips 60P8341 60" Rear Projection...
Toshiba 2938xp crt tv vertical deflection fail and i want diagram
I don't have access to the manuals for your specific model, but vertical failures are usually the result of poor connections at the vertical IC or a defective IC. Look for a small flat IC attached to a heat sink with about 9-11 pins. It may be marked LA7837 or something similar. Resolder the pins first. If that doesnot resolve the problem, change the IC.
Keep us posted,
Dan
Apr 15, 2009 | Televison & Video
Mitsubishi rear projection tv
replace vertical IC and shadows/ghosting the problem is either electrolytic capcitor or video IC or convergence adjustment
Aug 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Sony tv model no. KV - 19 APR 2
This is for a different model, but I had thin horizontal lines in red and had to adjust the tube for red. You may have a similar adjustment on your set.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Aug 01, 2008 | Sony KP-48V80 48" Rear Projection...
Philps 60P8341A
I have a 60 in. Philip Magnavox tv that it haveing sound problems.It,s sounds when is in dvd ,but not when is in tv the model no.is 9p6040 c104. Does anyone have any ideas to fix this problem? Thank you........Lucy
May 03, 2008 | Philips Magnavox 27MS343S 27" TV
Convergence IC's
Lines going across is a little vague but there is always the problem with the electrolytics (caps) around the vertical, be sure and get the one on the power supply too. Just change all you can find(usually 4-5). Thre are 2 convergence ic's if you didn't change them both, resolder the other one.
Then check the value on R519 for me.
Apr 09, 2008 | Apex Digital GB5108 51" Rear Projection...
Vertical black lines rear projection
Please provide exact model from back of tv........
Possible vertical IC circuit problem===bad caps? IC?
...........T.
Nov 01, 2007 | Hitachi 50UX57B 50" Rear Projection...
Picture shows only about a 2-3" blue,green,or red vertical line down the middle
If your seeing vertical line across the screen you need to check the components in the vertical stage as well as the vertical IC could be bad, or the yoke could open.
Also check if any voltage reaching the vertical stage.
Good luck.
Was this help full.
Oct 31, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Television has no picture
That TV uses the PTK195 chassis, and the fact that you see only a thin line for each color near the bottom of the screen tells me your vertical output IC has stopped working, and is putting a small DC voltage across the yokes. I have seen this caused by a defective vertical output IC and I have also seen vertical problems caused by a small CRT coolant leak which drips onto the main board near the vertical output IC. If you do not have experience servicing the PTK195 chassis than have a qualified tech handle it for you.
Jul 12, 2007 | RCA P52937 52" Rear Projection Television
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
